Old 07-19-2020, 04:12 PM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
2 Stupid Tow Vehicle Questions.
I have a 2013 GMC 2500 Diesel that has been pre-dented for carefree driving. The other day I was backing up in my driveway next to the cabana and noticed that the rear roadside light had waves.... yes, it is half full of water. Is there a semi-easy way to drain it and reseal it, or should I put on my mask and go to the dealership? Do I need to order any gaskets, sealants, etc.
Next, the right side rear bumper step pad blew off. I KNEW it was loose, but procrastinated and it went bye-bye somewhere. Luckily, I was able to locate one on Amazon for a very reasonable price. Question... reinstall with double-sided tape, mechanical fasteners or both? Does not look like rocket science but instructions aren't included.... and I am female so I actually READ instructions.
Thanks in advance. PAULA
Old 07-20-2020, 10:19 AM   #2
Silverado owners chime in. It is just badged differently.
Old 07-20-2020, 10:23 AM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
A very small drill bit, and drill a hole at the bottom of the lens, so it can drain. If you want it to drain faster, you can drill another hole at the top, and put a dab of glue in the hole when all the water is out.
Old 07-20-2020, 11:03 AM   #4
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Terry is right, put a small hole at the lowest point on the bottom of the fixture. If water is getting in, just give it a way to get out. There are a lot of leaky gaskets across the vehicle spectrum.
Replacing gaskets and fixtures just adds up to many dollars spent.
I would use a few fasteners to secure your pad but I would use some DOW CCW or 795 silicon to glue it down to the bumper. If you are stepping on it frequently, the fasteners can work loose and fall out (and probably end up in my tires ) but the silicon will set up and remains pliable and doesn't care about water.
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 07-20-2020, 11:27 AM   #5
Chelsea , Maine
Remove the GMC grill badge and everything behind it.
Replace with blue oval.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 07-20-2020, 11:34 AM   #6
My last name is FORD.
GUD ENUF?
Old 07-20-2020, 11:40 AM   #7
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Look to your owners manual to find out how to change the bulbs, this will get you access to the light fixture.
I found water in my headlite, I used a hairdryer to vent & purge the moisture, then regreased the O ring that sealed the bulb, after cleaning out the dirt. Common sense will help in figuring out the seal fix depending on what you find.
As to step pad, look to a heavy weatherstrip contact cement, add weight for the cure.
"Chip Tank" is in Redcrest Ca.
CDONA is offline   Reply With Quote
Old 07-20-2020, 11:48 AM   #8
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Ah, then it's just be a pile of rust with a blue oval on it.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-20-2020, 12:01 PM   #9
richw46's Avatar
I'm In , Kentucky
I have found that Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker, 3.35 oz. Tube (Amazon) is fantastic. I use it as a glue and sealer on anything stubborn. I have a 91 Camry with the glass headlight lenses. Those would be very expensive to replace. I took a rock on the right side, like a BB or pellet hole. I put regular silicone in there and it lasted a year.
I got the Permatex Ultra Black on a whim, seemed to look strong, and sealed the right lens. After a year it was still holding. About that time a took a big rock in the left side lens. This as a pretty big gap. Over the course of 3 days I would put some Permatex in the hole then wait a day, put some more in the next day and finished up on the third day. That was the summer of 2012 and the Permatex is still holding strong.
So for your rubber step thingy I would put some of the Permatex on the new rubber pad and on the bumper and press it down.
For your taillight lens, if you can remove the lens then you can get a new gasket for it, probably also on Amazon or local parts store. Drilling a hole is the easy way but may cause rusting later on.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
richw46 is online now   Reply With Quote
Old 07-20-2020, 12:48 PM   #10
1960 22' Safari
in the wilderness , The great Mojave Desert
Isn't that the truth! First time you get a dent or scratch it is a relief. Now you don't have to worry about it anymore.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 07-20-2020, 01:07 PM   #11
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
Had that issue all the time when I lived where flooding was common. Issue seemed to be when water splashed from below, heavy rain puddles, etc. it wasn’t caused by regular rain or driving in the rain. Came in around the bulb screw in area but non-hardening goop and grease would melt out in high heat.
Drilled 2 small holes. Because it wasn’t happening every day, seemed like no problem after that.
Similar to the blue oval comment, when I hear of a difficult repair I suggest jacking up the radiator cap and driving a new truck under it. Another option - where the headlight screws into the lens housing - tighten it until you strip it and then back it off 1/4 turn.
LilPeanut is offline   Reply With Quote
Old 07-20-2020, 01:10 PM   #12
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Open the tailgate - there are just two screws holding the fixture in.
Each of the lights sockets will detach by turning the back counterclockwise 1/4 turn.
Pick the most convenient one and empty the water. Then you can check the mounting gasket and see where water might be entering.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 07-20-2020, 01:14 PM   #13
dznf0g's Avatar
Oswego , Illinois
GUD ENUF?
Foiled A. Ford??
-Rich-
Old 07-20-2020, 02:41 PM   #14
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Most tail lights do not fill up with water. I would fix it.
Bill M. is online now   Reply With Quote
Stupid, stupid, stupid continued. Air345Fly Classic Motorhomes 77 12-07-2018 06:08 AM
Dented my AS: stupid, stupid, stupid! Air345Fly Classic Motorhomes 88 09-12-2018 10:54 AM
This May Be A Horribly Stupid Question: Bicycle as tow vehicle hnrmcf Tow Vehicles 15 10-05-2012 12:51 PM
"Stupid is as stupid does"... Tin Diesel On The Road... 7 08-14-2009 08:59 PM
Stupid truck question - for next tow vehicle summerkid Tow Vehicles 18 09-14-2006 05:57 AM
