08-22-2013, 10:45 AM
1969 29' Ambassador
brooksville
Allure sticky side planks
Ok all, I have some allure planks. We are getting closer to installing it. I was Reading through the installation manual for the the flooring. It states not to use in a camping trailer. Since we bought it months ago returning it is not an option and we really do like the floor style.
Has anyone had problems with the heat during the summer on the floor? I was wondering if there's problems with separation or expansion issues. We live in Florida so the trailer does get very hot.
08-22-2013, 10:47 AM
1966 26' Overlander
Woodstock
, Georgia
I have Allure in my Overlander, had it in a Sovereign before. It expands a little in the summer but if you leave a 1/8 or 1/4" space around the edges it is fine. I cover the space with a shoe modling
08-22-2013, 10:58 AM
1969 29' Ambassador
brooksville
No buckling or popping up?
08-22-2013, 11:13 AM
1994 21' Sovereign
Paradise Valley
My only input is I have used it in a couple of my rental properties. Great durable stuff and handsome as well.
WBCCI# 2520 AIR# 77458 Ken and Ben the Saint Paradise Valley, Arizona
08-22-2013, 11:39 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Silverflames...my experience hasn't been so positive. Installed Allure bamboo flooring in our "78" Ambassador. Left about 1/8" around the edges and ran it lengthwise in our Ambassador. It looked beautiful when first installed. That Winter we noticed considerable gaps in the flooring...more so end to end gaps. During the Summer some of the gaps close up with expansion. I'm in the process of flooring a "74" Tradewind and don't think I'll be using Allure but go with solid sheet flooring of some type...probably marmoleum.
Bob Leopold
Indiana, PA
PA TAC-5
WBCCI 4871
08-22-2013, 02:16 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Silver flames,
We live in Texas and it gets H O T. I put the Allure in a 75 Argosy, run lengthwise. I did not leave enough gap at the edge and experience some buckling. Went back a trimmed to a 1/4" gap and problem solved. Love the stuff!!
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
08-22-2013, 02:19 PM
1969 29' Ambassador
brooksville
Originally Posted by bwoodtx
Silver flames,
Good.. What was the temp when you laid the floor? I might want to adjust the temp inside to a middle ground so the seams don't expand and contract to much.
08-22-2013, 02:28 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
I have used it too. It is great. Now....pay attention. When installing it use a pattern where you lay the sticky side down onto the previous piece. The adhesive is so good that if you touch the sticky strips at all...they are together. No adjustment. There is no sliding that one piece under the previous to a good connection. By laying it on top you have that control.
08-22-2013, 03:06 PM
1969 29' Ambassador
brooksville
I'm sorry, in a but confused, I had my brain cell sucked dry at work today. What do you mean about a pattern? Like a card board cut out?
08-22-2013, 03:20 PM
1992 34' Excella
Austin
When I installed mine (which has been working fine for 4+ years now) I used the release paper laid onto the sticky surface to keep the two overlaps separated until I had the planks into position, then I kept them in place while I slid the paper out and bonded the overlaps. My gaps are really tight in the winter and less so in the summer, but I'm not that picky and I like the Allure flooring just fine. I left about a ¼" gap around the perimeter with molding over the edge and it never buckles.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
08-22-2013, 04:06 PM
2002 25' Safari
Fountain Inn
, South Carolina
I have had ours installed for almost 2 years. Works great. I installed length wise. I used a cutter from home depot that was design to cut vinyl tiles. The cutter looks like a school paper cutter. Think carefully through your plan to minimize waste.
Bud
08-22-2013, 05:26 PM
1997 30' Excella
San Antonio
I laid my floor in April and the temperatures were in the 80's when I did that.
Bruce
08-27-2013, 02:10 PM
1972 27' Overlander
Denver
, North Carolina
2 Questions; what did you use to cut the curves? Did you start from the middle of the floor like most flooring or one of the edges? Thanks
08-28-2013, 07:47 AM
1992 34' Excella
Austin
I laid mine out lengthwise cause I think it looks better that way. I snapped a chalk centerline on the floor and worked outward from it but understand that one side of the line is more difficult to lay when it's done that way because of the overlaps. I have a pair of really heavy duty shears and a razor knife that I used for trimming.
Crusty
Lake Travis, TX
"Rancho Deluxe"
08-28-2013, 08:23 AM
1966 26' Overlander
Woodstock
, Georgia
I made a template with heavy brown paper and cut the curves from that
08-28-2013, 08:33 AM
1969 29' Ambassador
brooksville
My brother in law installs flooring for a living. He uses a heat gun to heat up the planks before cutting tight areas. You can also score the plank and then snap it.
Using heavy duty brown construction paper is a good idea. Use that to make your patterns, then over lay it on the planks you need to cut.
Install instructions state to start on one wall and then work your way over.
08-29-2013, 02:10 PM
1972 27' Overlander
Denver
, North Carolina
Thanks Guys, I like both ideas. I get some paper, make a story stick with a paint stick and figure the curves.
08-29-2013, 07:51 PM
1969 29' Ambassador
brooksville
Story stick?
08-29-2013, 09:14 PM
Tenkara Fly Angler
1975 31' Sovereign
Vernon
We are in the process of looking. What we want is not good with Texas heat. Thanks for the thread!
1975 Sovereign
"The Silver Bullet"
2013 F350 Super Duty 6.7 Liter Diesel
WBCCI #8578
08-30-2013, 02:18 PM
Classic 30
Sum Wear
, Ohio
Did you check out the Ultra Allure with the interlocking edges? I think I'm going to try them. Not much about them here, but rv.net makes them sound promising.
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
