Old 12-09-2020, 05:20 AM   #21
2018 30' Classic
Cumberland , Maryland
Originally Posted by nvestysly View Post
Found some very interesting information. This guy may not have covered all the aspects of insulation but he certainly hits many of the significant points. As others have said on this thread and others... reflective bubble insulation is not what many think it is.
Great info, thanks for posting!
Airhead2018 is offline   Reply With Quote
Old 12-09-2020, 07:59 AM   #22
Mollysdad's Avatar
There's insulation for heat and insulation for noise.
To mitigate noise, you need to attack several issues, vibration as well as noise through the air. That noise is dampened by foam AND mass, a sandwich of foam and lead.
I put some in a boat engine room and it made a big difference. The cost was eye opening, but for a small space it's worth it. I'd do the same if I built a generator box.
Mollysdad is online now   Reply With Quote
Old 12-09-2020, 04:13 PM   #23
docflyboy's Avatar
1968 17' Caravel
1967 22' Safari
Leawood , Kansas
My search of van build sites led me to use Thinsulate. It has an R rating that was about 2 higher than I could get with fiberglass, it is mildew and fire resistant, cuts easily, holds in place well and doesn't itch. It wasn't real cheap, but not prohibitive. I think the roll was 5' wide, and one roll will do my 17' Caravel less the forward and back endcaps. Jerry
Follow my '68 Caravel Frame Off restoration at https://www.airforums.com/forums/f13...el-207768.html
WBCCI 1968
VAC Region 8
docflyboy is offline   Reply With Quote
Old 12-09-2020, 07:55 PM   #24
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
The tape on ribs sure does help. Recently installed some 1/8” foam tape on ribs and while sitting in the sun for 30 minutes I couldn’t dare touch the outer skins... but the ribs were very easy to touch. Showed me all I needed to know!
Zcashio is offline   Reply With Quote
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Airstreams And Aircraft cooperhawk Forum Rallies & Meet Ups 3 01-18-2006 10:10 AM
Airstream and Aircraft Detailing in Texas jimmy Commercial Listings 0 08-03-2003 02:24 PM
