Old 06-22-2024, 02:06 PM   #1
2014 23' FB Flying Cloud
Ann Arbor , Michigan
Shock absorbers
2014 23 fb Flying cloud. During inspection of undercarriage discovered a loose end of curb side shock absorber. Think I attached a picture for review but canít see it myself. Bottom mount of this shock is firmly attached. Can this trailer me towed to a service center safely?
HoWee is offline   Reply With Quote
Old 06-22-2024, 02:39 PM   #2
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
Not ideal to tow it although it probably won't come off. It's not difficult to repair, for most of them a standard 1/2 - 13 nut and washer will secure it back in place. The proper nut is a shoulder nut but any will work. Tighten securely and you should be good to go. Check the others to be safe.
Keys Dave is offline   Reply With Quote
Old 06-22-2024, 09:29 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I agree - if the threads on the stud are still there (should be) just shove the end of the shock back in place and use a 1/2" washer and the proper nut to hold things in place. If you can get a Nyloc nut on there even better as they won't back off on their own.
If you can't get the nut on there, do what you can to secure the end of the shock to the mount - baling wire, zip tie, etc. - to avoid it coming totally loose and head to your dealer or any place which works on trailers. This is not a difficult thing to fix and any competent shop should be able to reattach the shock. Just make sure that they jack the trailer properly.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 06-23-2024, 05:58 AM   #4
Thanks!
Thanks for help. Iíll pull wheel and secure this. The info about which tap is perfect.
Happy travels to allÖ.
Delco shock absorbers TomW Shocks 13 06-20-2016 11:48 PM
shock absorbers for 1969 Tradewind TCL Member Introductions 1 04-06-2006 08:46 AM
Shock Absorbers for 62 Overlander Silverfly Shocks 6 07-14-2004 01:18 PM
Shock Absorbers for Ford Excursion Ed Keyes Tow Vehicles 2 06-12-2004 05:29 PM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 06:15 PM
