We put the Michelin LTX MS/2 tires on our '59 Overlander and the shocks rub slightly on the inside of the tire.
Does anyone know of a replacement shock with a smaller diameter? The outer diameter of this shock is 2" and I'd love to find one that is 1 1/2" or less.
An hour on the web and a 1/2 hour at the local NAPA store have come up short. Everything is by vehicle spec, not by performance spec, it seems.
You must have new axles from Colin Hyde if you have the Monroe shocks. Can you carve on the ends of the shock to let it move inboard a little? Or can you bend the outside cover of the shock in a little?
I almost suggested wheel spacers, but I wouldn't do that on my trailer, so I wouldn't suggest it for yours.
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
I feel your pain. For me the solution was to move the shocks to the inside of the springs. But that's a lot of work unless you're in the middle of a full monty.
Grinding the shock mount so that it doesn't interfere with the shock and moving spacers did the trick. Messy but easy. Plenty of clearance between the shock and tire now.
Thanks for posting the solution. It may help others!
>>>>>>>>Action
