12-24-2020, 10:53 AM
#21
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
"A friend's RAM 1500 Ecodiesel had 910 lbs on the door jamb sticker."
I do not know whether it is true or not but there was once a thread on the forums about Ram having a sensor that recorded any overload and maybe could void the warranty if overloads occurred.
12-24-2020, 11:10 AM
#22
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dodge still a real oxymoron.....Remember the "Dodge Ram"?
Appears they still can't make up their minds.
12-24-2020, 11:29 AM
#23
2017 23' Flying Cloud
Mesquite
, Nevada
https://www.ramtrucks.com/towing/towing-guide.html
Enter Ram VIN @ this website it will give exact payload and towing capacity for specified truck as equipped - Do your research before purchasing - don't believe the salesman (probably doesn't know). I assume all manufacturers have a similar resource.
BTW I intentionally chose a smaller trailer rather than need a 3/4 ton truck.
12-24-2020, 11:41 AM
#24
Salem
, Oregon
Originally Posted by Rrauch
Has anyone added payload capacity to a RAM 1500? Is it possible to modify the suspension to get, say, 500 lbs. additional capacity? The RAM 1500 has a rated payload capacity of about 1,100 lbs. Rather than moving up to a 2500 is there an alternative?
Hi, the only way to add to your payload is to reduce the weight of your vehicle. Removing the bed might save you about 500 lbs. [WAG] Your GVWR cannot be changed. Changing from a large gas tank to the smaller one, on some vehicles, might save you 50 lbs.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-24-2020, 12:23 PM
#25
2015 27' Flying Cloud
Cedar Rapids
, Iowa
Ram 1500
I tow my 27FCFB with a 2019 Ram 1500 4x4 Bighorn Quad Cab Hemi. Door sticker is 1850lbs. I changed the tires to E- Rated and added air bags. I don't haul tons of stuff and seldom drive over 65. Set my Blue Ox hitch at 9 links. Only need to add a little air in the bags to take out 1/2" sag on the back of the truck. Have pulled the trailer about 15,000 miles, mostly in the west, truck is stable and has plenty of power. I have no regrets
12-24-2020, 01:12 PM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
What, the BO can't 'level' the TV?🤔
12-24-2020, 06:32 PM
#27
2012 30' Flying Cloud
Milpitas
Originally Posted by jim6090
I'm so frustrated with my 2020 Ram. Website says payload 1840 lbs for Limited 1500. Thats what i based my purchasing decision. Actual sticker says 1086 lbs. No relief from Ram. They are straight up dishonest on their website.
The quoted payloads from all the mfgs are based on a stripped down version of the truck. Every option you add to the truck adds weight and reduces payload. The top of line the trims generally have the lowest payload numbers. Ford, GM, Ram...all the same. You have to look at the sticker on the truck you are buying to know what the payload is.
John
2012 Flying Cloud 30RB
2015 Ram 2500 Cummins 6.7L
12-24-2020, 06:40 PM
#28
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I am not sure I think all the difference in the payload of different models is due to weight of accessories. I suspect that on some of the trucks that they try to up the fuel economy and there are differences in the engine tune and the tires and gearing and maybe some structural things that reduce payload.
Do pickup trucks count in the corporate fleet average fuel calculation? Do the larger 2500 trucks count? I think so and I think that is what is driving the prices up. And driving the production of trucks that are just open backed cars. And there seems to be a lot of uses for trucks that never haul more than a refrigerator for delivery.
12-24-2020, 07:26 PM
#29
Bartlett
, Tennessee
Originally Posted by Dennis C
I have no sag at all with my 23FB and Blue Ox WDH.
Ummm, that is what the WD does, raises the rear end back up and pushes the front end back down to restore needed weight back to the steering axle.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
12-24-2020, 07:53 PM
#30
2019 27' Globetrotter
McHenry
Rrauch, you should be fine with a 23’ GT and your RAM 1500. We towed our FC23FB with a VW Touareg Diesel that had a 770 lbs. tongue weight limit and 1168 lbs payload. It handled the trailer fine.
We eventually traded up to a 27’ Globetrotter and a RAM 1500 with 1220 lbs payload. After a trip to the CAT scales we discovered we were within 100 lbs. of being over the RAM’s 4100 lbs. rear axle max. Rather than go through payload anxiety, we moved up to a RAM 2500 with 2940 lbs payload (gas, not diesel).
Unless you plan to get a larger trailer, you’ll be fine with your RAM.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
12-24-2020, 08:04 PM
#31
1997 25' Safari
Laurel
, Maryland
Simple payload
It is EXTREMELY easy to add payload capacity. Buy a 2500.
To add capacity, you NEED to add suspension components and most importantly, BRAKES!!!
Sell your 1500 and buy a 2500!
12-25-2020, 05:08 AM
#32
2018 25' International
Slidell
, Louisiana
It is unfortunate that "payload" and GVWR are legal terms used to regulate commercial hauling. It is more unfortunate that 11 states have murky laws or clear laws that are not enforced that when interpreted literally apply to RV towing. the confusion creates difficulties for people who want to increase the load capacity of vehicles. Generally one can increase the load capacity of a vehicle with no legal or regulatory difficulties by keeping the GVW below 10,000 and so long as the GCW does not exceed the sum of the original GVWR + the trailer GVWR. They can avoid serious vehicle performance and safety issues by staying below the original GCWR, the axle limits, max towing limit and the tongue limit. If tongue limit is not published, use 10% of max towing limit as the presumed tongue limit.
With this as a guideline, one can still be out of compliance with the letter of the law but not the the claimed spirit or intent in 13 states.
12-25-2020, 07:18 AM
#33
2019 27' International
Western NC
, North Carolina
I know SD trucks don’t count for fleet fuel economy. Not sure about 1/2 ton or smaller. That’s why SD trucks don’t come with a fuel economy rating on the sticker. Pretty sure my 1/2 ton did.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
12-25-2020, 08:39 AM
#34
Evergreen
Correct, but I mentioned it because of the comments above about sag. My truck actually displays very little sag even without the WDH. My brother tows a large trailer with his F-150 and he has significant sag, even with a WDH. He uses airbags to offset the sag. I’m not a fan of that approach, but he seems okay with it.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
12-25-2020, 11:40 AM
#35
2017 28' International
Jim Falls
, Wisconsin
I don't have sag with my F150 with my WDH. A cheaper solution to consider than airbags is a roadmaster suspension system. Also more durable.
I was going to put on airbags, but the accessory parts guy said go with roadmaster. That's what he uses. And he could have sold me airbags for twice the price.
12-26-2020, 09:41 AM
#36
2021 23' Globetrotter
Northern
No, Chrysler was aware of the oxymoron, but they were in a bind. Their first choice, “Dodge Duck,” didn’t test well with focus groups.
12-26-2020, 09:52 AM
#37
Evergreen
I suspect that my brother’s trailer is too big/heavy, or his setup needs some adjusting.
Dennis
Past:
Newmar Ventana 3715
12-27-2020, 07:59 AM
#38
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
I would advise your brother in law to try the Roadmaster Active Suspension. It’s not that expensive, and the install is an easy DIY. It really transforms the truck/towing experience. It does not magically add a thousand pounds payload, or a thousand actual pounds to your trucks actual weight. It doesn’t change the door sticker. It does level the truck and make the trailer behind you a lot less noticeable in terms of tongue weight. Way cheaper than changing trucks.. Still really need to drive carefully, still shouldn’t exceed axle and vehicle weight ratings.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
12-27-2020, 09:52 AM
#39
Newport Beach
Question - you want to upload the capacity because of what? What are you trying to accomplish?
12-27-2020, 12:27 PM
#40
2017 30' Flying Cloud
Raleigh
, North Carolina
1086 is the actual payload.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
