11-03-2018, 03:32 PM
1989 25' Excella
Torrington
, Wyoming
Self sticking tile
If you have used self sticking tiles in your Airstream how do you rate them?
How long have you had them installed?
On the glue side of the tiles did you use another type of glue to insure sticking?
I like the appearance of the self sticking tiles. The weight factor is good too.
I am concerned about what happens when the trailer flexes during travel. Will the flexing cause the glue to pull away from the wall?
I would like to use the tiles in the kitchen and bath.
Will the bathroom humidity cause an issue with the glue?
Appreciate anyone sharing their experience with me!
Regards, Carole
11-03-2018, 05:35 PM
1989 25' Excella
Torrington
, Wyoming
Self sticking tile.
I should have said I want to use the tiles on the wall...not the floor!
Thanks to Bob for the redirection..that was nice!
Regards, Carole
06-05-2019, 01:23 PM
Satellite Beach
After reading lots of great reviews of the Smart Tiles, we used them for the kitchen backsplash in our 1979 Sovereign. We cleaned the surface really well before applying them and after application and for the first couple of months they looked and worked out amazing. Fast forward one year, where our trailer has endured intense temperatures (we live in Florida, so it freezes occasionally in the winter and I'm sure it gets to over 100 in the summer in there), and they are yellowed and lifting. We're really disappointed. I wouldn't recommend them.
06-05-2019, 03:09 PM
2004 28' Classic
Monument
I did aluminum self-sticking tiles. The adhesion was not very good so I sprayed the back of the tiles with 3M Super 77 Multipurpose Permanent Spray Adhesive Glue. That did the trick.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
06-30-2020, 09:03 AM
1973 Argosy 24
Ashland
, Wisconsin
DaveP, After a year how would you rate your tile? What brand did you use?
thanks.
06-30-2020, 03:42 PM
2004 28' Classic
Monument
I like the tile. It has held up well, looks nice and is easy to keep clean around the backslash area.
I have a Classic and the tile had backing that would not stick very well to the vinyl wall paper in the trailer. The extra 3M Super 77 took care of that. The tile is called Art3d 10-Pack Self-Adhesive Metal Backsplash Peel and Stick Tile for Kitchen, 12" x 12" Silver Aluminium Surface. It is still for sales on Amazon. Here is a link https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
DaveP
2023 Ram 3500 4x4
08-28-2020, 08:37 PM
1973 29' Ambassador
Mercer Island
Thanks for the tip! Putting this in the ambassador tomorrow
08-29-2020, 06:54 AM
2004 28' Classic
Monument
Also a good idea to clean the wall with some rubbing alcohol before the installation. Good luck! You'll like it.
DaveP
2023 Ram 3500 4x4
08-29-2020, 10:14 AM
1973 29' Ambassador
Mercer Island
Thanks, mine has that weird actors plastic coating on the wall and I was torn between TSP or alcohol. Alcohol is easier to use, so I’ll do that
08-29-2020, 10:55 PM
1973 29' Ambassador
Mercer Island
Put them up today. Easy, quick, high quality. Two cuts to make tomorrow to finish
08-30-2020, 07:06 AM
2004 28' Classic
Monument
Pictures?
DaveP
2023 Ram 3500 4x4
08-31-2020, 08:43 AM
1973 29' Ambassador
Mercer Island
They went up very easily. I cut full tiles off around obstructions with a utility knife. The final row next to the window was 1 1/2 inches. I cut it very easily with a wet tile saw and touched up on grinder.
Takes 4 full panels plus on partial to do a trailer. They come in a pack of 10 so you could do two jobs with one box. Anyone in Seattle want to buy 1/2 box? [emoji3]
Very easy job, very stick tiles. Covered the holes I made when I repaired the door sag a few years ago
08-31-2020, 09:55 AM
2004 28' Classic
Monument
Nice!
DaveP
2023 Ram 3500 4x4
