Old 12-23-2020, 03:19 PM   #21
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Without a brake controller, you had no trailer brakes. Dangerous and illegal.
Richard
azflycaster is online now   Reply With Quote
Old 12-23-2020, 04:25 PM   #22
2018 25' International
Slidell , Louisiana
Originally Posted by Ny3299 View Post
Thank you for the input.
I towed the 22í Bambi without a WDH or sway bar, and without a brake controller and didnít have any issues. I was wondering if I actually benefitted from some trailer braking without the actual controller. I mean, with the 7 pin plug, doesnít that activate the trailer brakes a little bit? And a controller would only enable further adjustment to the vehicle/trailer brake percentages, right? Anyway, I was running 70 mph at 2000 rpms and didnít even feel the trailer. Sway started at slightly higher speeds so 70 was my max for this setup.
No the standard 7 pin controller does not activate the trailer brakes at all.
The controller when present and connected applies about 1 volt to the brake circuit constantly so that it is able to detect that a trailer is present. this is not enough to activate the brakes, then it applies an additional voltage proportional to vehicle deceleration to activate the brakes. You adjust the gain of the controller to increase the degree of proportionality and resulting sensitivity.
Brian
Old 12-23-2020, 06:51 PM   #23
2017 23' Flying Cloud
Bartlett , Tennessee
All the 7 pin connector does is connect the brake controller to the trailer brakes. It provides no other benefit as far as braking is concerned.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is online now   Reply With Quote
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany Tow Vehicles 6 07-03-2017 10:44 PM
Avoiding Chicagoland while towing? EZ-Pass when towing? JustSomeGuy On The Road... 86 04-24-2015 10:33 PM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
