01-15-2007, 11:09 AM
1967 17' Caravel
East Bernard
67 Caravel Shocks
I bought new shocks for my 67' Airstream Caravel 17ft. By looking at the shocks it looks as if you have to take off the drums and backing plates to have enough clearance to remove the shock away from the mounting stud without it getting in a bind. If this is true are there any tricks or recommendations for the easiest way.
01-15-2007, 11:33 AM
Retired.
, At Large
Hi, and welcome to the forums.
To answer your question, you will need to bend the shock bracket outward slightly so the shock can be removed. The alternative is to unbolt the axle to gain enough clearance for the shock. You can bend the bracket back into place when you are finished. Removing the tire will give you more room to work.
01-15-2007, 11:43 AM
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
When I finally mounted my shocks to my trailer, I unbolted the axle and dropped it down just enough to slide the shock on and repeated the process on the other side.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
01-15-2007, 01:48 PM
Corona
Bend the shock bracket just enough to enable the removal of the shock.
It is not necessary to bend the bracket back in place when your done.
01-15-2007, 01:53 PM
2003 22' International CCD
Kiln
, Mississippi
Bend It - already done this on my 66 Caravel.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
01-15-2007, 02:54 PM
1967 17' Caravel
East Bernard
thanks for all the suggestions guys
01-15-2007, 03:03 PM
1967 17' Caravel
East Bernard
If anyone is interested the part no. on those shocks are #20718 from O'Reilly Auto Parts for $14 each. From Napa their #94005 but I think theirs are about $25 each. If you don't have one of those auto parts stores just tell them you need front shocks for a late 60's early 70s Chevy 1/2 ton truck. These match the existing length shocks pretty close.
01-15-2007, 03:23 PM
1967 26' Overlander
Huntsville
, Alabama
Its a design issue
... just tell them you need front shocks for a late 60's early 70s Chevy 1/2 ton truck. These match the existing length shocks pretty close.
Airstream shock absorbers are designed to work while mounted near-horizontal.
While the shocks you mentioned may physically bolt up, they will not function as well as they do in the vertical orientation in the Chevy trucks you mentioned.
Tom
01-15-2007, 03:31 PM
1967 17' Caravel
East Bernard
I'm not sure what you mean about mounting horizontally? These shocks are mounted verically up and down on my Airstream.
01-15-2007, 03:33 PM
1967 17' Caravel
East Bernard
I got those part no's from previous forums I found on the internet about Airstream shocks.
01-15-2007, 03:36 PM
Corona
The NAPA number you quoted is good "BUT" only for the vertical shocks.
A vertical shock is absolutely useless in a horizontal position.
Airstream trailers from 1966 and back used vertical shocks, and 1967 and up all use horizontal shocks, except some Caravel models.
DO NOT USE A VERTICAL SHOCK IN PLACE OF A HORIZONTAL SHOCK.
01-15-2007, 03:45 PM
1967 26' Overlander
Huntsville
, Alabama
He may be abrupt on occasion but
Hang around this forum and you will find that Andy knows what he is talking about.
From my own background I know about design differences.
Tom
01-15-2007, 03:49 PM
1967 17' Caravel
East Bernard
Well I can only assume I have one of those vertical models. These shocks don't look any different or mount any different than the ones on my 62' VW convertible. The original Delco part no. 3166784 on my shocks matched another guys forum on his 62 Bambi and this is the same replacement part no. he gave for the shocks to buy that I did. How the heck does a horizontal shock system work and look like?
01-15-2007, 04:27 PM
1967 26' Overlander
Huntsville
, Alabama
I don't have photos of my horizontal mounting to share
Well I can only assume I have one of those vertical models. ... How the heck does a horizontal shock system work and look like?
You may well have a 'vertical' model.
At this point you need to post a photo of your Caravel's existing configuration as I do not have a jpeg of my near-horizontally mounted shocks to share for comparison.
All said & done, you might be in good shape.
Tom
01-15-2007, 04:30 PM
Corona
Tom
Vertical mounted shocks are almost 90 degress straight up, from horizontal.
Horizontal shocks are at about a 30 degree angle up from horizontal.
01-15-2007, 05:07 PM
1967 17' Caravel
East Bernard
Well then I'm pretty sure I'm in the clear now and have the correct vertical shocks for my 67'. Those shocks are pretty much vertical and by no means lay at a 30 degree incline or so. Thanks for all you guys input. I've had many restored cars but this is my first classic trailer and I just bought it last week for $2300. I think I got a heck of a deal. If anyone is interested in seeing it I can send pics.
01-15-2007, 05:27 PM
1967 26' Overlander
Huntsville
, Alabama
Post some pix under the photos tab
.. If anyone is interested in seeing it I can send pics.
This forum gives each member a fairly good chunk of disk space under the "photos" tab in which to post pictures.
We would all appreciate seeing pictures of your "new" Caravel.
Tom
01-15-2007, 05:48 PM
1967 17' Caravel
East Bernard
I just posted pictures under my profile........Please view and I would appreciate any positive or negative feedback about trailer.
Steven
"he who dies with the most toys wins"
01-15-2007, 06:03 PM
Somewhere
, Indiana
Nice!
Nice looking trailer. That should be a cool project!
Best Regards,
Henry
01-15-2007, 07:41 PM
1965 17' Caravel
brooklyn park
caravel shocks
I bought the more expensive original equip. shocks from Inland RV because they dampen in both directions! A car shock keeps your car from bottoming out-one direction. The new shocks actually restored the proper height of the trailer relative to the tire and axle so I have more wheel well room. (still only 3/4" on the frig side) joe q in flyover land (MN)
