Old 10-02-2020, 02:40 PM   #1
1962 24' Tradewind
Quakertown , Pennsylvania
Hydronic ?
Anyone tried retrofitting hydronic into an old airstream ?
I am kinda worried about the complexity involved especially in terms of reliability/longevity, but one of the Alde type setups would be pretty sweet.
I am in the process of a shell off resto on a 1962 Tradewind 24. And I’m replacing everything anyhow. The other thought I had was some sort of electric ⚡️ radiant blanket type stuff under the floor like the Bowlus has.
I will be plugged in most of the time, so propane would potentially not be used at all unless I really wanted to use it.
62rosie is offline   Reply With Quote
Old 10-02-2020, 03:21 PM   #2
1962 24' Tradewind
Probably should have posted this in the appliances spot .
Old 10-05-2020, 01:28 PM   #3
Magnet18's Avatar
Churubusco , Indiana
For electric I think quiet warmth is a common choice for rvs. I'm about to do an install in my 31' and it should be about 500W. Definitely simpler than hydronic to install.
Warmly yours is another similar option
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 10-06-2020, 09:44 AM   #4
1962 24' Tradewind
Thanks I will check that option out
Hydronic Heating Startup and Review rheiniger General Repair Forum 13 07-27-2016 07:57 AM
Underfloor hydronic heating. DaytonaDan Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-17-2016 01:04 PM
Ghetto Hydronic Heater ericpeltier Plumbing - Systems & Fixtures 8 05-01-2016 01:36 PM
Problem with '84 345 with hydronic heating!! joe gooch Member Introductions 5 03-04-2009 08:06 AM
