02-25-2021, 04:02 PM
2019 28' Flying Cloud
Dripping Springs
How to check for post-winter leaks?
So as you know I didn't "winterize" when the Texas siberian storm hit:
https://www.airforums.com/forums/f46...en-219366.html
Everything has thawed now, it was 75F yesterday. (Today is a paltry 55F  )
Anyway, I pulled our poor baby out of storage. I don't have pink stuff in there, I only emptied the tanks.
What steps to take next? Fill up the tank, then what? I don't know where the pipes go or how to check for leaks.
02-25-2021, 04:18 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Fill the fresh water tank, turn on the pump and see what happens. If the pump continues to run on and off after the system pressurizes, you have a leak. If so start looking for dripping water in all cabinets.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
02-25-2021, 05:23 PM
2019 30' International
Pennsylvania
, Pennsylvania
x2 what mojo said.
Maybe do it on a paved surface driveway so you can see if/where it may be dripping underneath. Might help in location of a leak if there is one.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
1977 31' Sovereign
Rochester
, WASHINGTON
Look under your sinks, any lines or sink/ tub traps you can see.If nothing seems to be wet or dripping, you might have got lucky.
Same around water heater, outside at door for water tank gas lines.
I would avoid filling with any water now, wait till no chance of freezing again.Unless your going to use it soon,then fill and test pump like suggested above.
Just because winter storm over, doesn't mean it can't happen again
Airstream rodeo clown, it's my turn in the barrel 🤡
02-25-2021, 05:37 PM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
I favor using compressed air and monitor the plumbing just like new home construction roughed in plumbing is tested. Not hard to make a combo pressure leak down and blow out tool.
Air also cleans up pretty easy.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
02-25-2021, 05:44 PM
Normal
Yep.
A leak will find you.
Maggie
Find a need and fill it.
02-26-2021, 09:23 AM
2016 28' International
Trois-Rivieres
, Quebec
Don't forget the toilet pedal valve, very likely to have a hairline crack; no gushing water but enough to damage the floor over time. The good news is that the valve is pretty easy to replace, easier still if you remove the toilet for better access.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
02-26-2021, 09:50 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
I agree totally ....no water mess ...you can monitor the pressure and easy to rig up. You may have hidden leak that soaks insulation etc and ends up being a bigger PIA.
02-26-2021, 09:54 AM
1975 31' Sovereign
North Fort Myers
Not winterized
Use air before you make a mess and ruin something. Get a winterizing plug that screws into your water connection, fill with air up to about 30 psi. Then keep checking with air gauge that you use for checking tires. If it holds, you're good!
https://www.amazon.com/Camco-36153-B...358399&sr=8-29
02-26-2021, 10:11 AM
Long Island
, New York
Bingo!
Wet insulation buried in the walls/floor would defeat the benefits of using just water first IMO.
And the chances are quite good [IMO] that there is at least one broken line in the walls, near the outdoor shower valves, or behind the city water intake and pressure regulator there.
Let the music lift you up . . .
Have a little pun in life . . .
Peter
02-26-2021, 10:24 AM
Cedar Hill
I have a question, for myself and possibly for Kalashnikov. How much air pressure? I "assume"40 psi, but we all know what "assume" spells.
02-26-2021, 10:26 AM
1977 31' Sovereign
Rochester
, WASHINGTON
40 psi on the air seems to be the go to for pressure testing.Dont go higher.
02-26-2021, 10:34 AM
Lost in America
Santa Fe
, New Mexico
Using air can help detect a leak if the compressor starts and stops, but it can be hard to find the leak of air if it is not accessible. Dripping water is pretty easy to find and if you catch it early, is not going to cause damage. If the leak is in the wall, the water will find it's way out rather quickly.
02-26-2021, 10:36 AM
Long Island
, New York
. . . and soak all the insulation inside that wall, and possibly the insulation under the floor in the belly pan? [Please see Post #10]
No thanks.
Peter
02-26-2021, 10:40 AM
Somewhere
, South Carolina
I had to do a way back search for the combo blow out pressure test tool I made.
See post 10 for pic.
https://www.airforums.com/forums/f44...air-60222.html
Gary
S/OS #001
02-26-2021, 10:41 AM
Long Island
, New York
Nice!
Looks like all the parts are pretty standard at a good hardware store?
Peter
02-26-2021, 10:42 AM
Somewhere
, South Carolina
Thanks Peter, that's it and still used for each winterization.
S/OS #001
02-26-2021, 12:29 PM
2013 30' International
SAN ANTONIO
, TX
I will be doing the same thing this weekend as I got caught in the Texas weather unprepared. The question I have is should I fill the fresh tank and use the pump to look for leaks or can I just hook up to the city water connection and check that way? Would they return the same results? I may even try the air method but just trying to educate myself as I’m new to Airstreams. Thanks in advance.
02-26-2021, 12:41 PM
Somewhere
, South Carolina
Joey
If H2O is the only option using the pump will signal you because it will indicate a leak by cycling w/o you opening a faucet etc. Using city water supply will just leak leak leak and then you'll see the oops as opposed to hearing the pump respond to the leak.
Might be time to consider making the blow out / leak down tool unless you'll never be in a potential freezing condition again.
Looks like several states got caught in the it's don't happen here situation.
Gary
And air don't make a mess.
S/OS #001
02-26-2021, 01:01 PM
Lost in America
Santa Fe
, New Mexico
No thanks.
Well if it is already leaking, then it is already wet. Everything will dry out eventually.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks, leaks, and more leaks
da_lizard |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
15 |
04-11-2016 11:36 AM |
LEAKS LEAKS more LEAKS in ATL
parzam21 |
General Repair Forum |
17 |
12-27-2015 02:46 PM |
Leaks, Leaks and more leaks
Jim in Pima |
5 |
12-12-2007 11:23 AM |
Leaks, leaks, leaks
jeffnjen30 |
8 |
08-27-2007 11:03 PM |
leaks leaks leaks
Globie64 |
10 |
12-31-2005 05:49 PM |
