Old 12-28-2018, 10:45 PM   #141
Pygmypoacher's Avatar
Black Diamond , Washington
Originally Posted by Stanley29 View Post
Hi Pygmy,
do you have any close up picts of the inside trim? The problem Im having is trying to figure out how to cut the hole around the flue on the inside of the trailer. The hole has to be oval which is damn near impossible to make look clean without a plasma cutter or something I do not own. I was thinking I would cut a larger round hole say 4 or 5 inch round hole than try to trim around the flue. Im going to make a separate piece of aluminum polished up nice to span the hole distance from the stove up the wall. Ill make the hole then rivet it to the aluminum piece to the wall. Not pretty. Is this what you did? Cheers, Mike
Not sure I understand the plan you laid out. Here's a closer photo. You could always take a piece of cardboard and hold it over the top of your pipe (not installed) and trim a hole that will fit the way you want - holding the cardboard at the approximate angle of the inner roof. Click image for larger version
Pygmypoacher is offline   Reply With Quote
Old 12-28-2018, 11:38 PM   #142
1954 26' Romany Cruiser
jefferson , Oregon
wood stove
Thanks for the photo,
Sorry for the last message. I changed what I was writing and didnt erase all of it. Good idea about the card board trick. I should be done soon and Ill post some picts. Appreciate all the help. Cheers, Mike
Stanley29 is offline   Reply With Quote
Old 12-30-2018, 12:07 AM   #143
After months of brainstorming I finally decided how to trim my Vista view windows. Since I failed to install the classic plastic trim assemblies when installing the walls, and I trimmed the windows a fair amount wider than needed - it was difficult to decide on a solution. I wound up using 3/4" maple. Doubled up on the ends to allow trimming to the wall curve and bolted through on the perimeter. Next step is to trim the inside down to the window - either maple veneer or aluminum. Click image for larger version
ID:	330623Click image for larger version
ID:	330624Click image for larger version
ID:	330625Click image for larger version
ID:	330626Click image for larger version
Old 01-01-2019, 08:19 AM   #144
coloradoup's Avatar
1966 24' Tradewind
1987 34' Excella
Olathe , Kansas
Looks Awsome
So glad I found Air Forums and your thread! All your work is amazing, have you done something like this in the past? The control panel and fusing under the plexiglass is a really nice touch. Hard to tell what is attached to which layer of plexiglass from the pics but by far the best one I have seen. Any closer pics of that area?
Your talents are endless!
coloradoup is offline   Reply With Quote
Old 01-01-2019, 09:42 PM   #145
This is my first attempt at an rv renovation project. Thanks for your kind words. There's a 3/4in layer as a seat platform. A half width layer below that for fuse panels, breakers and interfaces. Floor level below that for inverter/charger, solar charger etc. Photos in sequence. Click image for larger version
ID:	330823Click image for larger version
ID:	330824Click image for larger version
ID:	330825Click image for larger version
ID:	330826Click image for larger version
ID:	330827Click image for larger version
ID:	330828Click image for larger version
Old 03-19-2019, 08:10 PM   #146
coloradoup's Avatar
1966 24' Tradewind
1987 34' Excella
Olathe , Kansas
Wiring diagram
Did you have a wiring diagram that you used or just figure that out by your self. I think I can handle everything else on the build but the wiring thing has me a bit worried. I can wire a house no problem but this is a lot different. Pretty much thinking of doing what you have except less panels and batteries.
Yours is still one of my favorites!
Old 03-20-2019, 12:45 AM   #147
Thanks for the compliment. I home run power and ground for each 12v load. Eliminates guess work if loads don't work at some point. Little more expensive in wire though. I did bthe same for 110v AC, except a few outlets were linked. Wiring your trailer is much easier than your house. I worked up my own wiring diagram. Basically list all of your loads AC and DC. Then group them as you want. I grouped lights and fridges etc. So they were next to each other on the fuse/breaker panels. I'll add some pictures...
Old 03-20-2019, 12:51 AM   #148
Pictures of AC and DC wiring in progress... Click image for larger version
ID:	336108Click image for larger version
ID:	336109Click image for larger version
ID:	336110Click image for larger version
ID:	336111Click image for larger version
Old 04-07-2019, 09:04 AM   #149
Houston , Texas
Pygmypoacher, do you have a separate blog that documents your early works? Like electrical, plumbing, and axle change out?
Disable is offline   Reply With Quote
Old 07-06-2019, 08:28 AM   #150
Adinafloyd's Avatar
1976 31' Excella 500
Clinton , Louisiana
Pygmy, may I ask which shear you used to cut your patches? I will be needing to cut a few and have an idea of what I want to cut but baffled on getting curves in there. TIA
Don't take life to serious, Nobody ever gets out alive anyway
www.sweetadelida.com
Adinafloyd is offline   Reply With Quote
Old 12-23-2020, 09:20 PM   #151
Just stopped by to check on this thread. Jppatchesairstream is doing great. Systems are working perfectly. Adding the thermal fan to the stove pipe blows hot air into the back bedroom and was just what the wife ordered. Peace. Click image for larger version
ID:	385408Click image for larger version
ID:	385409Click image for larger version
ID:	385411Click image for larger version
ID:	385412Click image for larger version
Old 12-23-2020, 09:25 PM   #152
coloradoup's Avatar
1966 24' Tradewind
1987 34' Excella
Olathe , Kansas
So Cool
Still one one of my favorites!
Old 12-30-2020, 11:22 AM   #153
redthies's Avatar
1963 19' Globetrotter
1967 17' Caravel
1974 29' Ambassador
Top of the 395 , British Columbia
I haven’t been on here much lately, but it was fun to read through your thread again. And of course, since the 5 year reno of my 74 Ambassador is basically done, I had to drag home a 63 Globe Trotter yesterday. So much for free time...
We did bang out a couple more in between though...
ID:	385783   Click image for larger version
redthies is offline   Reply With Quote
Old 12-30-2020, 11:28 AM   #154
redthies's Avatar
1967 17' Caravel
1974 29' Ambassador
And a bit of color... Not exactly my style, but clients pick what they like. They do look great though.
I love the corrugated and natural wood in yours. It’s like an amazing cabin in the woods on wheels. I’m a fly fisherman and hunter so our 74 has a “mantry” to compliment the pantry. It’s a 5’ long drawer that pulls out from under the rear king bed with rifle and rod racks.
ID:	385788   Click image for larger version
ID:	385790   Click image for larger version
Old 12-30-2020, 11:58 AM   #155
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Red you do nice work!!!!! Good luck on the 63 globetrotter. We have a 61 we're puttering on ourselves.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 12-30-2020, 12:41 PM   #156
redthies's Avatar
1967 17' Caravel
1974 29' Ambassador
Thanks Hit! I’d be out pressure washing the 34 years of green funk off it right now if it weren’t for the 60 mph winds and buckets of rain. Natures pressure washer isn’t cutting through all the layers!
Sorry for the hijack Pygmy! We are pretty close to each other, so maybe some day I could see yours in person...
The Long long long trip Foiled Again Full-Timing, Winter Living & Workamping 39 03-24-2016 11:27 AM
Shrink wrapping an Airstream Don.44 Winterizing, Storage, Carports & Covers 10 11-06-2011 08:15 AM
Airstream wrapping paper..Ho, Ho, Ho... 63Silver Airstream Lifestyle 4 11-06-2008 11:09 AM
Movie: The Long, Long Trailer fritzs Our Community 5 12-29-2003 04:46 PM
