11-03-2019, 07:35 AM
2004 25' Classic
Hanahan
, South Carolina
What is this on my sink?
Have two of these on my kitchen sink. Can’t figure them out.
Can I ask what accessory someone added?
11-03-2019, 08:03 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Are they attached to the counter top and if so how?
11-03-2019, 08:26 AM
1994 30' Excella
Mississauga
, Ontario
they might be mounts for soap dispenser. So that they stay put when travelling.
Al
Al and Jean
TAC ON-3
11-03-2019, 10:49 AM
2004 25' Classic
Hanahan
, South Carolina
They appear to be glued on to the counter top. I can’t locate any screws either on top or underneath. My wife would like them removed but I don’t want to damage the counter and was curious as to their purpose.
It is on a 2004 25’ classic.
11-03-2019, 04:38 PM
2007 22' International CCD
Corona
Probably on there with a circle of VHB tape or the like.
Use a very thin, flexible putty knife with rounded corners or a piece of thin guitar string and two wooden toggles to cut through the tape at the base of the plastic thingie.
Then use “Rapid Remover” from Amazon get the remaining adhesive off the countertop. Try it first in an inconspicuous area to be sure it won’t dissolve the countertop material.
11-03-2019, 05:15 PM
2015 23' Flying Cloud
Copper Hill
, Virginia
Might want to soften it up first with a blow dryer.
11-03-2019, 05:33 PM
2017 27' Flying Cloud
Fort Worth
Try Glide dental flow. Work it back and forth.
11-03-2019, 06:40 PM
Corona
Bill means “Dental floss.” Wrap a good long length of it around a couple sticks so as to not cut your fingers.
Even better idea, Bill!
11-03-2019, 06:44 PM
Fort Worth
Exactly....thanks for the catch!
11-04-2019, 05:53 AM
2004 25' Classic
Hanahan
, South Carolina
Thanks, I will give it a try today and report back.
11-04-2019, 02:06 PM
2016 27' International
Sherwood Park
, Alberta
If it is VHB tape, or the like, I would try rubbing alcohol to break the adhesion. Together with a plastic scraper, you should get it off fairly easy without damaging the counter.
11-05-2019, 05:32 AM
2004 25' Classic
Hanahan
, South Carolina
It came off with floss and a little prying in the provided slot. Tape looks like it will come off pretty easy now.
