Old 09-05-2020, 04:27 PM   #1
1974 25' Tradewind
Charlottesville , Virginia
'74 Tradewind - Sheared off shock-mount bolt
Hey all. While removing one off the axles from my Tradewind, I wrenched too hard on one of the shock-mount nuts and sheared off the end of the bolt. I've found several other posts asking for advice on how to repair this, but I haven't seen any responses. I assume I'll have to get a welder to come out and weld something new in place, but what will they need? Would a competent welder just be able to look at the other side and know what to do?
zimage is offline   Reply With Quote
Old 09-05-2020, 05:19 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
A good welder will inspect and then decide if the existing pieces can be welded back or what is left is cut or ground off and new metal is to be attached.
But an inspection is needed.
Action
Old 09-05-2020, 07:23 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had one break off when I had a 75 TradeWind. My neighbor was a welder and we cleaned it up and welded it back in place. It was still attached 10 years later when I sold the trailer.
Richard
azflycaster is online now   Reply With Quote
Old 09-09-2020, 06:39 PM   #4
1974 25' Tradewind
Thanks for the tips. I haven't fixed it yet, but I also found that Inland RV sells them as "Airstream Axle Shock Stud". The OEM Airstream part number for the bolt appears to be 400012-01. It's a weld-on part, so I either need to learn to weld or find someone who does house-calls.
'72 Ambassador lower shock mount: weld back on or use a bolt? flaagan Shocks 12 07-24-2015 04:30 AM
Upper shock mount sheared off 89 Excella pjg5842 Shocks 0 06-12-2011 08:17 AM
Sheared shock mounts? Where to get replacements? robwok Shocks 3 05-31-2011 10:40 AM
Sheared door locking mechanism upper bolt woppa 4 Doors & Locks 3 06-18-2009 08:39 AM
