11-30-2017, 08:11 AM
2008 25' Classic
Full Time
2013-2017 Ram 2500 Cummins Water Pump Recall
Got a recall notice about water pumps, T51, could fail and cause engine fire. No parts available yet. Hmm, already had my catalytic replaced earlier in the year.
Anyone had this recall performed and had the water pump replaced?
Kelvin
11-30-2017, 08:27 AM
2016 30' International
Florence
, Alabama
Come join cumminsforum, multiple threads over there.
Rumor is you can order an Italian replacement through your local Cummins shop, but FCA dealers will only replace your current pump with the same thing if you are having trouble. Otherwise you’re stuck until the official part is out.
A diesel tech who I trust told me to look for a leak around the pump. If it’s not leaking than don’t worry about it until parts become available.
11-30-2017, 08:53 AM
2008 25' Classic
Full Time
I just called a local dealer near me. The service department doesn't think the parts will be available until March/April and has about 4000 trucks in this area to be recalled. I expect this recall will take over a year to get all affected vehicles processed. Hope my water pump doesn't fail as we tour the southwest.
Kelvin
11-30-2017, 09:22 AM
2007 30' Classic S/O
Somewhere
, South Carolina
11-30-2017, 06:08 PM
2017 30' Flying Cloud
Pleasant City
, Ohio
Some posters on other forums are finding diesel shops to replace the pump and then getting reimbursed from Chrysler
11-30-2017, 06:40 PM
Somewhere
, South Carolina
FYI, Post Recall water pump from Geno's. They are a very reputable supplier for Dodge Ram Cummins OE and aftermarket parts. I personally buy from them.
https://www.genosgarage.com/product/...7/new-products
11-30-2017, 08:09 PM
sacramento
I am a Cummins warranty person, it is recommended, not to drive, if you must drive inspect every time to drive. Local dealerships have been instructed not to sell any of these years . Confirm with your local dealerships what is there policy.
11-30-2017, 08:14 PM
2008 25' Classic
Full Time
I'm a full timer. Can't stop to wait 6 months for the parts to arrive and get an appointment.
12-01-2017, 10:21 AM
2016 27' Flying Cloud
Olympia
My local dealer told me, "We don't have the replacement part. When we get them, we'll call you."
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
12-01-2017, 10:30 AM
2013 31' Classic
billings
, Montana
Kelvin
What has been happening is the pump seizes up, and the serpentine belt starts slipping and breaks...then engine heats up...stop and have it towed to the nearest dealer...4000 miles up to 45000 miles it can happen....it doesn’t need to leak to seize up...watch your gauges
12-01-2017, 05:25 PM
2009 34' Classic
Lake Worth Beach
Originally Posted by GCinSC2
This is interesting...I wonder whether A) a dealer would install this for free if I brought the part, and B) whether the part would be covered under warranty like FCA's approved water pump would be covered?
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
12-01-2017, 05:28 PM
Pleasant City
, Ohio
Service guy at a local dealership told me that they hadn’t determined just what the problem was with the current water pump - bad parts vs bad design - and they wouldn’t have replacements available until they figured it out. Who knows.
12-01-2017, 05:54 PM
2008 25' Classic
Full Time
Hadn't heard of this recall back in September when it was announced. We've traveled almost 5k miles since then so hopefully all will be well before we have the work performed in the next 3k miles.
Kelvin
12-02-2017, 07:25 AM
2013 31' Classic
billings
, Montana
What! They know exactly what the problem is...the bearing seizes up, Cummins tried to save fifty cents and it didn’t work, my 07 went 100,000 before it went south....
12-02-2017, 08:39 AM
Pleasant City
, Ohio
I found his response a little curious since places like Genos are selling post recall water pumps.
12-02-2017, 01:32 PM
2014 30' Flying Cloud
Milton
, Ontario
My water pump failed in November 2016 and destroyed the serpentine belt. They replaced the pump. I was on the hook for the belt and a coolant flush and fill. I am on the road and don't know now if this recall applies to the pump they installed. I will ask the dealer at my next service in Jan.
12-02-2017, 03:33 PM
2008 25' Classic
Full Time
Why did you have to pay for those parts when the pump failed? What year was yours?
Kelvin
12-03-2017, 06:40 AM
Milton
, Ontario
I assumed the pump failure was a one off. The dealer didn’t mention a recall. When I go for my next service check in Jan I will get the information.
I have a 2013
12-03-2017, 08:04 AM
ObviouslyKnot
KAILUA
, HI
Look at the third picture on the linked pump, the correctly drilled vent hole is circled. The factory pumps under recall don't have it (vent or weep hole) so water seal leak can run into the bearing, if past that bearing seal, then bearing failure. If I can find the FCA page with all the facts and caveats, for repair or replace, I'll post it. You can see the hole on yours if you have it, no hole, needs new pump.
Yes, watch temps, but the bearing contamination is all internal, if no vent/weep hole, no indications until failure.
Folks that fixed already have some reimbursement clause.
Update: read the "Install And Tech Information" on the link above for more accurate and complete info.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
12-03-2017, 09:25 AM
2008 25' Classic
Full Time
I wonder if you purchased the Geno pump and then took it to a dealer if they would install it via warranty. Or would you have submit a reimbursement request to FCA
Kelvin
