12-28-2018, 09:45 PM
#141
Black Diamond
Originally Posted by Stanley29
Hi Pygmy,
do you have any close up picts of the inside trim? The problem Im having is trying to figure out how to cut the hole around the flue on the inside of the trailer. The hole has to be oval which is damn near impossible to make look clean without a plasma cutter or something I do not own. I was thinking I would cut a larger round hole say 4 or 5 inch round hole than try to trim around the flue. Im going to make a separate piece of aluminum polished up nice to span the hole distance from the stove up the wall. Ill make the hole then rivet it to the aluminum piece to the wall. Not pretty. Is this what you did? Cheers, Mike
Not sure I understand the plan you laid out. Here's a closer photo. You could always take a piece of cardboard and hold it over the top of your pipe (not installed) and trim a hole that will fit the way you want - holding the cardboard at the approximate angle of the inner roof.
12-28-2018, 10:38 PM
#142
1954 26' Romany Cruiser
jefferson
, Oregon
wood stove
Thanks for the photo,
Sorry for the last message. I changed what I was writing and didnt erase all of it. Good idea about the card board trick. I should be done soon and Ill post some picts. Appreciate all the help. Cheers, Mike
12-29-2018, 11:07 PM
#143
Black Diamond
01-01-2019, 07:19 AM
#144
1966 24' Tradewind
1987 34' Excella
Olathe
, Kansas
Looks Awsome
So glad I found Air Forums and your thread! All your work is amazing, have you done something like this in the past? The control panel and fusing under the plexiglass is a really nice touch. Hard to tell what is attached to which layer of plexiglass from the pics but by far the best one I have seen. Any closer pics of that area?
Your talents are endless!
01-01-2019, 08:42 PM
#145
Black Diamond
03-19-2019, 07:10 PM
#146
1966 24' Tradewind
1987 34' Excella
Olathe
, Kansas
Wiring diagram
Did you have a wiring diagram that you used or just figure that out by your self. I think I can handle everything else on the build but the wiring thing has me a bit worried. I can wire a house no problem but this is a lot different. Pretty much thinking of doing what you have except less panels and batteries.
Yours is still one of my favorites!
03-19-2019, 11:45 PM
#147
Black Diamond
Thanks for the compliment. I home run power and ground for each 12v load. Eliminates guess work if loads don't work at some point. Little more expensive in wire though. I did bthe same for 110v AC, except a few outlets were linked. Wiring your trailer is much easier than your house. I worked up my own wiring diagram. Basically list all of your loads AC and DC. Then group them as you want. I grouped lights and fridges etc. So they were next to each other on the fuse/breaker panels. I'll add some pictures...
03-19-2019, 11:51 PM
#148
Black Diamond
04-07-2019, 08:04 AM
#149
Houston
Pygmypoacher, do you have a separate blog that documents your early works? Like electrical, plumbing, and axle change out?
07-06-2019, 07:28 AM
#150
1976 31' Excella 500
Clinton
, Louisiana
Pygmy, may I ask which shear you used to cut your patches? I will be needing to cut a few and have an idea of what I want to cut but baffled on getting curves in there. TIA
Don't take life to serious, Nobody ever gets out alive anyway
www.sweetadelida.com
12-23-2020, 08:20 PM
#151
Black Diamond
12-23-2020, 08:25 PM
#152
1966 24' Tradewind
1987 34' Excella
Olathe
, Kansas
So Cool
Still one one of my favorites!
12-30-2020, 10:22 AM
#153
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Top of the 395
, British Columbia
I haven’t been on here much lately, but it was fun to read through your thread again. And of course, since the 5 year reno of my 74 Ambassador is basically done, I had to drag home a 63 Globe Trotter yesterday. So much for free time...
We did bang out a couple more in between though...
12-30-2020, 10:28 AM
#154
1967 17' Caravel
1974 29' Ambassador
Top of the 395
, British Columbia
And a bit of color... Not exactly my style, but clients pick what they like. They do look great though.
I love the corrugated and natural wood in yours. It’s like an amazing cabin in the woods on wheels. I’m a fly fisherman and hunter so our 74 has a “mantry” to compliment the pantry. It’s a 5’ long drawer that pulls out from under the rear king bed with rifle and rod racks.
12-30-2020, 10:58 AM
#155
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Red you do nice work!!!!! Good luck on the 63 globetrotter. We have a 61 we're puttering on ourselves.
Hittenstiehl
12-30-2020, 11:41 AM
#156
1967 17' Caravel
1974 29' Ambassador
Top of the 395
, British Columbia
Thanks Hit! I’d be out pressure washing the 34 years of green funk off it right now if it weren’t for the 60 mph winds and buckets of rain. Natures pressure washer isn’t cutting through all the layers!
Sorry for the hijack Pygmy! We are pretty close to each other, so maybe some day I could see yours in person...
10-09-2023, 06:45 AM
#157
1966 24' Tradewind
1987 34' Excella
Olathe
, Kansas
I'm wondering how the buskote has held up. Getting ready to paint the top of my tradewind.
