Old 09-05-2018, 03:21 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Cummins Diesel Engine
Several days ago I traded my RAM 1500 for a RAM 2500 with a Cummins. My first ever diesel!
I noticed the coolant temperature runs about 190 degrees and the oil temperature is about 200 degrees. Both of these temperature are 15 to 20 degrees cooler than the 5.7 hemi in my 1500. These readings are taken after driving for over an hour in mid 90 ambient temperature. Also, this is truck only with nothing being towed.
Also oil pressure is less by about 10 PSI as compared to the hemi.
Of course the hemi ran at higher RPM's generally speaking.
I was surprised that the temps. would be lower. I guess this is normal. Just trying to understand this new beast I have under the hood!
Hans627 is online now   Reply With Quote
Old 09-05-2018, 05:53 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I would put it to work, and enjoy it.
A bumper sticker from Geno's Garage www.tdr1.com was Load the wagon, don't worry about the mule.
Enjoy it you're running a completely different powertrain.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 09-05-2018, 06:19 PM   #3
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
The 2500 RAM is a hearty beast. We replaced a 2012 1500 Hemi with a 2016 2500. Best move we could have made. I recall always being conscious of many of the gauges while towing with the 1500.
Remember to pay attention to the DEF gauge in your 2500. You don't want to get below 1/4 DEF level, especially in the Yukon (an example of an isolated location). Always use MoPar DEF and keep the receipts in the truck. If you get caught out with a DEF alarm or limp home situation, you'll want to be able to prove to the dealer and FCA reps that you used MoPar DEF.
SilverWind is offline   Reply With Quote
Old 09-05-2018, 06:33 PM   #4
ITSNO60's Avatar
Tucson , AZ
Diesel trucks tend to have large radiators and cooling systems. Pretty hard to overheat one. Unlike the notorious Rabbit diesels that only held 3 quarts of coolant.
Brian
ITSNO60 is offline   Reply With Quote
Old 09-06-2018, 07:21 AM   #5
mojoe7009's Avatar
Green Cove Springs , Florida
As a former automobile dealer for 39 years, I can tell you there is no need to run the ridiculously expensive MoPar DEF. It is not a requirement of the manufacturer. It may be “recommended” in the owner’s manual, but they want to sell you their expensive brand. Anything in a box, including the Blue DEF you find at auto parts stores is more expensive than filling your DEF tank at a gas station that offers bulk DEF, such as many Flying J’s, Love’s, TA’s, etc. I have a 2016 2500 Cummins, never used MoPar DEF and never would. Best price you can usually find on the box of Blue DEF is between $11.99 and $12.99 for the 2.5 gallon box. That’s roughly $4.80 to $5.20 per gallon. Bulk DEF at the stations mentioned above runs about $2.89 per gallon. Pretty significant savings and way more convenient to fill up your DEF tank at the same time you are filling your fuel tank. No hauling the boxes around, no spilling the fluid on your shiny new truck and no box to dispose of.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 09-06-2018, 08:15 AM   #6
1971 27' Overlander
Kansas City , Kansas
I'll second the above post. Having worked as a cummins tech for years there was never a mention of what type of DEF people should be putting In their vehicles. DEF is basically urea and water. It gets injected into an exhaust catalyst and reduces nitros oxide.
Shermy1987 is offline   Reply With Quote
Old 09-06-2018, 01:05 PM   #7
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
The engine coolant temperature in my 2009 Dodge Cummins rarely gets over 200 degrees when pulling the steepest grades. It is nice to have a well designed cooling system.
DEF - My truck is outside of the years that use DEF fluid. From my reading I think the biggest issue with DEF is that heat can shorten the shelf life and can go bad.
Here are two good forums for your pickup.
https://www.turbodieselregister.com/forums/
https://www.cumminsforum.com/forum/
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-06-2018, 02:02 PM   #8
Hans627's Avatar
Thanks for the input, suggestions and links.
The other day I drive thru a truck stop with diesel and DEF at the pump. I could not figure out how to activate it. The pump did not take credit cards. But I didn't take the time to figure it out as I was there to weight the truck.
Do others use the truck stops for fueling and DEF?
Old 09-06-2018, 02:23 PM   #9
SilverWind's Avatar
1968 17' Caravel
My RAM/Mopar parts guy showed me the chart posted in their parts room that indicated the maximum storage temperature for DEF. 85 degrees F is the max. My dealer is careful about storing it below 85.
I've seen fuel stations/quick stops with their DEF stock stacked in their front windows, in the sun.
My 2005 RAM/Sprinter diesel (non-DEF) went into limp home mode twice. It's no picnic. I'm perfectly willing to pay MoPar's price and potentially avoid a delayed trip and the consequences of costly repairs.
Old 09-06-2018, 03:14 PM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I've never used a DEF pump while traveling so can't speak for them but when at home I fill up at a local place that has DEF at the pump and it works easily. I pump the diesel fuel first then after the spout is secured I access the DEF spout and fill up. Can't use them both at the same time. A full tank is good for more than 5000 miles in my Ford F-350 and if I need more then I'd pick up some and add it myself.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-06-2018, 03:57 PM   #11
1971 27' Overlander
The trouble with emissions systems on modern Diesel's is that they fail. Repairing emission related failures is a daily occurrence in a modern shop. It's something you have to accept when you buy a modern diesel.
If you're traveling long distances often, then having a code reader that will reset emissions faults is a handy tool to get you out of a de rate situation. Avoiding idle time is another big saver to the health of your DPF, which is another source of the most common emissions failure.
Old 09-06-2018, 08:31 PM   #12
1965 24' Tradewind
Chestertown , Maryland
Without a load on the hitch or in the bed your Cummins is just loafing along hardly working and generating no real heat. Towing heavy you can see the temp slightly move and the fan clutch kick in. The oil pressure in my 2011 is a little bit above 40psi all the time. It never seems to move! I have towed lots of miles with my Ram 2500 and LOVE it. The airstream isn't there when towing it's so light :-)
jcslocum is offline   Reply With Quote
1993 airstream diesel pusher motorhome cummins engine eBay Watch Airstreams on eBay 0 05-18-2013 12:50 PM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
Cummins Diesel Upgrade to Classic MH Wayne Olson Classic Motorhomes 99 01-26-2008 05:59 PM
