11-29-2018, 07:40 AM
#21
Dayton
, OH, 2017 33' Classic 8,561 dry
FWIW 490,000 miles on my 8 speed Ecodiesel transporting TTs. I have changed the fluid 5 times 3 times with filter. No transmission repairs. Shifts smooth & quick. Generally tows 6-7k daily has towed 9k & 15,500 CVW going over 6 percent grades. (The turbo brake & factory trailer brake controller are great options) tuned to 465 TQ.
BTW local dealership has an 18 ED sitting out front. Often what the salesman recommends is the particular car the dealership has had the longest / most wants to get rid of.
11-29-2018, 08:05 AM
#22
1971 27' Overlander
Kansas City
, Kansas
I wouldn't be too concerned about new transmissions. The complexity of repairing them has only marginally changed over the past 10 years. parts always become available with time. Give it a few years and parts will showing their faces as the transmissions find their way into world markets.
11-29-2018, 08:24 AM
#23
1981 31' Excella II
New Market
, Alabama
Made by Fiat you know it is going to have problems. As soon as these came out, I knew this would happen. Fiats are notoriously unreliable. I am sure they are great till they are not. When Cummins makes the engine, I will change my tune. Diesels are more expensive on a good day than most gas engines. They are fun to tow with.
Perry
11-29-2018, 08:43 AM
#24
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
VernDiesel
This longevity performance is what I was expecting and still believe is obtainable which is why I had the engine replaced as opposed to junking the Jeep. You give hope, but I will only do it once. Jim
11-29-2018, 08:50 AM
#25
1994 30' Excella
alexandria
, Kentucky
Perry
The engine is produced by VM Motori (a company owned by Fiat). I believe this engine was originally developed for Cadillac. I think most of the issues have been with a faulty EGR cooler allowing coolant into the crankcase. Emission control systems on diesels are so complicated that it is just a matter of time until problems develop. I think there was a TSB on these engines to run heavier engine oil. They had some European spec of 5w-30 or similar which just seems too thin for diesel motors.
Maybe Verndiesel will chime in and set the record straight on the preferred oil weight as he apparently has had good luck with this motor.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-29-2018, 10:01 AM
#26
Aluminut
2004 25' Safari
Originally Posted by J-Dog
Bummer...I thought those days of blowing motors were behind them, but apparently not.
Transmissions too. If I had a buck for every Dodge owner that told me they have had 3 trannies in 100k miles...."but I only paid for one of them", I could retire.
11-29-2018, 11:43 AM
#27
1971 27' Overlander
Kansas City
, Kansas
Just to clarify. The EGR cooler, when leaking allows coolant to flow back into the intake of the engine. The cooler is used to cool down exhaust gas which is then fed back into the engine to reduce Nitrous Oxide gas emissions.
11-29-2018, 01:31 PM
#28
Dayton
Fiat now owns both VM Motori who builds the 3.0l diesel & Chrysler that bought rights to assemble & sell German Mfg ZF’s transmission but Fiat builds none of this. VERY few Rams are having issues with this transmission relative to sales volume etc. It has no lineage to past Ram transmissions.
I did use the original 5/30 Penzoil Euro L environmentally friendly full synthetic made from natural gas oil. Clean & Zero ash but thin. 170,000 miles with good oil analysts results. I then switched to the thicker cheaper & more readily available T6 (5/40) as it’s been added as an approved oil.
This motor is a real gem but the first gen has a bearing eating problem that a thicker oil isn’t fully midigating. Fortunately Ram has been pretty good about it even meeting some people part way beyond the 100k warranty something I’ve never seen Ford do. Fortunately we should see the 2nd gen next summer in the 5th gen 1500.
This motor is nitch product in that it is best used to supplement the Hemi & Pentastar in the 1500 for 5 to at most 10 percent of sales and matched to perspective buyers needs & goals. It has been valuable to Ram though as it’s been responsible for acquisition sales to grow the market & their share of the market. IE because a higher percentage of people who bought it came from driving a car or a Toyota Ford or GM truck thank you 30 HWY MPG. Unfortunately that has become a two edge sword in that if they don’t keep it and competitive with the new Ford & GM 1/2 ton 3.0 diesels they will lose what they had gained.
It suits my unusual duty cycle or needs & goals as I drive big miles & tow moderate loads in fact the profit of which is directly related to the towing economy.
12-01-2018, 09:53 AM
#29
Dazed and Confused
Hillsburgh
, Ontario
Update......
Engine is kablooee and will need an engine replacement....dealership declined to tell him what happened.[emoji57]
One problem; the total engine allotment coming to NA for FIAT 3.0l turbo diesels has been spoken for......my boss won't get an engine until......wait for it.....April!!!
He thought I was joking when I told him three months...and I was off by three months.[emoji849]
Cheers
Sidekick Tony
12-01-2018, 03:57 PM
#30
1997 25' Safari
Burlington
, Ontario
Engine blew up!
My EcoDiesel imploded in September. The dealer told me that I was 111 on the wait list for a long block. It took 8 weeks for delivery and installation . All works perfectly, just like it was working prior to the moment of implosion. Jim
12-01-2018, 04:06 PM
#31
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Let me just apply my politically incorrect opinion, the EPA ruined diesels with it’s unreasonable emission control requirements.
12-01-2018, 04:34 PM
#32
Vancouver
, British Columbia
Let me just note that your opinion that the EPA is too strict on vehicle emission controls is at odds with your recently expressed opinions in a different thread about the US and global leadership in environmental regulations, and being a nation of laws. Hard to have it both ways.
There is a reason that some manufacturers have either pulled out of light duty diesel engine production, or announced plans to.
12-01-2018, 04:48 PM
#33
1972 31' Sovereign
Benton
, Arkansas
Nope.
Not at odds at all, but you have to follow along with me to get what I’m saying.
My point of view in general is that vehicle emissions were “clean enough” by about 1990 standards, and further what the EPA expects from diesels over the past ten years or so is unrealistic.
My point of view is that spending about three times getting the last one percent of emission improvement over and above the cost of getting the first 99% cleaner has worked well past the law of diminishing returns.
12-01-2018, 05:35 PM
#34
Salem
, Oregon
I don't like Diesels.
Hi, I don't care what anyone says about Diesel emissions; Every time that I get behind one of those stinking diesels I have to close my fresh air vents, change lanes, change streets, or pass that horrible stinking skunk.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-01-2018, 07:13 PM
#35
Vancouver
, British Columbia
Nope.
I follow you, but it doesn’t compute. You are living in an area with lower emissions standards than some other parts of the world. You can’t argue to further relax those standards while also claiming leadership in environmental stewardship. China isn’t representative of the whole world. Lots of countries are tightening emission standards, not relaxing them.
Diesel emission standards have been relaxed beyond gasoline engines in some cases. Nobody is asking “too much” of diesels. Holding them to common emissions standards will result in them being not cost competitive (lots of after treatment) which is what some manufacturers are already recognizing by ending development and production of diesels. If they are made cost competitive, they will suffer on reliability and durability, as we are already seeing.
But don’t just focus on diesels. Internal combustion engines will stop being used for personal transportation as well. It will just take a little longer.
12-01-2018, 07:14 PM
#36
Vancouver
, British Columbia
Try riding a bicycle behind one.
12-01-2018, 08:24 PM
#37
1972 31' Sovereign
Benton
, Arkansas
Nonetheless, there is always a point of diminishing returns, and the fact is, American emission standards of 1990, diesel and otherwise, are about infinitely more stringent that the standards in China because standards do not exist.
As far as what’s “gonna happen”, when it happens it happens.
12-01-2018, 08:29 PM
#38
1972 31' Sovereign
Benton
, Arkansas
As far as less than medium duty diesels go, I could care less. I won’t own one because they’re ruined by emission standard. They’ve been made A) too expensive to maintain and B) too unreliable. I hate having to call a tow truck.
12-01-2018, 08:38 PM
#39
1982 28' Airstream 280
Port Angeles
Just remember all you diesel haters that just about everything you own and consume traveled to you on a diesel powered vehicle.
Cheers, Dan
~ Margaret Thatcher ~
12-01-2018, 09:19 PM
#40
Dazed and Confused
Hillsburgh
, Ontario
Amen to that; and protect your freedoms to do idiotic things; no gas powered Hummers in the military.
Cheers
Sidekick Tony
