Old 05-09-2019, 01:54 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
CAT Scales: Same trailer weight regardless of tow vehicle?
Would I get the same gross trailer weight on a CAT scale with two different tow vehicles? Is there anything with TV or trailer setup that might cause different weight readings of the trailer? The trailer would be loaded exactly the same in each instance.
I'm currently towing my 68 Caravel with a RAM 2500 without a weight distribution system. I'd like to also tow it with our Jeep Grand Cherokee but need to get a gross trailer weight in order to select the appropriate weight distribution system for the Jeep.
It's a 100 mile round trip to the CAT scales and I'd prefer to tow it on that route with the RAM.
SilverWind is offline   Reply With Quote
Old 05-09-2019, 02:12 PM   #2
2020 Classic 33 on order
Box Elder , South Dakota
If the hitch height when connected to either vehicle is the same then the weight you measure on the axles at the CAT scale would be the same since you don't have WDH setup.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 05-09-2019, 02:16 PM   #3
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
It should be the same for a single axle trailer +/- 20 lbs which is the accuracy of the CAT scale. But you should unhitch the trailer and put the tongue down on the scale to get the trailer gross weight. You can also weigh the tongue separately at home using the bathroom scale method if you don't want to fuss with unhitching at the CAT scale. Add the tongue weight to the axle weight to get the gross weight.
out of sight is offline   Reply With Quote
Old 05-09-2019, 02:30 PM   #4
SilverWind's Avatar
1968 17' Caravel
Makes perfect sense. I've got a tongue weight with a Sherline scales. So it sounds like the trailer's axle weight is all I need to get at the CAT scales.
Old 05-09-2019, 02:32 PM   #5
SilverWind's Avatar
1968 17' Caravel
I understand that CAT scales are certified by their manufacturer. How reliable are non-CAT scales found at truck stops?
Old 05-09-2019, 04:40 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I can't say definitively in California, but in Texas commercial scales are subject to inspection by a division of the Dept. of Agriculture, so they're all certified.
Drive the truck+trailer combination onto the scale, weigh them together. Since you're not trying to dial in weight-distribution at this point, you can pull off the scale, unhitch the trailer and drive the truck alone across the scales and the difference in those 2 is the total gross weight of your trailer. The difference between its total weight and the weight of the trailer axle on the scale when hitched is the tongue weight, to give you an idea for your initial setup of weight distribution for the Jeep.
— David
CAT Scales and weight distribution Ponyfvr Towing, Tow Vehicles & Hitches 50 07-06-2017 04:15 PM
Calculating Tongue Weight at the CAT scales? SteveSueMac Hitches, Couplers & Balls 39 03-23-2017 06:44 AM
visited CAT scales - the numbers are in... 2airishuman Towing, Tow Vehicles & Hitches 143 08-23-2015 03:55 PM
results of CAT Scales and WD hitch adjustments funkill Hitches, Couplers & Balls 10 07-11-2009 07:35 PM
