Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Winter Living
Old 12-20-2022, 09:20 AM   #1
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Propane Hack
Since COVID hit, I amongst others was sent home to work remotely. For nearly three years, I am still working from home and it has become permanent for me. We all started in our dining room, then bedrooms, etc. For me, Ryzer, my 2018 25FC became my home office. It took several months to finally settle in and make it into a functional office.
Then winter came. As you may or may not know, the heat pump doesn't work well before 40 degrees. Where I am from, Northridge, California, it has been hitting in the 30's. I have had to fill my tanks twice already and found it to be a PITA. I had to find another solution to make it easier for me to refill my tanks.
I found a propane hose extension, in attempting to install it, I heard a hissing sound. The existing 12" hose was too tight and any movement before removing it from the tanks was just too much stress. So I had to replace it. I chose an 18" braided hose. The extended hose allows for what I needed to do and gives a little more slack to minimize stress on the connectors.
I did all that so that I can use that propane hose extension to connect to the box connection and have a smaller tank outside. It is more convenient and much easier to go and refill the tanks. I made a video to help illustrate what I did.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 12-21-2022, 09:29 AM   #2
Stay CazuaL
cazual6's Avatar
Reseda , California
Apologies for the typo and miswording. It should be "*below 40 degrees", and "any movement before removing it" should be "any movement *beyond removing it"
WBCCI 9164
Old 12-28-2022, 11:39 PM   #3
2016 30' International
redondo beach , California
We use the propane quick disconnect on the front of the trailer.
To that we connect two small 5 gallon easy to fill propane tanks.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 12-29-2022, 07:30 AM   #4
2022 27' Globetrotter
DALLAS , TX
Can we assume that you have a pressure regulator on the 5lb bottles?
And those 5lb bottles simply provide additional capacity instead of being used to refill the main 30lb propane tanks on the trailer?
foobar is online now   Reply With Quote
Old 01-01-2023, 07:17 PM   #5
This is how it works in more detail.
Two 5 lb tanks with regulator and crossover valve sit on the ground and go to Airstream quick disconnect. Less work for me to keep them filled.
The big Airstream propane tanks are turned off when using the external propane source. The big Airstream tanks are for emergency backup, or while on the road, or maybe one night. It has been a year since we have had to remove them to be refilled.
Old 01-01-2023, 08:49 PM   #6
DALLAS , TX
Thanks, that is what I was picturing mentally. Appreciate the confirmation.
How long does it take to burn through 5 lbs of propane? As part the answer to my question, would you mind sharing what stuff you are operating using propane and for approximately how long you are running each propane consumer? Thanks in advance for taking the time to answer.
Old 01-01-2023, 11:13 PM   #7
Stay CazuaL
cazual6's Avatar
Reseda , California
I couldn't find a cable to connect to the QD from a tank. Can you share and provide links?
Old 01-01-2023, 11:33 PM   #8
During cold weather at 6,000 feet in southern Utah we rely on the propane forced air heater. And we also cook with propane. The thermostat is set at 55 at night and 62 during the day. Typical outside temps are 19 at night and 33 during the day. We also use a small electric space heater and the electric hot water heater.
With all that we burn through about two 5 gallon propane tanks a week. So thats around 10gal/week.
The heater cycles about every 10 min and runs for about 5 min.
Old 01-02-2023, 06:34 AM   #9
DALLAS , TX
Thanks. That is longer utility than I would have expected. What size Airstream do you have?
Old 01-02-2023, 09:02 AM   #10
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
So, is it 5 pound or 5 gallon tanks? Big difference. With the length of time you are able to go, I suspect it is 5 gallon.
10Smiles is offline   Reply With Quote
Old 01-02-2023, 09:06 AM   #11
DALLAS , TX
Ah, good point.
Old 01-02-2023, 11:46 PM   #12
30 feet.
Old 01-02-2023, 11:46 PM   #13
5 gallons.
Old 01-02-2023, 11:47 PM   #14
I'm still looking for the part numbers.
Old 01-03-2023, 10:03 AM   #15
2022 27' International
Poway , California
How to measure propane tanks
Propane tanks are normally described in pounds but can be converted to gallons as well. A quick google search states that 1 pound of propane is 0.236 gallons at 60 degrees Fahrenheit
Airstreams come with 30 lb tanks.
Most barbeque grills and outdoor heaters have 20 lb tanks
I just purchased 2 - 5lb tanks to be used with my propane fire-pit and grill so I don't have to lug around 20lb tanks or have a long hose from the trailers external connection described in this thread.
I suspect Mythbuster is using 20lb tanks as 5 lb tanks are quite small with just a gallon of propane. Just a guess though and maybe they are 5 lb tanks?
markuscis is online now   Reply With Quote
Old 01-03-2023, 10:45 AM   #16
dznf0g's Avatar
Oswego , Illinois
I also carry a little baby 5# bottle for fire pit and grill. I got really tired of buying the 1# tanks and making unnecessary trash. They have gotten expensive too. I do carry one 1# bottle in case I run the 5# out in the middle of grilling.
-Rich-
Old 01-03-2023, 10:47 AM   #17
Poway , California
Yup, I was doing exactly that and hated adding to the landfill.
Old 01-03-2023, 11:08 AM   #18
DALLAS , TX
Where did you guys buy your 5 gallon propane tanks?
Old 01-03-2023, 11:22 AM   #19
Poway , California
NOTE - They are 5lb not 5 gallons. A 20lb tank is about 5 gallons a little less and the 5lb tanks are about a gallon.
Costco online still has them for $50 each. Google and you'll find a rather larger price range from about $60 to $100.
Old 01-03-2023, 11:34 AM   #20
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Yep, me too! I have the 1# Coleman bottles I carry for my portable grill and campstove. I try to find them on sale 2 for $7-8bucks...can run you a lot more if not on sale. I found these bottles at Walmart and also at ACE hardware on sale few times; I stock up. But I also have a quick disconnect adaptor I got from Amazon which I can use to connect with my generator hose connected to my portable 20# bottle. I have used it with the AS QD, but psi too low and I need to move the grill around depending on where we are camping/eating so I have not converted my grill to use direct from AS QD.
2017 28' Twin Flying Cloud
furnace, heater, propane, propane hose, propane hose extension
Hack a vintage radio antenna for wifi? jrsygrl Computers, Internet & Satellite 4 03-16-2014 07:25 PM
Electrics - is this factory or a PO hack? Eugiepayset Electrical - Systems, Generators, Batteries & Solar 2 09-11-2013 11:38 AM
Refrigerator hack ! nick_gee Refrigerators 3 02-09-2012 12:44 PM
8-Track or Hack? Rivetedude Audio, Video & TV 12 05-19-2005 05:02 PM
