Old 04-13-2023, 02:46 PM   #1
2023 27' Flying Cloud
Byron Center , Michigan
Twin mattress retention ideas
Can someone please connect me with an existing thread that can give some ideas on how to prevent a twin mattress from sliding off the frame. Or offer an idea that they have tried and found to work. Thanks in advance.
2travelers is offline   Reply With Quote
Old 04-13-2023, 03:29 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Add a 1/4" or 3/8" strip of plywood along the edge to extend the width by about 3 or 4". Problem solved.
2019 Ford Expedition Platinum
Old 04-13-2023, 03:29 PM   #3
2000 25' Safari
2007 27' Safari FB SE
1995 25' Excella
Woodbine , Georgia
We've never had that problem with any our twins. Is the supporting surface plywood or a composite material? I would think the pads used to keep rugs from slipping would work and are pretty cheap.
gamakai is offline   Reply With Quote
Dump Valve Retention Clip failure etojeo On The Road... 5 02-02-2020 09:27 AM
Wire retention clips crazycuda Electrical - Systems, Generators, Batteries & Solar 1 10-02-2019 06:11 AM
Awning retention hook gone, would you replace? MN Jeff Awnings 36 06-07-2016 06:15 AM
Rusty Rear Awning Retention Struts – SOLUTION withidl Awnings 7 01-03-2014 04:40 PM
Frame Rust/Belly Pan Moisture Retention?....2000 and Later Year ASs???? TomR Repairing/Replacing Floor &/or Frame 23 10-30-2009 11:17 PM
