Old 01-30-2021, 01:56 PM   #1
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Air Lift Install on 2017 GMC 2500
Was getting close (inside 500lbs) to my rear axle rating of 6,200lbs on my 2017 gmc 2500 when fully loaded with passengers, cargo, tools, camper shell, roof top tent, 30 airstream with propride, water, dogs
Etc.... truck was handling it no problem whatsoever but did not leave for very much suspension travel on the rear axle with the ~3 of squat under heavy but acceptable load (still within all my GAWR limits. Note that these trucks have a lot of rear-end rake, so 3 of squat has the truck essentially sitting dead level vs nose high.
Weight distribution on the propride is great and front axle is 50+% restored (heavy duramax helps keep the front end pinned to the ground too) but I wanted to restore some of the travel on the rear end + keep the headlights on the road a little better.
Note that the only engineering difference between the 2500 and 3500 SRW Duramax on the 2017 MY are higher rated rims, tires and a helper spring on the 1-ton rear axle which provides for another 800lbs of payload or door sticker rear axle rating of 7,000 lbs up from 6,200lbs. Everything else is identical from front to back.
I had already upgraded my tires which are now rated for 7,500 lbs per pair @80psi and threw on some 1-ton spec rated gmc factory rims for good measure. Plus they look better
Went back and forth on adding a helper spring on the rear but in the end decided to go with air bags from air lift instead. Model 88338.
Happy I did, install went smoothly and I can now fine tune the ride quality, sag and suspension travel. Not to mention load up the rear end to 6,200lbs and not bat an eyelash given the equipment I am now running.
Fully aware that legally the door sticker rear axle weight rating is unchanged at 6,200lbs and dont necessarily plan on going past that. Also fully understand that air bags do not replace weight distribution as restoring front axle load is critical on any rig.
Gonna get out and tow this afternoon and see how she goes / mess with system pressure some. I think reducing sag from 3 to 2 will be fine / enough for my needs.
Just happy to have piece of mind that the gear is good to go with tons of overhead at Max weight rating. Duramax is not phased and tugs around all /
Combined 18,000 or so pounds without breaking a sweat up and down and around through the Rocky Mountains here in Colorado.
ID:	387817   Click image for larger version
ID:	387819   Click image for larger version
wulfraat is offline   Reply With Quote
Old 01-30-2021, 02:33 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Poor use of money for me, but I guess not for you,🔥$$$$$$🔥
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 01-30-2021, 02:42 PM   #3
wulfraat's Avatar
Meh. Rims didnt cost anything (swap for my chrome Denali rims), so only $400 bucks for springs. $20-30k less than trading up to a 1-ton haha.
What size drop down for GMC Sierra GMC 2500hd? JJ1 Tow Vehicles 4 11-15-2016 04:50 PM
2015 Chevy 2500 LTZ HD vs GMC 2500 Denali HD Roadtech Tow Vehicles 2 10-21-2014 05:47 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Titan vs GMC 2500 ? Daniel LOUIS Tow Vehicles 18 08-27-2005 02:45 PM
