05-23-2021, 06:05 PM
Woodinville
Airstream Serenity and F150 PowerBoost Hybrid w/Generator - GFI Faults
I am just returning from a 5 day trip with my new F150 and a rented 2016 28' Airstream International Serenity. I bought this truck specifically to power a trailer and rented an Airstream to see if I liked it enough to put out the extra $$$.
Long story short, the F150 would not charge the trailer as it kept triggering a ground fault. It charged fine from my garage without triggering GFI and my truck will power other things, but they won't run together - which made for a very cold dark trip to the beaches in Western Washington. Like dragging a big aluminum tent.
I know that sometimes 2 GFI's in the same circuit will fight one another and trip continuously but the house circuit has a GFI.
Any thoughts/experience with this? Since Ford advertises with Airstream, and vice versa, I would think they would have tested this out and have posted an FAQ.
05-23-2021, 06:48 PM
2019 27' Globetrotter
Salem
, Oregon
You may need a generator bonding plus. Usuall about $10.00 at Camping World, Amazon etc.
The Ford generator may need this.
Dave
05-23-2021, 06:51 PM
2021 30' Flying Cloud
2020 25' International
minneapolis
We’re you physically plugged into one of the outlets mounted in the bed, or were you relying on the 7 pin connector? If 7 pin, that’s probably not any better than any other f150. You need to plug into either the 20amp or larger located in the bed.
- Stewart
05-23-2021, 07:15 PM
2017 23' Flying Cloud
Bartlett
, Tennessee
A bonding plug will definitely trip a GFCI outlet.
Maybe the Airstream was pulling more power than the truck could provide, overloading the circuit.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
05-24-2021, 09:21 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Ok, what's with the bonding plug?
In a normal house, your ground and neutral wires are tied together at one point (usually) in the main breaker box. It's tied at one and only one point so that strange things don't happen and electrocute you.
If you are going to feed your house with a generator, that one point still needs to be the only connection point. A "normal" generator relies on this. It is not set up with the ground and neutral tied together.
An Airstream trailer does *not* have the ground and neutral tied together inside it. It relies on the "bond" being done at the shore power pole or upstream from there. Again, it's done at a single point. It just happens to be outside the trailer.
Hook up a "normal" generator to an AS trailer and there is no connection between ground and neutral. The generator does not have one. The trailer does not have one. This is not a good idea.
A ground fault device looks at the current flowing in the ground and neutral to work out if there is a fault. Part of this logic *assumes* they are connected and that the ground is acting as a safety barrier. With no bond between them, the logic gets very confused.
Plug into a normal home outlet or a shore power post and the ground fault gizmo is happy. There is a neutral to ground connection in the home or the power post. The logic sees what it expects to see. The device operates properly.
Does any of this apply to the F150? Who knows ....
05-24-2021, 09:51 AM
2013 31' Classic
billings
, Montana
Cheaper to carry a 2000 Honda
05-24-2021, 10:44 AM
Woodinville
It was plugged into the Pro Power Generator in teh bed. I tried both the 20 amp and 30 amp circuits.
05-24-2021, 10:46 AM
Woodinville
Thanks - this makes sense. I recall having issues with other GFIs like this in past experience. I'll talk to Ford/Airstream about a solution.
05-24-2021, 10:47 AM
Woodinville
As noted in the original post, I already have the F150 - getting another generator would be more expensive.
05-24-2021, 11:17 AM
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by pnoshawn
I know that sometimes 2 GFIs in the same circuit will fight one another and trip continuously but the house circuit has a GFI.
This could be the problem, it "can" be just certain GFIs that interfere with each other. One pair could interfere with each other, then change either one in the pair and it's fine.
05-26-2021, 12:18 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
All generators 5000w and above a neutral bonded to ground internally. Below 5000W they are not bonded and need external bonding.
guskmg
