Old 03-08-2020, 08:23 AM   #21
2018 30' Flying Cloud
New Hudson , Michigan
This is exactly what I'm looking for, do you have a parts list for the Yakima parts by chance?
ekbruster is offline   Reply With Quote
Old 03-08-2020, 08:23 PM   #22
Huntsville , Alabama
The compatible accessories for the RetraxPRO XR can be found in the link below:
https://retrax.com/images/RX_XR-Seri...hart_Final.pdf
143pm is offline   Reply With Quote
Old 03-11-2020, 09:50 AM   #23
@harstadventures
hakstad's Avatar
2015 30' FB FC Bunk
Crestview , Florida
I went with the Undercover Ridgelander cover with Rhino Racks, and it's been awesome! Tracks, racks and cover all can be individually removed. I upgraded to the 90psi struts and even though its not recommended, it can still lift with bikes attached, depending on how heavy bikes and gear are I suppose. They have all sorts of add-ons for these tracks too, like a sun canopy/awning for example, which will be my next add-on. This is best pic i could find, I guess i don't have any close-ups.
https://undercoverinfo.com/undercover-ridgelander
hakstad is offline   Reply With Quote
Old 03-11-2020, 10:34 AM   #24
Boulder , Colorado
Can you tell me who made the racks? Thanks
Bkeller is offline   Reply With Quote
Old 03-11-2020, 11:58 AM   #25
2015 30' International
Escondido , CA
MAX Modular UTILITY RACK for TONNEAU COVERS (URTC), Fits All Trucks
I have the Fold-A-Cover folding tonneau cover on my RAM 2500 and there is no room for side rails to be installed. the MAX Modular system will install under the rack mounts and allow the cover to open normally.
https://www.max-modular.com/shop-max...tonneau-covers
dsatwork is offline   Reply With Quote
Old 03-11-2020, 12:11 PM   #26
2019 30' Classic
Belleville , Illinois
I agree with JMitchell in adding a hitch to the front of the truck. Makes for very easy mounting/dismounting bikes. Mine does not interfere with the front camera nor does it adversely affect the lights.
Presitla99 is offline   Reply With Quote
Old 03-11-2020, 12:52 PM   #27
Trekbiker
Boonville , Missouri
Bike carrier over truck bed
You might check out Pace Edwards Full Metal Rabbit. I is a rollup, rails with T slots. We used it with Thule equipment and liked it a lot. A bit expensive, but worth it to us.
I would post photos, I'm new at this and haven't figured that out yet.
trekbiker is offline   Reply With Quote
Old 03-11-2020, 03:59 PM   #28
2010 25' FB International
Livermore , California
I think your fold-up tonneau cover won't work with a bike rack installed. I use a Pace Edwards Ultra Groove retractable tonneau with Thule rack, but Yakima makes towers to fit this cover too.
ID:	363082   Click image for larger version
MotoMannequin is offline   Reply With Quote
Old 03-11-2020, 04:22 PM   #29
2000 19' Bambi
BOZEMAN , Montana
Adarac, BaK Roll-X, Thule Combo
For what it's worth here's what we did:
Bak Industries Roll-X Tonneau Cover
Adarac Truck Rack
Thule - Bars, Ski Rack, and Bike Racks
Superstrut 6" Powder coated lengths to act as blocks for Thule foot attachments
Amazon ordered Kayak carriers
This setup gives me the ability to switch from Bikes to Skis to Kayaks and certain combinations of each. The Adarac system mounts to the truck's stake pockets and is rock solid. We've been using this system for 5 years with no issues.
ID:	363084   Click image for larger version
BobBozeman is offline   Reply With Quote
Old 03-11-2020, 06:10 PM   #30
2018 27' Flying Cloud
Carnation , Washington
Over the past 8 years we have been using a roll up cover from Truck Covers USA with an integrated Yakima rail system. We liked the product line from Truck Covers USA as it gave options including a shallow depth tool box with minimal intrusion into the truck bed.
The Yakima rails let you mount or carry just about anything. We elected to load up 4 bicycles using Whispbars, Forklifts, and Wheelhouses on our F150 SuperCrew short bed.
When we are not traveling there are 4 detach points and the bars/mounts all come off in one piece. They fold down for easy storage on the garage wall giving us full access to the truck bed.
Timberock is offline   Reply With Quote
Old 03-12-2020, 05:36 AM   #31
2017 19' Flying Cloud
Calgary , Alberta
This is what i’ve been considering. How wide will the cover open in order to access the front of the bed?
Ronyx is offline   Reply With Quote
Old 03-12-2020, 06:29 AM   #32
2016 30' International
redondo beach , California
Our bikes weigh 50 lbs each. The Yakima rack is rated at 50 lbs. So we used four cross bars not two. This gives the bikes a very solid platform and they don't sway anymore while off road.
ID:	363113   Click image for larger version
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 03-12-2020, 04:40 PM   #33
L.D.Clara's Avatar
2015 20' Flying Cloud
Brandon , Manitoba
I have a tri-fold cover on my f150, and no rails of any sort for anything to lock into. I looked but couldn’t find a commercial solution - I would’ve probably bought it if I did as I was under the gun to come up with something before a trip.
Ended up buying a couple of fork mounts on a popular online rainforest retailer and $50 worth of steel. A couple of hours cutting and learning how to stick weld and o came up with this.
Can’t open the lid with it on and it very effectively secures what’s in the box. Took our bikes all the way from the Canadian prairies to Oregon and back with no issues.
I can take more pictures if anyone else wants to build their own..
Rob.
L.D.Clara is offline   Reply With Quote
Old 03-12-2020, 04:45 PM   #34
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Originally Posted by jmitchell View Post
There are also advantages to the bed rails, and cons with the front mount. It is obviously not a good fit for everyone, but I thought I'd share our experience.
I guess reduction in airflow to the TV and the ugly views on a long trip would be a negative
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
Ultraclassic is offline   Reply With Quote
Old 03-12-2020, 05:56 PM   #35
DougnJanet's Avatar
2013 23' FB Flying Cloud
Kennewick , Washington
Originally Posted by dmslawson View Post
I carry several recumbent trikes on my Thule rack system. Added a cargo carrier as well . . . all of which is below the height of the truck cab. Works great.
dmslawson, do you have any pictures you can post showing how you load your recumbent trikes on your Thule system. Thanks.
DougnJanet is offline   Reply With Quote
Old 03-12-2020, 07:44 PM   #36
2005 25' International CCD
Oak Ridge , Tennessee
After a lot of research a couple of years ago, I went with a USA Truck Covers rollup bed cover with an integrated Yakima rail system for my new 2017 truck. I then bought the Yakima crossbars and bike racks. It was a bit pricy, but definitely worth it. I'll post pics of you want. This system works out great for us. At the time only two companies offered the roll up cover with the rails, but there could be more offerings now.
billhenry58 is offline   Reply With Quote
Old 03-13-2020, 08:58 AM   #37
@harstadventures
hakstad's Avatar
2015 30' FB FC Bunk
Crestview , Florida
This lifts exactly 2 ft from top of the bed to bottom of the cover. Here's a couple more pics with it open. Make sure to ask for the upgraded 90PSI struts if you get it. Otherwise you get by default 40PSI if I recall correctly, which wasn't even enough to hold cover up with my 2 bike racks and basket empty.
Old 03-15-2020, 01:41 PM   #38
Port Allen , Louisiana
I recently purchased a set of crossbars for the retrax pro cover. I have Yakima bars with Yakima bike tracks that leaves the tires on. I am set up for three bikes. About three weeks after purchase I totaled out the truck but racks were not on the truck. I would be willing to sell if anyone is interested. I can be contacted at 225-603-9249
JohnnyCash is offline   Reply With Quote
Old 04-20-2020, 10:48 PM   #39
2020 23' International
Kansas City , Missouri
Yet another option for racks over tonneaus.
https://realtruck.com/p/elevate-rack-system/
Mack1 is offline   Reply With Quote
Old 06-03-2020, 03:50 PM   #40
Thanks for all the feedback guys! Ended up going with the retrax cover and the Thule compatible system. The bike mounts themselves were reused from my previous vehicle!
ID:	369324   Click image for larger version
Safari 25 Twin Bed-over bed cabinet falling down Snowback General Repair Forum 0 02-23-2019 09:05 AM
Bike & kayak rack over TV bed wareaglewalt Tow Vehicles 10 08-21-2018 10:58 AM
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
