09-28-2015, 04:03 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Barely got 110,000 miles out of these brake pads after towing with my half to...
I barely got 110,000 miles out of these brake pads after towing with my 1/2 ton, why do these wear so quickly?
Brevi tempore!
09-28-2015, 04:23 PM
1981 31' Excella II
New Market
, Alabama
They don't even look worn out.
Perry
09-28-2015, 04:38 PM
1994 30' Excella
Mississauga
, Ontario
sounds like you have a heavy foot on the brake! Ha Ha.
Al and Jean
TAC ON-3
09-28-2015, 06:48 PM
1979 23' Safari
Wayland
, New York
110k on brake pads sounds pretty good.
09-28-2015, 06:52 PM
2005 31' Classic
Garner,
, North Carolina
that is unheard of.. 100 k on brake pads pulling a trailer.. either you see stop lights for miles ahead and let off the gas or your trailer brakes are wearing out after 10K miles..
It hard to do that on a car much less a truck. good one.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
09-28-2015, 06:56 PM
Remember, Safety Third
Catfish Corners
, Georgia
I had a 1990 Ford Ranger that I put 120k on without ever changing the pads. Only thing I ever replaced was the muffler on that truck. Sends most folks' BS meter into the red zone when I tell them that story. All truth.
09-28-2015, 08:08 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I pulled my trailer with a 97 Ford 150 a couple of times. I had to change the front rotors after each time. Do you live in flat land?
09-28-2015, 08:37 PM
1972 31' Sovereign
Benton
, Arkansas
Lots of miles between AR, NM, and AZ.
The biggest grade I have navigated (several times now) is a fairly long 8%er south of Globe AZ on hwy 77.
I do like to feel my trailer brakes at every stop. Those brakes came on the truck, I took them off today with 118,000 miles, I think I might have been able to squeeze another 20,000 out of them.
The trick is, in my opinion of course, to avoid hard stops and to go down a hill at a speed that only requires intermittent, fairly light, and brief brake applications. It is all about pace and anticipating what is coming next.
Brevi tempore!
09-28-2015, 09:26 PM
Madison
, Alabama
I replaced the brake pads on my Excursion @ 125,000 but it was preventative maintenance. Big Ford trucks have good brakes, but I don't use them much. Sadly, I had to replace the front calipers at 132,000 miles in Pensacola this winter, as the front was pulling when I applied the brakes. New pads were still good, so they are now in the new calipers.
Let's Roll !
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
09-28-2015, 10:43 PM
1999 34' Excella
Hillsboro
Yeah, I use normal deceleration and engine braking a lot.
Also, proper "break in" of the new brakes are KEY to longevity!!!
Peace and Blessings..
Channing
WBCCI# 30676
09-29-2015, 03:44 AM
1967 17' Caravel
Oak Creek
I'm due for brakes on my car. What is proper break in?
I'd love them to last longer than they do.
09-29-2015, 03:57 AM
Lin
, Ne
5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. If you're forced to stop, either shift into neutral or give room in front so you can allow the vehicle to roll slightly while waiting for the light. The rotors will be very hot and holding down the brake pedal will allow the pad to create an imprint on the rotor. This is where the judder can originate from.Then do 5 moderate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot.After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure.After the brakes have cooled to standard operating temperature, you may use the brakes normally.
09-29-2015, 06:34 AM
1972 31' Sovereign
Benton
, Arkansas
Many years ago my Uncle Billy told me the way he would break stuff in.....
Upon starting break in, drive it just like you are going to drive it, proceed with this procedure for the life of the vehicle.
This has been working for me for about 35 years now.
If a person goes through a lot of brake pads;
A. The car is driven hard with lots of hard braking.
B. The pads used are not very good.
C. The car is driven hard with lots of hard braking.
If a person often sees lots of black dust on their front wheels see A and C above.
Brevi tempore!
09-29-2015, 10:16 AM
1999 34' Excella
Hillsboro
Yup... see above!
http://www.ehow.com/how_7518438_brea...rake-pads.html
and as mentioned above:
http://www.powerstop.com/brake-pad-break-in-procedure/
Now, I do this all 'in the country'... I once lived in the country but the 'city' has 'improved' around me... so, it takes a little drive to get there...
I 'brake' using downshifting... coasting to stops (really upsets the Hybrid drivers behind me)...
I use the 'brakes' mildly then NEVer hold the car with them until break in complete. I use the clutch/ shift in/out of gear..
Once in the country, I proceed as above.. then drive at a moderate speed to cool the brakes.. then repeat the process...
The whole process is to 'transfer' brake pad material to the disc, then allow heating/cooling of the parts.... then cycle it at least 3 times... heat, cool.. repeat.
The brakes will work their best from now on...
NOTE.. when/if you have a 'hard/panic' stop, try to heat then cool the brakes again so that you 'balance' the brake material across the disc.
Channing
WBCCI# 30676
09-29-2015, 11:15 AM
1977 31' Sovereign
Lynnwood
It's all about friction material, Bro - asbestos. I'll bet a month's pay your replacement pads won't least nearly as long.
Tom
09-29-2015, 11:19 AM
1999 34' Excella
Hillsboro
Tom
Tom.. do the carbon fiber pads also have asbestos?
Channing
WBCCI# 30676
09-29-2015, 03:48 PM
1972 27' Overlander
Penokee
, Kansas
Since we only have 1 stop light working in over 900 sq. miles,,, our brakes last almost 200,000 miles..
Semi truck use to be set up with a brake pressure gauge to see how much pressure you were putting on them.. Up to 20% all you do is transfer the braking action to heat,., ANything over 20%,, you start eating up shoes and drums.. So,, gential pressure on the peddle to slow you down just makes heat.. To shift items in the TV is a sign of over 50% peddle pressure. Speaking of brake life,,, our farm semi has almost 400,000 miles on a set of shoes..
As for gas MPG... I have found with my Bully Dog gauge for my Dodge pu,,, I can gain almost 2 more MPG by coasting as much as possible ahead of a stop light or stop sign.. One does not gain that much time racing to the light,, then slamming on the brakes..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
09-29-2015, 04:04 PM
2013 30' Classic
Greenwood
, Mississippi
110,000 on a set of brake pads demonstrates good driving habits-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-29-2015, 04:24 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Sodbust, your 1 stop light in 900 miles made me laugh. When your in the city seems like you have 900 in 1 mile. Looked up Penokee on Google Earth, you're out there a bit. Pretty country.
Hittenstiehl
09-29-2015, 08:29 PM
Dan and Lynda
2012 28' International
Bremerton
110K towing, they look great. My 2500 HD brakes are doing great at 65K, however when I tow I use the engine brake on the diesel engine to provide significant assistance when slowing down.
