Old 05-24-2020, 05:45 AM   #1
2018 30' Classic
Callao , Virginia
Duramax Oil
We have a 2017 Silverado with the 6.6L Duramax and it's time for our first DIY oil change. Dealerships have been doing our maintenance so far and used the GM Delvac 15W40 (P#88864038 quart size) which is a synthetic blend I believe. Our home is in Virginia so no worries about extreme cold temps and plan on staying with the 15W40 grade oil. So we are looking for any Duramax owners who would like to share what brand of oil they use Mobil, Shell, Amsoil, etc.. Also the type conventional, synthetic blend or full synthetic. Any Diesel mechanics who want to chime in would be excellent. Thank You in advance!
Airhead2018 is offline   Reply With Quote
Old 05-24-2020, 06:54 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I use a Rotella T6 full synthetic, but if you want to stick with 15W you will need to go with T5 blend. I use a Mobil filter.
Old 05-24-2020, 07:10 AM   #3
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Go with Shell Rotella T6; you'll be happy. When I've exhausted the "free" oil changes that come with a new truck purchase, that's exactly what I will go back to using.
Are you claiming Shell doesn't make T6 in 15W40 grade? I see it everywhere. Here is an example. (Full disclosure: you get the most benefit when switching to 5W40, so that's what I run.)
2019 Flying Cloud 30FB Bunkhouse
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 05-24-2020, 07:16 AM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I use Rotella T6 5W40 full synthetic, and Rotella oil filters. Have used this oil in the last 3 Duramax trucks I have owned with 0 problems. I run 10,000 KM or 6500 miles between changes. I also have a FASS fuel system installed and change all fuel filters every third oil change. I also use fuel conditioner at every fill. Stanadyne is a great fuel additve to give extra lubrication to the diesel injetor pump.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 05-24-2020, 07:19 AM   #5
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
DuraMax DIY Oil
Mobil1 Turbo Diesel Truck - 5w-40 Full synthetic w K&N Filter
<https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-turbo-diesel-truck-5w-40/>
Best!
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 05-24-2020, 07:40 AM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
No but I do run 5W40 in mine. That what my local guy carries. Easy for me to find.
Old 05-24-2020, 10:22 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Rotella T4 for me as well.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-24-2020, 06:23 PM   #8
Lucky Dog's Avatar
2014 25' FB Flying Cloud
Down the Shore , New Jersey
Whatever premium, non-synthetic diesel oil WalMart has on sale plus Napa Gold filters (oil and fuel) from fleetfilter.com Oil change every 5k, fuel filter change every other. ‘06 Duramax, 180k miles, and all good so far. Also have been using Diesel Kleen fuel additive for the last 120k or so.
Rich
Lucky Dog is offline   Reply With Quote
Old 05-25-2020, 05:39 AM   #9
2018 30' Classic
Callao , Virginia
Rotella seems to have a good reputation here and otherwise. I use Valvoline in all my gasoline vehicles with NAPA Gold filters. Not a minutes problem and we reached 330k miles on our Tahoe before giving it to our daughter who is still running it. The only other diesel motor we had was a Mercedes which used Mobil in but we didn't keep that long. I assume a full synthetic would be the best but don't want to over do it if not necessary. In any case DIY will save $$ no matter what, decisions, decisions.
Old 05-25-2020, 06:37 AM   #10
2018 25' International
Slidell , Louisiana
If you go by the physical properties of the oil, Amsoil consistently comes in the top couple. It also consistently holds the important properties as it ages. Full disclosure, I work for Shell Oil and our Rotella product is very good, but if you go by the numbers there are several better oils, including some at a competitive price.
That everyone report goods experience with the oils they use speaks volumes to the standards and the general forgiving nature of engines and oil.
Brian
Old 05-29-2020, 05:44 AM   #11
2018 30' Classic
Callao , Virginia
I appreciate your input being an oil man who knows the specs. I have looked at Amsoil and like the product but it's about twice the price. Also I have someone else change it if we are traveling so availability might be an issue.
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Duramax oil change BillTex Tow Vehicles 35 04-23-2009 11:50 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Duramax-Allison Pahaska Tow Vehicles 34 11-23-2003 10:55 PM
Duramax towing question Mark Wiltrakis Tow Vehicles 6 11-07-2003 12:24 PM
