Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 09-17-2020, 07:57 AM   #21
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
West 105 epoxy and 207 hardener is way to go
Non yellowing and designed for flat surfaces
We used 3 coats on our home outside smoker. I redo if every 7-10 years
Lee Valley sells the whole product line including matching fillers
waninae39 is offline   Reply With Quote
Old 09-17-2020, 08:28 AM   #22
1976 Argosy 20
Doylestown , Pennsylvania
Thank you all so much for the information. You guys think it is still worth it even if I’m only doing the top side that is exposed?
I was planning on hitting as much area as I can. Some of it covered by the structures still up will not be hit but everything I can get my hands to will. Just want to make sure there is no downfall to just top side where I can get to.
Thanks!
npm5031 is offline   Reply With Quote
Old 09-17-2020, 10:36 AM   #23
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
I did what you are asking about on my 1958 AS 18' Traveler almost 2 decades ago. I had a small area at the rear where a window had previously leaked where I repaired it as well.
West Systems Epoxy is a great product that is easy to use with the metering pumps. I used Denatured Alcohol to thin out the first coat to ensure that the sub-floor could absorb as much as possible. Then I just rolled and tipped two more coats to seal all. With the newer trailers having rot issues on their sub-floor this made perfect sense to me as a preventative measure.
I tried a couple of Vinyl Planks and wasn't happy with them probably because we can have extreme temperature swings where I live. I settled on Smart Core because it has a rigid core. When I talked to their tech support I was advised to glue it down. I used Liquid Nails Polyurethane adhesive because it wasn't very permanent but did the job very well. I used it with small dots similar to the way Corian Counter Tops recommends so that there is still a possibility of expansion and contraction movement.
Here is a link to the flooring that I used....not cheap but then it still looks great after all of this time.
https://www.lowes.com/pl/Smartcore--...ent=1686755038
Steve
1958 California Built 18' #18-4092
https://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 09-17-2020, 12:36 PM   #24
"Cloudsplitter"
Thanks!
To properly seal I would definitely use the penetrating epoxy system, do not just add a waterproof surface layer.
Key West/West Palm Beach Franktr On The Road... 4 10-30-2019 08:23 AM
Epoxy paint used in bath question 74Tradewind Upholstery, Blinds, Walls & Interior Finishes 1 11-01-2015 06:27 AM
Appalachian Mountains/Trails On The West Side Between West VA & Tennessee murreywalker On The Road... 2 08-27-2013 07:43 AM
Floor repair:epoxy vs resin TomW Repairing/Replacing Floor &/or Frame 11 12-24-2003 11:32 AM
Penetrating Epoxy Andy R Repairing/Replacing Floor &/or Frame 8 06-08-2002 06:12 AM
