Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 11-16-2016, 05:38 PM   #1
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
Shocks on 2012 Eddie Bauer 25'
My mechanic is going thru my AS, just told me shocks are toast and I need to replace them. They are Gabriel 610816. I would like to put a better quality shock on, preferably bilstein.
Has anyone else done this, any thoughts?!? Thanks in advance...
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
sparkymark is offline   Reply With Quote
Old 11-17-2016, 08:29 AM   #2
Vintage Kin
Fort Worth , Texas
Shock absorber design can be pretty specific. Torsion axle AS trailers are one of those places. Personally, I'd doubt shocks 4/5 years old have failed unless can be shown seals blown and fluid leakage. See other threads on this site. Andy at Inland RV for info search words, and purchases
1990 35' Silver Streak
2004 555 Cummins
Old 11-17-2016, 10:57 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I wonder how he mechanic determined the shocks were toast? Road test, leaking, did he pull them? Have things been thrown around in your Airstream going down the road?
We have a 2012 FC 25 with Michelin 16" tires and had the running gear inspected, bearing runout and brakes checked, tires rotated last spring at Jackson Center. I talked to the mechanic, he said all is in excellent condition. Never mentioned shocks specifically as I recall.
Doug and Cheryl
Old 11-17-2016, 12:11 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Those shocks are mounted more or less horizontal. (Different than vertical mounting) Because of that the oil & valves in a horizontal mounted shock is in a different position. Mounting a vertical shock in a horizontal position doesn't work.
Because of limited application only Airstream supplies the correct shock.
>>>>>>>>>>>>Action
Old 11-17-2016, 07:15 PM   #5
sparkymark's Avatar
The seals are blown, somfar I haven't been able to find anything available except the Gabriel's which, according to AS is a specific shock made exclusively for them...
Old 11-18-2016, 09:13 AM   #6
Vintage Kin
Fort Worth , Texas
By report, the AS-specific shock absorbers are inexpensive.
2004 555 Cummins
Old 11-18-2016, 11:18 AM   #7
2006 19' Safari
East Greenbush , New York
They're available from any AS dealer, and online at Outdoors Mart and Inland RV.
Not very expensive at all. And you're right, Gabriel custom makes them for AS.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
heitkergm is offline   Reply With Quote
Old 11-18-2016, 01:01 PM   #8
Diehard51
Diehard51's Avatar
1986 25' Sovereign
Bulverde , Texas
Sparkymark,
I just received 4ea AS shocks for my 1986 Sovereign 25' They are Gabriel brand purchase from Inland RV, there p/n 12416, they are currently on sale 25% off at $30.00 each. Great customer service and fast shipping.
Mike
Diehard51 is offline   Reply With Quote
Old 12-17-2016, 04:36 PM   #9
sparkymark's Avatar
Update: so, all 4 were absolutely shot-if your mechanic doesn't remove the shocks to test them-then they didn't test them. I found a similar replacement made by Bilstien and they all have been replaced and work perfectly!!!
Old 12-17-2016, 05:17 PM   #10
Harpo's Avatar
2017 23' International
Curry County , Oregon
Images: 14
I too have a 25' Eddie Bauer. Just wondering how many miles do you think you have on your trailer before you replaced your shocks?
Harpo is offline   Reply With Quote
Old 12-18-2016, 10:49 AM   #11
sparkymark's Avatar
I purchased it as 'previously owned' in 2013, have no idea of mileage before I picked it up...I purchased it in Arkansas, probably around 5-6,000 over the last 3 years. Not a lot of miles.
Old 12-18-2016, 05:48 PM   #12
Harpo's Avatar
Images: 14
Hmmm! I failed to mention mine is a 2012 as well. I probably have about 7 or 8 thousand on mine. I guess I better go get mine checked. Thanks for the reply.
Old 07-06-2018, 08:23 PM   #13
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Wow we have a 2009 25FB Classic with over 30,000 miles no problems with shocks.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 07-06-2018, 09:53 PM   #14
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Do you happen to have the Bilstien part number of the shock you used?
Old 07-07-2018, 11:32 AM   #15
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
2 1/2 year old thread. Not sure you will get an answer.
thewarden is offline   Reply With Quote
Old 07-07-2018, 11:59 AM   #16
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If it were me, I would reach out to Bilstien and ask them if any of their shocks would work mounted in a horizontal position.
>>>>>>>>>>>Action
Picture of an Eddie Bauer on the back cover of a semi annual Eddie Bauer flyer BassCan Airstream "In the News" 0 06-18-2016 08:11 PM
25 FB Eddie Bauer :: 2012 Airstream Eddie Bauer Jennybeth Airstream Registry Discussions 0 09-26-2013 06:28 PM
Eddie Bauer :: 2012 Airstream Eddie Bauer 25' FB screamstream Airstream Registry Discussions 3 12-12-2011 03:00 PM
2012 Airstream Eddie Bauer 25' FB Travel Trailer eBay Watch Airstreams on eBay 0 03-19-2011 02:00 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
