Old 04-22-2020, 08:48 AM   #1
1976 Argosy 28
Buford , Georgia
Best way to install plank flooring
About to install vinyl plank flooring (NuCore with cork backing) and would like to know how people have done it before. How have you found is the best way to install including dealing with the curves etc.
MY thought was to run it front/back parallel with the left/right sides of the camper.
Thoughts/ideas/ suggestions..
John
strangepod is offline   Reply With Quote
Old 04-23-2020, 08:28 AM   #2
1976 Argosy 28
Buford , Georgia
One thing I didn't mention is this is going down on a fully gutted, new subfloor in the trailer.
So should I do it like this or wait until I have the interior installed due to the 'floating' floor?
John
Old 04-23-2020, 08:52 AM   #3
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Detroit , Michigan
From experience, I suggest waiting to install the floor until after the base cabinetry is in. You’ll avoid trapping the floor under a cabinet and use less product which saves money and weight.
I also do not suggest installing it in the direction of trailer travel unless you’ve found a product that has very little expansion / contraction. Lastly, painting and other tasks that may damage the floor (dropped tools, etc) are not a concern with your existing subfloor.
Of course, those using marmoleum or similar would certainly install it prior to the cabinetry.
Brian's AS renovation:
https://www.airforums.com/forums/f11...on-134984.html
Tow vehicle: 2019 F250 Lariat 6.7L CC SRW
Atomic_13 is offline   Reply With Quote
Old 04-23-2020, 09:04 AM   #4
GeocamperAS's Avatar
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
I did not use NuCore but did install vinyl plank. I installed base cabinets before the floor. Then on a warm sunny day with the trailer closed up, I opened the door to find the expansion so great the floor was buckled so bad it snapped apart in some places. Took it out and replaced with a wood laminate.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 04-23-2020, 09:14 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Long axis of planks parallel with length of trailer. Not under cabinets.
Old 05-13-2020, 06:52 AM   #6
1976 Argosy 28
Buford , Georgia
Thanks - now thinking about it I would agree that since this is a floating floor there should be no cabinets etc on it.
John
Old 05-13-2020, 07:12 AM   #7
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
Good advice here....do it last, and allow room for expansion along edges.....always install lengthwise with the trailer....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 06-09-2020, 06:57 PM   #8
1968 26' Overlander
Orlando , Florida
I just earned myself genius status by making a template for the curves out of a clear shower curtain and a sharpie. I pushed a piece of the shower curtain along the wall and into the curve and then traced along the curve at the floor with the sharpie. Once cut out, it works in both corners and and can be transferred easily to the flooring pieces with a grease pencil or dry erase marker.
megan is offline   Reply With Quote
Old 06-21-2020, 11:13 AM   #9
1999 19' Bambi
M , Northern California
Awesome M for sharing this cool tip!
Blossom is offline   Reply With Quote
Old 06-21-2020, 11:50 AM   #10
Mount'n Man's Avatar
Cedarcreek , Missouri
We just finished installing COREtec Plus (the higher end stuff, not the Lowe's brand) in our '06 Safari. The old sheet vinyl had finally pulled away from the edges and buckled enough to warrant the new floor covering. The new flooring is supposedly heat/cold stable and not susceptible to expansion... we'll see. I trimmed the old vinyl at the cabinetry rather than gut the trailer. Honestly, the hardest thing was figuring the layout to have mostly whole pieces at the edges.
Once I started, I had sheets of Kraft paper cut to the size of the tiles to make templates of the more complicated shapes. The vinyl tiles cut very easily with a jigsaw equipped with a laminate blade. I cut the tiles around the kitchen area to fit very close, leaving the ¼" expansion gap around the outer straight perimeter. I caulked the kitchen edges to make sure spills didn't get under the tiles, and milled some hardwood moldings to cover the expansion gaps. Moldings were attached to the vertical surfaces with automotive emblem adhesive tape so there was no fastener damage to the walls or floor. The new threshold was attached using original screws.
Do yourself a favor and purchase the steel installation tool to seat the seams...
(Hopefully the pictures load in the correct orientation [emoji849])Click image for larger version
ID:	370853Click image for larger version
ID:	370854Click image for larger version
ID:	370855Click image for larger version
ID:	370856Click image for larger version
Mount'n Man is offline   Reply With Quote
Old 06-21-2020, 12:09 PM   #11
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Looks great. I did mine a few years back but I don't like my expansion gap moulding much. I do not know how to mill wood like you.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 06-21-2020, 12:54 PM   #12
Thanks. Trickiest one was the molding that went around the outer aluminum wall. Curved with a compound back angle and I needed to cover the hole from the old woofer wires that I pushed back in the wall. Two layers of ⅜" bendable plywood, glued against a jig, milled to profile, Bondo'ed, sanded, and painted to match the commercially available moldings for that particular flooring style. These trailers are a labor of love!
Replacing original flooring with vinyl plank flooring Team Hardy Repairing/Replacing Floor &/or Frame 23 10-26-2019 07:45 PM
New carpeting and vinyl plank flooring JMSx2 Land Yacht/Legacy Motorhomes 12 05-20-2014 05:09 AM
Picture of vinyl plank flooring installed spaceghost65 Repairing/Replacing Floor &/or Frame 6 08-19-2013 11:37 AM
Wood Plank vinyl flooring wvabeer Land Yacht/Legacy Motorhomes 33 07-08-2013 05:13 PM
Best Way to Install Cork Flooring? highmark Floor Finishes 9 08-23-2006 08:41 AM
