Power Problem
Greetings,
I have a 2019 International Signature 27FB. We are experiencing record cold for my area (NE Texas), so prior to this cold snap, I winterized my trailer, shored it, and set the furnace at 50 degrees.
We are experiencing rolling blackouts that happen about every hour and a half and last about a half hour.
I've been checking it daily to make sure my propane tanks were full, etc. Went out today and when I went inside the trailer, it was cold. Checked the thermostat and it was 32 inside the trailer. Tried to turn on the lights and they would barely come on. Checked the battery level and it was 9.2.
So I checked the breakers, and the GFI button was out. When I pushed it in, the breaker tripped.
I unplugged the shore line and the breaker GFI did not trip.
Battery disconnect is on. Shore line is hooked up. Outside temp has been as low as -6 and is currently about 7 with 6-8" snow on the ground.
My batteries are not charging and the breaker trips when I push the GFI button.
Any ideas?
