Old 01-23-2022, 12:02 PM   #1
2017 22' Sport
Knoxville , Tennessee
25% grade - should I worry?
New member here, appreciate everyone's posts - so much knowledge out there. I'm heading to a NE Georgia campground that warns of a 25% grade to get to it - not a long pull, maybe a mile or two. I'll be pulling 22' Sport w/2019 Tahoe w/Max Tow Pkg - should I worry about the pull? Thanks in advance, have not done heavy mountain towing.
carythomas is offline   Reply With Quote
Old 01-23-2022, 12:15 PM   #2
1994 30' Excella
Mississauga , Ontario
If the campground is in northwest Georgia I think I have heard of it. I seem to remember people saying there is an easier way into that spot.
Al
Al and Jean
TAC ON-3
Old 01-23-2022, 07:12 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I would not recommend it if in fact it is a 25% grade. That is about a 14 degree angle. I've never seen a road that steep. Going up is the easy part.
Going down it would be the pits. I can't imagine anyone building a road like that. I drive a 7% grade down our "mountain" here in Colorado with my trailer pushing me and I do so cautiously.
But I bet others will chime in with more experience than I have. Let's see what they say.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 01-23-2022, 08:08 PM   #4
2017 28' International
Jim Falls , Wisconsin
I had to go up a similar grade (not sure if it was 25% though) but for only a 1/4 mile one time. It was a gravel road. Had to put it in 4WD low. One place you want 4WD. Thankfully I didn’t have to go down it. But it was only 1/4 mile. I think you will have plenty of power. And going down shouldn’t be a problem if you go slow. For one thing a mile or so isn’t going to heat the brakes up that much if you have to brake. Will look a bit scary though. Maybe find the steepest hill you can around where you live and see what it’s like.
Daquenzer is offline   Reply With Quote
Old 01-23-2022, 08:25 PM   #5
2019 22' Sport
High River , Alberta
I was curious, so I went looking. Amicalola Falls State Park. It seems like a beautiful spot.
Using Google Earth, I checked the length of the access road. It's about 1.4 miles uphill. The grade averages out to about 12%; perhaps half of it is 14 to 16%. A short stretch (maybe 500 feet) is close to 20%. If Google Earth's elevations are accurate, 25% is an exaggeration.
It's still a hard first gear pull with virtually any tow vehicle. But I wouldn't be concerned about towing a 22' with a Tahoe.
AlbertF is offline   Reply With Quote
Old 01-24-2022, 09:13 AM   #6
2021 27' Flying Cloud
Oxford , MS
I avoided that park because of that 25% grade warning. I am pulling a 27’ FC with a Ram 2500 diesel. Didn’t want to chance getting pushed off the road on the downhill route out of there!
BlakeSmith is offline   Reply With Quote
Old 01-24-2022, 09:15 AM   #7
1960 26' Overlander
Tipton , Iowa
You should probably be OK. But be certain to go slow and use first gear going downhill!
Scott S is offline   Reply With Quote
Old 01-24-2022, 09:22 AM   #8
2007 27' International CCD FB
San Diego , California
I've been to a couple campgrounds like that. If you have 4WD, and a transfer case with low-range, that's going to help tremendously.
I'd be less worried about downhill as every wheel, including the trailer, is braked. As opposed to driven wheels.
pteck is online now   Reply With Quote
Old 01-24-2022, 09:58 AM   #9
Napa , California
When in doubt, try it out without your trailer. If your vehicle has 4 wheel drive and you are competent driving that type of road in it, ditch the trailer and test drive the road.
We have a favorite family campground in a canyon down 3 miles of dirt road, complete with washouts, ruts, washboards, downed trees, curves, elevation changes and absolutely no where to turn around, even in a car. Once the snow has melted and the road is accessible without a snowmobile, we make a run down in a vehicle with 4 wheel drive. Sometimes it is fine and sometimes it's not.
The worst year was where the road was relatively clear, but the campground's turn around spot at the far was blocked because a culvert had washed away. Every big vehicle or trailer that came in bottomed out and got stuck. It was worse when other vehicles were headed down and some poor shmuck was trying to get out, making itty bitty partial turns with his trailer unhitched.
Sadly, the fix the forest service put in that year was a typed sign at the top of the road that said "campground may be impassible". Folks who'd been there before laughed it off and charged ahead. It was a great year for being a tent camper!
Atwebs is offline   Reply With Quote
Old 01-24-2022, 10:31 AM   #10
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I'm quite sure that if snow or ice was possible, I would want to avoid that road.
Old 01-24-2022, 11:05 AM   #11
1996 25' Excella
Tillsonburg , Ontario
I've done 20% with a C
JCWlassic 25 behind my Dakota 2WD...by this forum's opinion seriously under rated for that trailer. Going down is easy as long as the brakes are ok all round. Going up or down on dirt or gravel ...with your rig I wouldn't be worried. Obviously a lot of folks who don't know better maker it in and out of that campground.
JCWDCW is offline   Reply With Quote
Old 01-24-2022, 11:16 AM   #12
Rich Jenkins's Avatar
2022 23' Globetrotter
Venice , Florida
If you are referring to Amicalola Falls State Park, I've been there with a passenger vehicle when I lived in Atlanta. Yes, up and down is steep but not unmanageable.
There is a good summary of campground reviews here. Lots of campers seem to enjoy it.
https://campgrounds.rvlife.com/regio...park-lodge-881
While I haven't driven the approach/departure in a travel trailer, based on your description of your TV+TT, I would be surprised if you had any issues. Obviously make sure your brakes are in good shape, and everything is working correctly. But I'd do that for any tow of any distance, of course.
It's well worth the visit and a beautiful area.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Rich Jenkins is offline   Reply With Quote
Old 01-24-2022, 11:21 AM   #13
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
If you are, in fact, referencing Amicalola Falls State Park you will see evidence of how many folks had tough time decending. The sites at top are tiny at best too although your Airstream should fit fine. Cloudland Canyon is another GA park with kinda steep, switchback, entry road but well worth tackling it cautiously for the beauty. There are surrounding roads that are definitely not towable roads but the main one is fine if you keep your wits about you. Just do your due diligence to be sure you know which roads you want to take.
Enjoy the journey.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
369goose is offline   Reply With Quote
Old 01-25-2022, 07:29 AM   #14
2017 22' Sport
Thanks for all your replies. Yes, it is Amicalola Falls I'm asking about. It will be late May so frozen precip should not be a factor (else I'll bail..), and Tahoe/Trailer brakes are both solid. No 4WD, but I've noticed Max Tow Pkg activates engine braking during steep downhill. I've navigated up/down Cloudland Canyon many times w/no issues, so I guess I'll give this a try.. Thanks again for everyone's feedback - good stuff.
Old 01-25-2022, 08:13 AM   #15
Salado , Texas
I had to bring our 27FC down a very steep grade once, not far, but I was the first trailer down the mud/gravel road after it was built (!). Use 4 Low and engine brake to control the rig, and I dialed down the gain a smidgen and manually brake checked the electric trailer brakes to make sure the trailer didn't try to push my tail around going down the mud grade. Go slow and drive smart.
Gtx Eng is offline   Reply With Quote
Old 01-30-2022, 10:16 AM   #16
Winemaker
rgwatkin's Avatar
2022 25' Flying Cloud
Avila Beach , California
25% grade is huge, you did not mention the surface, ie asphalt, gravel?. If you do not have 4wd and the surface is gravel it would be a no go for me. Life is too short to get stressed out and risk an insurance claim that would take you a year to sort out.
rgwatkin is offline   Reply With Quote
Old 01-30-2022, 12:52 PM   #17
2019 30' Flying Cloud
Teaticket , Massachusetts
Ya, I’d def be interested in surface type
before trying it. If 4Wd Low is needed
there may be a risk of driveline damage
on pavement . At least in the past trucks we have owned that is.
AnotherBob is offline   Reply With Quote
Old 01-30-2022, 06:18 PM   #18
2021 27' International
Canton , Georgia
If amicalola state park. It’s steep for a short bit but not bad. Good paved road. Some spots are a bit tight but if your backing skills are decent then no issue. I’ve done it a couple of times, no issue
F250e9 is offline   Reply With Quote
Old 01-30-2022, 07:28 PM   #19
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
I pulled my 16 foot Bambi with my Toyota Tacoma to Amicalola Falls campground with no problem whatsoever in or out. And some of the campsites are spectacular. It’s like you’re parking on a deck overlooking the forest
Native143 is offline   Reply With Quote
Old 01-30-2022, 08:39 PM   #20
Canton , Georgia
Should I worry about rust on my hitch? loislane Hitches, Couplers & Balls 28 03-25-2012 12:54 PM
Should I worry? Hitch receiver rated 400# tongue but trailer 459# amm3824 Hitches, Couplers & Balls 10 04-03-2011 09:59 PM
Fridge... Should I worry? THEPILL 2006 - 2010 International 5 05-14-2010 10:38 PM
Pipe vent covers storing water... should I worry? ronstory Roof 12 10-01-2008 01:38 AM
should I worry? ostapbender Cleaning, Stripping & Polishing 3 06-19-2007 06:28 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
