This is an interesting discussion, but it feels to me like it’s getting unnecessarily complicated. Payload capacity is calculated by subtracting your truck’s curb weight from the Gross Vehicle Weight Rating (GVWR). Trucks with many options (4x4, sunroof, etc.) have a higher curb weight than trucks with fewer options, and therefore a lower payload capacity, assuming the GVWR is equal.
GVWR is set by the manufacturer, and it generally reflects the component in the vehicle with the lowest weight rating. This is typically the weight rating of the axles or tires.
The use of a weight distribution hitch doesn’t change the payload capacity at all, it simply transfers some of the weight from the rear axle to the front axle. Payload ratings for trucks don’t specify how or where the load is placed in the vehicle, they only specify the total payload. If you use a WDH, you’re actually reducing your payload capacity as mentioned above because most WDH systems are quite heavy. Mine weighs 79 lbs. The benefits of the WDH are: improved handling and stability, improved steering, and improved braking because of better load distribution to the front axle.
One thing that confuses this discussion is the fact that manufacturers often publish different maximum tongue weight limits to reflect the use of a WDH. For example, my truck has a 700 lb. tongue weight limit without a WDH, but a 1,250 lb. tongue weight limit with a WDH. This doesn’t mean that the WDH magically adds 550 lbs. of payload capacity, It simply allows for a heavier trailer tongue weight because some of that weight shifts to the front axle.
There are some folks who are comfortable exceeding their vehicle’s published GVWR if they are below the maximum axle rating for each axle. For example, my truck’s axle rating (front and rear) is 3,950 lbs. In theory, my truck could be loaded and balanced in such a way that I put 3,900 lbs. on each axle, for a gross vehicle weight of 7,800 lbs. This would be a scenario where I’m below the maximum axle weight limits for my vehicle, but I’m exceeding my vehicle’s GVWR of 7,200 lbs. by 600 lbs. Personally, I’m not comfortable with this scenario.
Good luck with your research on this topic. It can get confusing and it’s sometimes hard to find the information you need, but it’s out there.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
