Xtra power supply.
Not sure where to put this one. First did this with my 73 31' than my 86 and now my 90. Tired of popping breakers trying to cool down the trailer if you turn on the micro wave . I got a 50 ft 12 gauge ext cord. My trailer has the compartments in the bottom edge under the hot water htr and back under bed compartment. I brought the cord in to the trailer thru one of the most came up the inside under the bed and cabinets. I put a new plug in the kick panel be under the cabinets and then another new plug behind the micro wave. Most sites have a couple of ,20 amp plugs you can use. If not I switch it back to the original plug. This also gives
Me a place to plug in an electric htr while the heat strip is running in the AC unit.
