RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-28-2020, 03:37 PM   #1
Waukesha , Wisconsin
Four Season Airstream?
I've read lots of threads about using an Airstream in colder weather but there is one question I have not yet been able to find an answer to.
We're in the slow process of looking for an Airstream, probably something in the 25 foot range. Since we live in Wisconsin and have hopes of being able to use the Airstream in the colder ends of the season (early spring and late fall) where temps can fall suddenly and drastically, I would really rather have a trailer which is factory equipped for this.
Did Airstream every make a true 4-season model? We'd prefer a used trailer, so if there were 4-season models made at some time I'll narrow my search to just those. Or can one be ordered with a true 4-season package from the factory?
richard5933 is offline   Reply With Quote
Old 12-28-2020, 03:39 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I don't know about ever, but there are no options to make this a 4 season trailer today. Go to a brand that really builds a 4 season trailer.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-28-2020, 03:56 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard👍
As far as I know Florida still has all its Seasons.😂
“I’ve always thought that over planning was just a firewall against not being sure of what you really want to do.”
RLC
Tahawus
Old 12-28-2020, 05:16 PM   #4
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Airstreams are NOT for camping in weather where it goes below freezing, snows and is this way for 4-6 months. The windows are single pane glass and the condensation is a problem. In saying this, cold weather camping can be fun as long as the Airstream is inside a heated garage.
We live on Vancouver Island where early "summer" can be in the low 40's and same with "late October" and we do camp in this temperature. But seriously Airstream get complicated when it goes below freezing. You know, condensation, freezing waterlines etc. and baby it's cold in those metal tubes.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 12-28-2020, 05:23 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
AS is only useful for 2 1/2 seasons,
once the temp goes lower than 10C, many issues occur such as
too much humidity
frozen pipes etc at night,
frost on the walls
waninae39 is offline   Reply With Quote
Old 12-28-2020, 05:25 PM   #6
Long Island , New York
Thumbs down
To my knowledge . . . no.
This recent thread from Colorado is an interesting read for how it can be done, with a lot of time and effort, by customizing our aluminum tents:
https://www.airforums.com/forums/f46...-a-215428.html
Post #83 goes into detail: https://www.airforums.com/forums/f46...ml#post2442068
"Let the Music Lift You Up!"
Peter
Old 12-28-2020, 05:26 PM   #7
Well, that's disappointing.
Old 12-28-2020, 05:38 PM   #8
2017 28' International
Jim Falls , Wisconsin
We live in Wisconsin. You can get by when the temperature is cold. We have done it for a week or so. But the LP gets sucked up pretty fast, and you really need to keep vents going. But the camping season is pretty much April 15 to October 15. Maybe extend it 2 weeks either side. That’s when most campgrounds are open in the north. Unless you are going to boondock quite a bit, which then means using generators.
And honestly unless you really like cold weather it isn’t much fun to camp when it is cold. At least we haven’t found it to be.
Now if you are really into things like cross country skiing, etc. and boondocking then you can get a 4 season trailer. Lance makes one that is pretty nice. As I get older I like the cold weather less and less. THE ONLY reason I would go with a 4 season trailer is I’m leaving here in March and going south where it is warm. But for those few days I’ll stay in a warm motel room.
Daquenzer is offline   Reply With Quote
Old 12-28-2020, 05:48 PM   #9
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
It seems every one of these writers has an insight that might help in your search. You may notice a common thread among their opinions - none of the choices are visually appealing and none are an Airstream:
https://camperguide.org/four-season-...trailer-guide/
https://rvexpertise.com/travel-trailers/4-season/
https://whereyoumakeit.com/rv/four-s...avel-trailers/
https://rvblogger.com/blog/4-season-...railer-brands/
https://rvfavorites.com/all-seasons-rv/
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 12-28-2020, 06:17 PM   #10
Thanks for the information. Guess I'm somewhat surprised, both that in all the years Airstream has never found enough of a market to do a 4-season model and that in the absence of a factory 4-season option no one else has produced a mod kit to accomplish this.
I've seen lots of SOB trailers with 4-season packages, but none of them have that special something inherent in an Airstream.
Old 12-28-2020, 06:37 PM   #11
2019 25' International
Providence , Rhode Island
All you have to do to answer the question is consider the construction.....the outer and inner skin in an AS are metal......which in newer AS are separated with double sided tape to create a small thermal break......other brands are wood or other materials that are not metal....so creating a 4 season other brand is something that can be done because the conduction methods of cold to the inner chamber is very different.......pros and cons to both I'd guess.
kittmaster is offline   Reply With Quote
Old 12-28-2020, 06:50 PM   #12
The fact is most people don’t camp in the winter. How many campers do you see going down the road in the Winter? Very small percentage camp in the winter.
Old 12-28-2020, 07:53 PM   #13
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Airstream is not a 4 season trailer..hot in the summer cold and froze in the winter....4 season. Look at artic fox. Be better for winter
Old 12-28-2020, 08:04 PM   #14
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Sadly, I have to agree.
panamerican is offline   Reply With Quote
Old 12-28-2020, 08:24 PM   #15
2019 30' International
Pennsylvania , Pennsylvania
Wouldn't take much for me to go in for a 25Y model
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 12-28-2020, 08:53 PM   #16
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I believe that another very capable 4 season trailer is the Bigfoot. Apparantly they have been building a 4 season since 2007.
gandttimes is online now   Reply With Quote
Old 12-29-2020, 06:42 AM   #17
I don't want to camp in the winter either - my goal is to have be able to extend the season further than what's normally done here in Wisconsin. My current coach is usually winterized by the end of October and I don't de-winterize until the end of April or early May.
Meanwhile there are events and rallies around the country in warmer states taking place every year in March and November. Attending those in with a trailer not suited to cold weather would mean having to winterize or de-winterize while on the road, something we're not at all interested in doing.
In some years getting to the events we want to attend would mean driving a day or more through temps in the teens or lower, not a risk I'd want to take with exposed plumbing. On top of that, when we travel we like to be able to stop for a night or two along the way to enjoy the areas we're passing through, and that isn't possible if you're trying to hi-tail it out of town to keep from having the pipes freeze.
We'd also like to visit some higher-altitude places in the country, and in those areas it can be late May or June and still have below freezing temps, especially at night.
I get it that winter camping is not a thing everyone enjoys, but with the number of threads I see on the various RV sites about how to travel from a cold climate to a warmer one without incurring freezing damage, I don't think I'm the only one wanting to do this.
My point? There are lots of things to do in this country in an RV which aren't really "winter camping" but still require an RV suited for below freezing temps.
If Airstream never made a 4-season model, what about the possibility of doing a renovation to an older one to convert it to 4-season? Is that possible, or does the structure inherent in an Airstream preclude the possibility of making the necessary improvements?
Old 12-29-2020, 08:06 AM   #18
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Of course "you" could do a winter oriented reno. Put in spray insulation, bubble wrap, thinsulate etc. Carry underneath skirting, install a dehumidifier, a dickinson heater with a wave heater and sleep under down duvet covers. Schedule for lots of propane delivery's and enjoy.
Airstream likey is selling so many 2.5 season trailers for big bucks they haven't the need or time to make a fully winter geared, more expensive, heavier model.
There are folks in here who tuff it out for a winter or two. There are also some folks who regularly go skiing in there's.
Just traveling to a more southern location in the winter doesn't take that many upgrades. Stay winterized until you get south.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-04-2021, 08:03 AM   #19
St. Paul , Minnesota
We just got back from a trip to Arizona from Minnesota for the Holidays. Both Colorado and New Mexico had very cold nights. (13-19 degrees) We used the water in the belly tanks and the gas furnace to keep them warm. Even when we got to Iowa and Mn with temps down to 7 degrees this worked fine.
The issue we had was the waste gate valves froze up at night. If I could figure out a way to prevent that I would be in Colorado more often.
markf004 is offline   Reply With Quote
Old 01-05-2021, 06:59 AM   #20
I assume then that the waste gate is outside the enclosed area?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Not a four season trailer? Alreddawg19 Full-Timing, Winter Living & Workamping 81 10-26-2020 09:32 AM
Four Season Camping? kdullea Land Yacht/Legacy Motorhomes 19 02-10-2016 09:13 PM
2011 Airstream International Serenity 28' Sleeps four, Christopher Deam eBay Watch Airstreams on eBay 0 08-05-2012 02:00 PM
2011 Airstream International Serenity 28' Sleeps four, Christopher Deam eBay Watch Airstreams on eBay 0 07-21-2012 10:10 AM
Four Winds Airstream MH passed at IBT rideair WBCCI Forum 102 01-22-2007 06:47 PM
