Old 10-26-2024, 06:45 AM   #61
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
nothing easy about winter camping if everything is "right", but without a furnace could become a nightmare. The risks are obvious, but a fire could have unimaginable consequences, and I have seen a lot of fires caused by supplemental heat sources and people trying to stay warm.
rbs is offline   Reply With Quote
Old 10-26-2024, 11:01 AM   #62
Mimbres , New Mexico
Originally Posted by TouringDan View Post
Too New
I have done some winter camping in West Virginia and it was quite cold but I only did this for a few days at a time when I went skiing.
I would probably operate using water from the water tank. Just refil it during the day when it is warm out.
Trying to winter camp without a furnace is difficult at best. I wouldn’t do it.
I would install a new furnace and the necessary propane lines.
If you need to heat with electric resistance heaters it will be expensive but here is what I would do. Heat the smallest area possible. Like only heat the bedroom at night and only the living area you are using during the day. At night use a mattress pad heater. It only uses about 90 watts and you will be plenty warm at least when you are sleeping.
Good luck.
Dan
Thanks for your thoughts. Ordered a Delonghi bathroom radiator heater and hoping that will be enough (possibly with a fan). The pipes are all pex after the bathroom (which is still copper) and inside. There are areas where they run behind storage panels and I may insulate there (both the pipes and the back of the door). Hard to say what should and shouldn't be done as it's my first winter and there are many variables.
too_new is offline   Reply With Quote
Old 10-26-2024, 11:07 AM   #63
I won't overload the circuits and have taken much time in researching how to ensure that doesn't happen.
Old 10-26-2024, 11:58 AM   #64
Lily&Me's Avatar
Normal , Illinois
It kind of feels like you’re daring the Devil, too_new, and I hope you don’t become a cautionary tale of how not to sit out a winter.
I sincerely wish you all the best with this venture, and please let us know how it turns out.
Maggie
🚐 Interstate Owner Emeritus 🚐
🌹 Cherish and appreciate those you love. This moment could be your last. 🐚
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 06:31 PM
FULL time Trailer or FULL time Motel? Ray Eklund Full-Timing, Winter Living & Workamping 40 07-06-2015 07:11 AM
First time living in Airstream full time. MyNancy1977 1977 Excella 500 0 02-23-2015 09:09 AM
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 09:07 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-21-2010 12:28 AM
