Good afternoon.
I am a relatively new Airstream owner, full time for now while working as travel nurse.
I spent Jan/Feb 2021 on the gulf of Texas, and it froze for the first time in a long time down there. My pipes froze and burst. After that, I had the fittings and pipes replaced with PEX.
I am working on getting better prepared this year, even as I go South again.
My 17 ft
1965 Caravel has a propane heater, I made sure it was in good working order. But to be honest I am nervous about using propane as silly as that sounds. Esp if I am at work for longer hours!
I have a great Vornado heater but when temps dropped below and hovered around freezing it would not do the trick.
Advice on heated hose? I know to disconnect hose when freeze potential.
Heat tape advice?
I may invest in another heater as well, not sure. If so, anyone have a good recommendation?
Any advise I am grateful for, and is appreciated.
Thank you, and take care out there.
