10-24-2020, 06:04 PM
#21
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
[QUOTE=Mr. Merk;2425526]My wife's coworker had this on his new F250 and they couldn't fix it. They bought it back and he's now in a modified 6.2 Sierra Denali half ton.[QUOTE]
Everyone seems to have a story about their brother-in-law’s second cousin.....
I’m at a rally now....200 rigs. LOTS of Ford Superduty’s here. It’s probably the most prevalent tow vehicle here. They didn’t all “death wobble” their way in.
The fix is an upgraded steering damper and making sure all front end components are tight.
If you want to go further than that there’s a place here in GA (powerstrokehelp.com) that has a mod that involves changing the caster angle along with steering dampers.
There are probably millions of 4wd Superduties on the road. You can find something wrong with any make or model if you look hard enough.
10-24-2020, 06:15 PM
#22
2018 25' International
Slidell
, Louisiana
Originally Posted by RivetED
The only mistake I made with both of my 3/4 ton pick-ups was not getting an OEM anti-sway bar installed on the rear. I've had the ASB added after market on each. They don't add stiffness to the ride, they only help stabilize the truck from leaning in turns.
For me it's a world of difference especially with a near capacity loaded bed.
With either a 3/4 or 1 ton diesel I don't think you can go too wrong.
They certainly do exactly what you say, but they dramatically contribute to oversteer when towing at the upper limits so if you are towing a 30' or more trailer, a rear sway bar is not a good option. This is why they are not on the truck from the factory..
10-25-2020, 08:11 AM
#23
Del Mar
Thoughts on a F350 with a Tremor package towing a GT 27FB? Is that much 4x4 going to degrade the towing experience a lot? It’s rated to tow 15,000 lbs.
10-25-2020, 08:41 AM
#24
2007 25' Safari
Rogers
, AR
If the shoe fits, right? The 27FB isn't even close to 15k. Tow it and then go wheeling!
2007 Airstream 25FB Safari LS - GY Endurance Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison
2008 Porsche Cayenne Turbo 500hp/516lb-ft
2014 Porsche Cayenne Turbo S 550hp/553tq
2005 GMC Sierra Crew Cab 5.3L built 4L60e, 40k Tru-cool
10-25-2020, 09:27 AM
#25
Slidell
, Louisiana
Yeah the softer springs with greater travel are less than ideal for towing. It allows the WD tension to put more strain on the trailer and provides for a less comfortable ride. Does not change safety or capability by much. So if these things don't bother you much or if the trade off is worth it, then the off-road packages may be your better choice.
10-25-2020, 08:52 PM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You mean Whishy Washy up in the air isn't the answer?
Who'd a thunk it.🥴
10-26-2020, 10:50 AM
#27
2007 25' Safari
Rogers
, AR
The truck is no rock crawler, its still a 2500 rated for 15k. It's not going to be a crazy ride.
10-26-2020, 11:36 AM
#28
2018 28' International
Fayetteville
, Georgia
The power train is the same for an F250 or F350. Suspension and axles are different. Check in the State where it will be titled for license cost, insurance cost, etc. It can vary.
brick
2018 International Serenity
Cute wife...
