RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-27-2020, 06:35 PM   #201
2018 25' International
Slidell , Louisiana
Originally Posted by CanyonMan View Post
OK, while my semi example may have been, according to you a "fallacy, how about 5th wheels, if that is more to your liking. How many trucks outweigh even the lightest and smallest 5er's? Are we to believe that they are all unsafe and should be banned from the road? Your premise does not hold water for so many reasons regarding tow vehicle weight to trailer wight ratio. Your assumption of less than 1:1 would leave many RVer's without a trailer. Even my 6K# trailer outweighs my 1/2 ton PU by ~300#
The rational observer would note the hitch location is different and would correctly conclude the formulation is different. Single wheels add 30-50% capacity, dual wheels nearly 100%. The eight wheeled semi-tractors quite a bit more still. The game changer is hitch location. A full explanation would be quite complex and drawn out.
Brian
Old 10-27-2020, 07:21 PM   #202
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Originally Posted by jcl View Post
Thanks for that. I just knew Ford and RAM. I see for the 1500, they allow up to 7000 lbs without WD, 2000 lbs more than Ford, and similar to many SUVs under discussion, at 7700 lbs. For the HD models, if it is not required, why do they list a FALR figure? Do they recommend but not require it?
There is no commentary about this in the owner's manual, so here is my best guess: As trailer-towing prowess increases, you can now tow something that's approaching 3x the weight of the truck. To minimize oversteer and reduce the risk of jackknife, they don't want too much weight removed from the drive axle.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 10-27-2020, 07:27 PM   #203
jaybauman's Avatar
Katy , Texas
Originally Posted by DewTheDew View Post
BMW sold 10,000 more X5's in the US in 2019 than they did in all of Europe according to carsalesbase.com I am pretty sure the German engineers have been here. Pretty sure they tailor vehicles for here. Not sure if you are aware but X5s are BUILT IN THE USA. To claim that these people are ignorant and dismissive of our huge market is pretty bold and I would want some backup on that.
Our primary vehicle when not towing the Airstream is a 2017 BMW X5 x35d. As for power and fun, this vehicle has it all. As for "tailored for here", there is a lot to be desired. The air conditioning is insufficient for the hot, muggy summers here along the Gulf Coast. If the German engineers understood the climate here, they would have added a bit more oomph to the AC. Every single one of my US- or Japanese-based vehicles have fared quite well down here. Even VW has adequate cooling. My X5, not so much. Can't wait to get rid of this thing. Just a bad job on engineering the cabin design.
Old 10-27-2020, 08:40 PM   #204
jcl
Vancouver , British Columbia
You have discussed this 2005 example. This is 2020. Has it occurred to you that they have thought about it and do not want you to do this rather than just being ignorant after more than 15 years of building X5's in the US? You think no one has told them about WD hitches in all this time while they were in South Carolina? If I thought the BMW engineers were that stupid I'd never have bought one in the first place.
My second paragraph wasn’t about BMW, that was another German manufacturer.
I am familiar with the X5 through the E53, E70, and F15 models up through 2018. That most recent model used a detachable hitch that was not usable with WD. Apparently they didn’t learn in the ensuing 19 years after they introduced the E53. Of course they knew about WD. They ignored it, and many other towing issues as well. If you look at the 2020 models on line, not just the X model, the vast majority have no BMW hitch offering at all in North America, nor a tow rating. Despite BMW offering both outside North America.
They aren’t stupid at all, that is your phrase. They just don’t bother. And it isn’t about where the vehicles are built. My X3 was built in Austria by a contract manufacturer, not by BMW. The manufacturer was owned by a Canadian company. But the vehicle wasn’t designed in Canada or Austria, rather Germany.
jcl is online now   Reply With Quote
Old 10-27-2020, 08:46 PM   #205
jcl
Never had a cabin cooling issue. Sometimes a heat issue at -35. Maybe the engineers were closer to Finland than the south. How did those cupholders work for you, were they tailored to North American tastes? Ours didn't hold anything larger than a small paper cup, not that we minded that much.
Old 10-27-2020, 09:06 PM   #206
jaybauman's Avatar
Katy , Texas
I was going to ask if -35 was Fahrenheit or Celsius, but they're nearly identical in that range!
The cupholders are as useless as on a boar. I've considered bringing along my Camelback for longer trips.
Old 10-27-2020, 10:33 PM   #207
Mountain View , California
I read probably over 10k posts over bimmerfest and xoutpost and I do not recall people complaining about AC in X5. Maybe your vehicle needs some kind of fix.
bono is offline   Reply With Quote
Old 10-27-2020, 10:39 PM   #208
I am perfectly aware that current X models are manufactured only in the US. It does not change the fact that these vehicles are designed in Germany.
I understand that it is difficult to comprehend that Germans do not car about Americans towing with BMWs. I guess this is not intuitive as truck manufacturers are in the race to add lbs to towing capacity.
The reason why BMW do not care is that Americans are not interested in towing with BMW. Therefore, BMW do not bother to make an effort to properly set up their vehicles for towing in the US. It was said many times - they do not even offer hitch option in the US for majority of the cars, which are commonly used for towing in the rest of the world.
Old 10-27-2020, 11:28 PM   #209
jcl
LOL. I have driven in -46 C, but the X5 only saw -35C. The X3 saw -30C. Both tended to ice the interior of the windows as the vehicles didn't produce enough heat. On the Explorers and Expeditions I had to run winter fronts at those temperatures, so maybe I should be grateful for small mercies.
I always thought the cupholders were a joke, I just never cared about cupholders that much. Certainly they were a frequent lament on BMW boards as not being appropriate for North American tastes.
Old 10-28-2020, 04:56 AM   #210
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
They do not set it up nor do they test it. Therefore all these "it works for me" people are playing with fire. Perhaps you like playing with fire, but I do not. I lived in Germany and worked with quite a few German engineers (including some in the auto industry). They are very cognizant of the US market. Most have probably spent time in this country. I don't think they don't care so much as they think it is silly to use an X5 to tow in the USA when we have far better vehicles available here that are far more suited to the task. Just my guess based on my interactions from my time there.
DewTheDew is offline   Reply With Quote
Old 10-28-2020, 08:11 AM   #211
Midland , Georgia
Originally Posted by milesinmyles View Post
I can say they do and for the obvious safety reasons we read so much about. But I can share a personal experience with my 2019 F150. I usually run pretty close or at payload capacity pulling my 2019 Globetrotter. On one of my longer trips I made plans to pull over and sleep for a couple of nights at Gander, Walmart, etc. As a result I my grey, black and fresh water tanks were pretty full. Then I fueled up my 36 gallon gas tank. After 5 miles on I95 in SC every sensor in the truck malfunctioned; Pre-Collision, Hill Start Assist, Parking Aid, etc. No cruise control and no Tow mode either. Coincidentally, I went to Cat Scales for first time and was 600 pounds over payload! Lots of water weight. The next day all was OK. Mmmm. Tanks are now empty. Ford dealer was useless. Actually more than useless. 7K miles of towing have passed, I now manage my payload much more carefully, the Cat Scales are my good friend, and have never had this problem with the truck again. Coincidence? Maybe, maybe not.
Do I hear the X Files theme song in the background?
ForteePlus is offline   Reply With Quote
Old 10-28-2020, 08:32 AM   #212
jaybauman's Avatar
Katy , Texas
Had it back to the dealer a few times for this issue alone. (Aside: Other than scheduled PM visits, this is the only thing that I have brought it in for.). I've demoed other 2017 and 2018 X5s in the heat of August, and they all behaved the same way.
The last time I was in for this, the dealership GM tried to get me to upgrade to the newly-refreshed model. When I reminded him of my AC challenges, he replied "Oh, they fixed that with the new body style." I honestly don't know if he is aware that the X5 has an under-cooled cabin problem that has indeed been fixed, or he is just saying what I want to hear so I will purchase a new XUV from him. In the end, my wife wants to go back to a Yukon XL (with amazing air conditioning!) so we'll be selling the Bimmer when GM's supply catches up.
Old 10-28-2020, 09:34 AM   #213
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Jay
"GM recommends no WD for 2500HD/3500HD models, up to the maximum towing capacity."
I think you read or interpreted the chart you posted wrong. I do not take "not required" along with a "50%" redistribution as "reccomends no". Just that is not required. But I certainly see no reccomendation against useing the hitch with WD.
Old 10-28-2020, 10:27 AM   #214
Ravenna , Ohio
One feature I do not hear discussed is the ability to do an emergency stop without having the TT and TV jacknife or for the combination to take so long to stop that the TV ended up driving right over the car that stopped a hundred feet sooner than you could. We have all seen the TV ad showing a P/U pulling a 747 but where is the video showing stopping distance? Car company engineers do have to consider the Federal Safety regulations even if the end user does not.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA across the US. Perry, GA in March 2021.
Tireman9 is offline   Reply With Quote
Old 10-28-2020, 10:35 AM   #215
jaybauman's Avatar
Katy , Texas
Originally Posted by Bill M. View Post
Jay
"Not Required" is a strong indicator of you-don't-need-to-do-it-with-this-truck. It's clearly stated in black and white.
Indeed, I do use weight distribution on my 3500HD. But since it's not exactly required for towing within vehicle design parameters, I have experimented over the range of 0% to ~75% FALR. For my rig, there is a sweet spot at ~25% that gives the nicest ride.
Personally, I interpret the GM direction as "You don't really need any WD on this truck; but if you do want to, don't go higher than 25% FALR".
PS GM states 25% FALR for the 2500HD/3500HD, not the 50% that you mention above.
Old 10-28-2020, 10:50 AM   #216
waninae39's Avatar
2017 22' Sport
NCR , Ontario
In the auto industry , engineers do the design. But marking defines the parameters.
IE marketing tells the engineer what they need to design for.
some the design look the same, some markets get slightly to major differences.
ie BMW cars in NA have much larger engines than those in EURO. Most EU countries have high taxes for autos with > 2L engines.
In the UK, the most common engines are 1.4 L and 1.2 L. In NA, those small engines are very hard to no possible to order. Thus the brakes change also to accommodate engine size.
Its not that Eu engineers are dumb or don't know, they are told what to design for.
Its also their job to keep costs down, thus why would they design in a feature that adds weight and cost when their bosses did not ask for it.
waninae39 is offline   Reply With Quote
Old 10-28-2020, 11:00 AM   #217
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
If you want to know the TV GVWR when towing, is it with WD or W/O WD?
What if your good with TV GVWR and over GCWR.
"I prefer someone who burns the flag and then wraps themselves up in the Constitution over someone who burns the Constitution and then wraps themselves up in the flag.
― Molly Ivins
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 10-28-2020, 02:29 PM   #218
dznf0g's Avatar
Oswego , Illinois
1) with WD applied
2) since gcwr is about powertrain and braking more than vertical load, you could be taxing either. Good, and properly adjusted trailer brakes largely take care of the stopping. Powertrain components could be overloaded and temps ( coolant, trans, rear end) could be elevated.
-Rich-
Old 10-28-2020, 04:28 PM   #219
Just curious, the old Burb has always had 580 to spare when towing with a full load. ####'s👍
― Molly Ivins
Tahawus
Old 10-29-2020, 06:18 PM   #220
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Since the 2007 Mercedes ML320 CDI 3.0L turbo diesel reached 205,000 miles and waa exhibiting the issues related to a reoccurring $3500 repair every 75,000 miles not mentioned in the sales literature, it was sold.
The Ram 2500HD Cummins already had the Hensley Arrow stinger left over from towing the 2013 25FB International Serenity. Thus it is no big deal to tow the 2015 23D International Serenity. I was able to remove then Tekonsha Prodigy RF brake controller and now use the Tuson brake controller for both the 31' Classic and the 23D.
I played with all of the numbers and the only SUV Toyota that was a reasonable tow vehicle by the numbers is the Sequoia (the more expensive Land Cruiser has the necessary towing numbers but not the air suspension of the top model Sequoia).
I am not sure the Sequoia would get the same mpg with the 5.7L V8 gasoline engine as the Ram gets with the 6.7L Cummins diesel.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
New axles - they're here, and they will require... drboyd Axles 34 07-17-2016 01:55 PM
New Tires - got Load Range E instead of Load Range D Hyperion 2009-2015 Flying Cloud 49 06-08-2016 07:47 PM
Show Your Tire & Load Info (Payload) Label KJRitchie Towing, Tow Vehicles & Hitches 12 02-12-2015 10:10 AM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 10:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 08:36 AM
