Old 06-26-2020, 10:22 AM   #1
Rivet Dude
1972 21' Globetrotter
1987 34' Excella
yep, still on the road , On The Road
Marmoleum vs Hand Sanitizer
How, you say, could they possibly be in the same sentence?
Well, I'll tell you.
I spilled some ethanol-based, who, hand sanitizer, on my marmoleum floor.
I thought I got most of it wiped up.
Turns out underneath a box, oh, there must have been a little left.
It has marred the surface, with a slight white
Tinge. I use the marmoleum cleaner, and the wax, but no luck.
Any suggestions, would be greatly appreciated.
Stay safe out there on the road.
airjeff is offline   Reply With Quote
Old 06-26-2020, 02:06 PM   #2
Sag Harbor , New York
Is there a section of that floor which is relatively hidden, so you can test these low-grit possibilities, to make sure they don't stain also?
-- alcohol [2 kinds]
-- Goof-off
-- vinegar [2-3 kinds]
-- lemon juice
-- etc.
Then I would move up to:
-- Soft Scrub
-- Bar Keeper's Friend [Cleaning tips: https://www.barkeepersfriend.com/cleaning-tips/]
-- Bon Ami
The trouble with these last ones, is that they will probably change the sheen of the surface in some way, so you might have to wax/polish it back to "normal" . . . or give that entire section of floor new "matte-like" sheen.
FWIW -- Marmoleum cleaning tips: https://duckduckgo.com/?t=ffab&q=mar...leaning&ia=web
https://www.greenbuildingsupply.com/...tain-Marmoleum
Of course in these Times Covidian, the definition of "normal" may have to become more pliable IMO.
Good luck,
Marmoleum? StingrayL82 Floor Finishes 43 08-16-2016 06:25 AM
Marmoleum Flooring J-n-A Our Community 34 03-10-2013 11:13 PM
Installing Marmoleum Lumatic Floor Finishes 10 08-19-2009 01:04 PM
Marmoleum swelling! modarch Floor Finishes 4 06-04-2009 11:57 AM
Marmoleum Flooring -Sheet or tile njunear Floor Finishes 6 04-22-2008 11:26 PM
