Old 01-02-2021, 06:04 PM   #1
Augie R.
1960 22' Safari
carlsbad , California
Canít locate shock replacements
Spent all day calling and driving around looking for shock replacements for my 1960 22í Safari I am in the process of replacing the 4Ē drop original axle to a straight Dexter. But I can not locate a shock replacement spent about two hours at Oreilyís cross referencing the length of them but Iím afraid the load numbers as to what they think matches will be off. Any suggestions ? Fully closed they are 9Ē and fully extended the are 13Ē any suggestions helps thank you 😊
augier is offline   Reply With Quote
Old 01-02-2021, 06:23 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado: You have a neat vintage Airstream. It is the last year of the leaf spring axles. Airstream went to the now Dexter "Dura Torque" axles in 1961. I replaced the axles and shocks on my 66 Trade Wind. They were a Monroe shock, but might not work on a leaf spring axle. The shocks came with the axles from Colin Hyde in New York. He has the shocks you need. Here is a photo of my new, vertical shocks.
California's Inland RV is a big vintage Airstream parts retailer. Calling them should get you a shock part number. They are also famous for helping folks with Dexter axles.
HighSky is also a big vintage Airstream parts retailer. Maybe they can help.
Converting your trailer to Dexter Flex Torque axles is well worth it.
David
Name:	1406 Axles Both Mounted (Small).jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 01-02-2021, 10:50 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The last year of vertical shocks was 1966.
Airstream used horizontal shocks after that and those kinds of shocks are an Airstream only!
The shocks for a 61 will be vertical. I went to NAPA and got shocks for my 66 Overlander. However that was over 20 years ago. Even if I did have the data from that, those shocks may be different for an older smaller trailer. I got replacements by taking an old one to the store and matched by dimension.
Action
Old 01-11-2021, 06:43 PM   #4
1994 28' Excella
Fort Myers , Florida
I just bought new shocks from Inland RV, they are in California.
Campingjimmy is offline   Reply With Quote
Old 01-11-2021, 08:14 PM   #5
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Did you actually get what you ordered from them?
-Leslie
LNBright is offline   Reply With Quote
We can't locate the original vin# on our 1966 Tradewind Adams 1959-69 Tradewind 9 01-14-2012 11:55 PM
Can't locate low point drain values MR AIRSTREAM Winterizing, Storage, Carports & Covers 0 09-15-2011 08:57 AM
Sheared shock mounts? Where to get replacements? robwok Shocks 3 05-31-2011 10:40 AM
can't locate six position switch on my 345 johnboy28540 Generators & Solar Power 4 03-13-2009 05:26 PM
