Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-24-2020, 01:44 PM   #1
1960 22' Safari
Missoula , MT
Which Rockwool product for my walls?
I read through numerous debates on what to use for wall insulation. I want to use Rockwool mineral wool, but can't seem to find anything that seems suited.
People mention Rockwool, but don't seem to specify which product I need something very close to 1.5" to fit within my 1960's walls. I have no clue how compressible Rockwool is.
Does anyone know what product that's flexible and comes closest to fitting?
If this doesn't work out, it's pink insulation for me.
Bystickel is offline   Reply With Quote
Old 10-25-2020, 12:43 PM   #2
gator.bigfoot's Avatar
KW , Ontario
You might want to try the comfort board. The batt is too thick and most likely won't work. The board would work for most places except in the end caps. There you'd have to get creative in how you cut it so it fits.
gator.bigfoot is offline   Reply With Quote
Old 10-25-2020, 11:08 PM   #3
1960 22' Safari
Missoula , MT
Thanks for the suggestion. I was concerned that anything with 'board' in the name would be too rigid, though I'm only doing the lower sections, so there's less curve to deal with.
I think I saw someone mention cutting the 3.5" down to 1.75, filet-style. I'd be curious to hear what kind of knife one would use for that.
Old 10-26-2020, 07:06 AM   #4
KW , Ontario
Just search "insulation knife". The usual places carry them. Some bread knifes will also work as will the standard utility knives. I have a variety of them and each one has a particular advantage of the other in certain situations and insulation types.
I personally would not cut down the 3.5" batt insulation. Especially Rockwool products. The board is thinner to begin with. You could also use something like the https://www.amvicsystem.com/products...oard-graphite/ series. These boards bend to some degree.
Old 10-26-2020, 09:01 AM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
GTS Interior Supply in Missoula should have the 1.5" mineral wool in stock. I think they carry the John Manville brand.
My local Home Depot has 1.5" RockWool in stock, but most HD stores don't keep it.
Any specialty supplier that caters to commercial drywall contractors should have "sound attenuation and fire safeing insulation". That's what most people call 1.5" mineral wool in my area.
I've have used this material a lot in commercial construction for sound attenuation and fire safing. It is flexible enough to bend around the curves in your trailer walls. However, holding it in place in those curves, prior to installing the interior skins, might be a challenge.
It has an R-Value of about R-3 per inch, so it will only give you ~4.5 total thermal resistance rating.
Alan
Old 10-26-2020, 09:20 AM   #6
Syracuse , New York
I just installed Rockwool in my trailer. I bought the Comfort Batt R15 and like others posted previously simply cut them in half using the insulation knife at home depot/lowes. It was surprisingly quite easy to do. I was a bit skepticle at first. I would do it again in a heart beat. 4 bags for a 70' Overlander.
Nate
fullahotair is offline   Reply With Quote
Old 10-26-2020, 02:43 PM   #7
1960 22' Safari
Missoula , MT
You folks are great. Thank you very much. I feel much better about the whole thing.
Old 10-27-2020, 10:41 PM   #8
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Images: 48
To buy it Rockwool in the right thickness, you need to look for Rockwool AFB (acoustic Fire Barrier). As sound barrier they sell it in 1/2" increments. I used 2" and it compressed just right into the cavity. I also bought EPDM foam tape for the ribs, but that was only 1/16" thick. Someone else on the forum had a link to Insulation4us.com that was the best place to buy it. I think I got it in under 2 days. It took 5 bags of 2' wide batts to do my 31' trailer, I bought 6 bags because there is free shipping after a certain dollar amount that made it a wash almost to buy 6 bags vs 5 and pay shipping.
It hasn't been terribly cold the few times we've camped in it so far, but it seems like it works pretty well, the trailer warms up fast when I want it to, and cools off fine with the air conditioner. I used 3M70 spray adhesive to hold the batts in place for the upper curves and ceiling. Wear a mask and safety glasses.
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
Can of beans is offline   Reply With Quote
Old 10-28-2020, 07:28 AM   #9
KW , Ontario
You can buy rockwool comfortboard in various thicknesses.
https://www.rockwool.com/products/co...ications&Sizes
Old 11-16-2021, 02:51 PM   #10
Lookin' to Boondock
03enduro's Avatar
1975 27' Overlander
Winnipeg , Manitoba
Send a message via MSN to 03enduro
I used 1.5” rocksul board. By making cuts on the back side of it you can make it conform to the curve. I even used it in the rear area (below the dome) and was very happy with the fit and how it stayed in place.
03enduro is offline   Reply With Quote
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 5 07-23-2021 07:11 AM
How much reflectix/rockwool did you use? RachBets General Interior Topics 5 03-22-2018 11:46 AM
Which Vulkem product to use? 68vtsafari Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 10-14-2010 08:09 PM
Product(s) to clean interior walls? YOGINA 2002 - 2005 International 1 04-26-2009 01:05 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
