Old 09-10-2017, 11:55 AM   #1
1992 29' Excella
Fruita , Colorado
Shock absorber installation
Greetings.... new to the forum
I want and need to install new shock absorbers on my 1992 29' Excella. I am unable to remove the top shock mount off the axle studs due to minute frame clearance. Do I need to drop the axles to install the 4 new shocks on the top mounts?
Thank you for your help
Djasay is offline   Reply With Quote
Old 09-10-2017, 12:15 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Never done it but maybe this video will help...
wulfraat is offline   Reply With Quote
Old 09-10-2017, 12:44 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
A lot of people say the shocks are not necessary? What do you think?
Old 09-10-2017, 02:23 PM   #4
Byron Center , Michigan
You ever drive a car with bad shocks? I wouldn't want my trailer bouncing around like that. Tire wear can get funky, too.
YippieKiYa is offline   Reply With Quote
Old 09-10-2017, 02:31 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Neither of my trailers appear to "bounce around" and I have not had any unusual tire wear or damage except from a bent spindle. I have ridden in trailers with old shocks without harshness. Respectfully, Is your comment based on personal experience or hearsay. I am still waiting to find someone who has had any kind of damage from old shocks. Dexter axles, which are used on Airstreams are not sold with shock absorber mounts unless you ask for them. On the other hand Airstream, I trust, puts them there for a reason.
I wonder the same thing and don't have the answer.
Old 09-10-2017, 02:52 PM   #6
Originally Posted by Lumatic View Post
Neither of my trailers appear to "bounce around" and I have not had any unusual tire wear except or damage except from a bent spindle. Respectfully, Is your comment based on personal experience or hearsay. I am still waiting to find someone who has had any kind of damage from old shocks.
Thanks for asking, and I appreciate the question.
I've seen the odd tire wear first hand (weird cupping) on my own cars and trucks when I didn't have money to replace worn shocks, and have had utility trailers slowly bouncing behind me. Part of the reason for a damper is to keep the tire in contact with the ground, too. This helps with safe braking, cornering, etc. It also ~seems~ that it would help with dampening sway [that's opinion/question].
When I was a teenager, we thought it would be fun to take them off of a car and see what happens. The car kept bouncing and was nearly impossible to control. That lesson probably biases my opinion.
It might not be as big of a deal on the Dexter design or with the low center of gravity of the AS, but given the choice, I'd prefer to have them. Especially if the trailer came with them. I'm interested in hearing from other Airstreamers who may have had this experience, too. Thanks again for asking.
Larry
Old 09-10-2017, 03:20 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
PS I'm not saying shocks are necessary on other vehicles.
Old 09-10-2017, 05:19 PM   #8
Hiwheel Joe's Avatar
1984 27' Sovereign
Central , Oklahoma
Shock install
One way is to take a large pry bar and pry out the top shock mount enough to replace the top shock. Maybe 1 to 2 inches. After you get it back on and tighten the nut, take a 4X4' place on the shock mount and pund back into place leaving space between the bolt and frame.
Hiwheel Joe is offline   Reply With Quote
Old 09-11-2017, 07:26 PM   #9
1992 29' Excella
Fruita , Colorado
Thank you for the info. It appears I need to purchase a large pry bar enough to persuade the top mount to move ever so slightly.
Appreciate it
Old 09-15-2017, 10:04 PM   #10
1963 19' Globetrotter
Orion , Illinois
Bad shocks can cause tire cupping. I just had them replaced on my 63 Globetrotter. Took it in to the shop to have the axle alignment checked because of tire cupping and found a blown shock , alignment and bearings were fine. Big pry bar to bend the bracket so the shock could be installed ,no need to drop the axle. In and out in 30 minutes. I confirmed this as the way to do it after talking to Andy from Inland RV. Also got the shocks from them-California to Illinois in three days ;excellent service.
63air is offline   Reply With Quote
Shock absorber life safari 28 Axles 10 10-13-2009 08:17 AM
Avion shock absorber question ColtSAA45 Vintage Kin 4 07-21-2007 11:18 AM
1969 Safari shock absorber studs tom westlake Axles 6 06-03-2006 01:03 PM
Shock absorber information Nye Thatcher Shocks 0 02-16-2005 11:49 AM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 07:34 PM
