Old 02-27-2019, 10:10 PM   #1
mddogpilot's Avatar
2011 25' FB Flying Cloud
Fox Island , Washington
Vinyl Floor Replacement
Has anyone had luck replacing the vinyl flooring without it separating at the seams or buckling?
I've read through years of posts and would like to hear if anyone has been able to put down an interlocking plank floor that lasts.
Stored in the Pacific NW, the trailer is exposed to 20 degrees on occasion, so not terribly cold.
mddogpilot is offline   Reply With Quote
Old 02-27-2019, 10:18 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
We are just starting to replace ours. We chose Smartcore Pro (tm) vinyl plank flooring available at Lowes. It is waterproof and specified for installation in environments where post-installation the temperature range is between -25 and +155 degrees F. This is by far the widest range we found. It must be stored and installed between 55 and 85 F, but after installation the wider range applies.
I will post during and after installation but am not going to be able to start for a month or so.
Al
Old 01-29-2020, 06:24 PM   #3
2008 28' Safari SE
Carmel , Indiana
Al
Al and Missy,
Just curious how your installation went. I am looking to remove the old vinyl flooring and looking for replacements. I see all types of suggestions in the Forum but your selection seems to be the best quality and fit for temperature and moisture variations. Hope it went well. Pictures and any lessons learned would be appreciated. Thanks. Michael
mapbikes is offline   Reply With Quote
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 11:32 AM
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 07:23 AM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 03:38 PM
corian color preferences and vinyl floor choices? 2airishuman General Interior Topics 9 02-28-2005 06:57 PM
