Old 08-21-2018, 11:26 AM   #1
1979 25' Tradewind
Port Townsend , Washington
What model Gabriel
I want to replace shocks on a 1979 Trade Wind. I'd rather buy Gabriel because my tire shop can order them wholesale, and cannot do that with the Airstream branded shock.
What model # Gabriel?
douggant is offline   Reply With Quote
Old 08-24-2018, 01:03 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The only shocks available for that year with horizontal mounted shocks is through an airstream source.
>>>>>>>>>>Action
Old 09-16-2018, 07:09 AM   #3
1991 25' Excella
Sioux Falls , South Dakota
Gabriel part number 610816 is what fit my 1991 Excella got em from Inland RV in May this year their part number 12416
TOPORANGER is offline   Reply With Quote
Old 11-17-2018, 01:26 PM   #4
2006 34' Classic
Alamogordo , New Mexico
This is my first post type question so may be incomplete. I am trying to replace the shocks on a 2006 Classic 34' Travel Trailer. I contacted Gabriel dealers/parts houses and they cannot cross or find the part number. Is this number only listed for Airstream? If there is a cross to another number would appreciate mfg. and source. Mentioned above is Inland RV and their part number of 12416. Are they a direct cross or a substitute?
Thanks, MatadorX
MatadorX is offline   Reply With Quote
Old 11-17-2018, 02:11 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The correct shocks are only available from an Airstream dealership. Since these are so limited in production numbers no one will carry these. Because of the limited application there are no substitutes.
All other shocks are designed to operate in a vertical position. These are designed to operate in a horizontal position.
>>>>>>>>>>>>>Action
Old 11-17-2018, 02:37 PM   #6
1963 19' Globetrotter
Orion , Illinois
These shocks are only available from someone who stocks Airstream parts. My local Airstream dealer did not have them - no surprise when it comes to vintage stuff. So I did what I should have done in the first place; called Inland RV, right part in two days. Very knowledgeable folks with great service. One other thing ,you don't have to drop the axle to install them. You can bend the bracket that holds them out then back to get the job done. Learned that from Inland.
63air is offline   Reply With Quote
Old 12-31-2019, 09:55 AM   #7
Hardman's Avatar
Crestone , Colorado
The only shocks available this year occur through an airflow source.
Hardman is offline   Reply With Quote
Airstream Expert in San Gabriel, CA who can inspect a used 19'? butters Dollars & Cents 4 02-09-2013 04:45 PM
Gabriel Shocks rwkrapfel Shocks 4 05-23-2012 01:45 PM
Gabriel shock number needed 63air Shocks 1 09-27-2005 10:23 AM
