10-21-2006, 09:56 PM
Osceola
Stupid Question Time...
I have a 74 31' Sovereign. We have gutted it in prep for a full restoration.
I have questions.
Has anyone ever gone ALL electric? Removed all propane appliances, including furnace, stove and fridge?
Recomendations for an ELECTRIC tankless hot water heater that handles high volume (I found a low volume one, but I love my LONG hot showers <grin>).
Thanks!
Merry
10-21-2006, 10:11 PM
Corpus Christi
When I was looking for my first Airstream, I ran across an all electric '96 25' Excella for sale near Sarasota, Fla. The original owner's wife was scared to death of propane due to some former incident so they ordered the all electric Excella direct from the factory. Unfortunately the trailer leaked like a sieve and the floor was rotting. It was all moldy and damp inside so I ran like hell!
So Long!
10-21-2006, 10:19 PM
Osceola
Due to an unfortunate fire in my teens, I too, am afraid of fire. Open flames don't bother me - having to restart a pilot light or a sparkingelectronic ignition, that sort of thing scares me.
We will be doing all electric, I just wondered of anyone else has ever done so? Is there anything to watch out for? Advice, tips, suggestions, things to beware of?
Thanks, Merry
10-21-2006, 10:42 PM
2012 25' FB Eddie Bauer
Virginia Beach
Fire good.
Thanks, Merry
You're going to be restricted to being at full service campgrounds only - no boondocking. Now I thought I'd be spending 99% of my time in just those circumstances, but I've found the joy of being self contained. The new gas water heaters have ignitions that don't require a long match or lighter, and a gas water heater recovers much faster than an electric one. I never had propane before, but I'll tell you the smell is "distinctive".... You'll never have a leak you won't smell LONG before it becomes dangerous.
By all means get a convection microwave oven if you want, but I'd really try to get some help getting over the fear of open flames and keep the water heater and gas burners.
Whatever you decide... enjoy your airstream.
Paula
10-21-2006, 11:07 PM
2002 25' Safari
Dewey
I agree with Paula, I boondock 99% of the time and could not be without propane. Another thing to think about is the amount of current all electric is going to use. Your trailer most likely has 30 amp service as do most RV parks. Add the amperage of the items you want to run at the same time and you will be way over the 30 amp number. 120 volt tankless water heaters draw alot of power (20+ amps) as do A/C units, stoves and ovens. Check out the units you want to get, find the amout of current they require and do the math.
Richard
10-21-2006, 11:31 PM
Salem
I have questions.
Thanks!
Merry
Hi, with everything electric, you would probably have to have 50 amp service; And with the exception of a hot plate, I believe electric stoves all run on 220 volts. And if I'm right about this, what campsites have 220 volt systems for you to plug into? High voltage could be just as dangerous as with a propane problem. [Key word Problem]
10-22-2006, 01:30 AM
1994 30' Excella
Milwaukee
, Wisconsin
You will be without a cook stove since none operate on 110 and if you ever did find one the amp drain would be too great for campground wiring. Then there is the problem of campground wiring. Many, too many, campgrounds have poor wiring, reverse grounds, no grounds, low voltage, and anything else that can go wrong. There have been times that I will plug Chummy in only to unplug and go without due to the campground wiring problems. I am willing to bet that more fires are caused by electrical problems than by propane problems. One other thing for you to consider is the resale if you do go all electric. You may not think you will ever want to sell but most of us are on at least our second Airstream. An all electric trailer will make it difficult to sell and diminish the price. I drive a motorhome with a 100 lb. propane tank that extends from the passenger seat almost to the entrance door and we keep it full. There is a propane gas detector inside but as previously mentioned the rotten egg smell from a leak is very distinctive. The only concern I have about the propane is the ever increasing price.
Chaplain Kent
Forest River Forester 2501TS
10-22-2006, 02:40 AM
Osceola
Hmmm..the voltage thing would be a problem. I shall reconsider.
That said, when we boondock, we stay in tents. We've been doing it for about 14 years. Although Mom and Pa bought a pop-up a couple years ago, they've never really cooked in it, we STILL cook outside even when they bring it along.
The problem is that we have various needs for this Airstream. It wasn't bought to camp in, it was bought so I'd have a living space while the house was being built. Due to construction delays, looks like I might be living in it for up to a year. I am permanently parked on my property, tied into septic, electric and water.
I'll be staying in it through the winter. An experimental night sleeping arrangement was tested 3 nights ago - the electric space heater did a fine job of keeping the place warm. Of course, it only dropped to the mid 30s...so we shall see.
We still have a long way to go to rehab it, flooring, cabinets and walls are awaiting a dry day because we need to caulk a couple windows before the floor is tackled. Some leak spots have damaged the subfloor.
Anyway, I'll talk to the husband and Pa about which propane devices may stay, if any.
Thanks for the advice and I'll refer them here to see what you have to say, too! Thanks again!
Merry
10-22-2006, 07:23 AM
Corpus Christi
On the "all electric" Airstream I saw in Sarasota, the owner used a 110v hotplate for cooking. The upgrade to 50 amp service will likely be a necessity.
So Long!
10-22-2006, 07:50 AM
St. Cloud
No trailer should be without a smoke detector and CO detector (mounted high) and a propane detector. The latter is mounted near the floor since propane is heavier than air. One might not smell it right away down there, so the detector is vital. New units certainly have all three and anyone should retrofit if theirs doesn't have them!
I was traveling last week in 30 degree weather and having my LP furnace running was cheap insurance to keep the pipes thawed. (Unthawed if you speak Minnesotan... )
10-22-2006, 07:59 AM
Iowa City
, Iowa
CO detector
Canoe Stream,
I know smoke detectors need to be up high, but I just got a CO detector and was going to mount it low. I always thought it was "heavier" than air. (Our home bedroom is below grade and our kids said we needed to put one at a lower lever where the CO "sinks". I need to be sure on this one.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
10-22-2006, 08:02 AM
Corpus Christi
It occurred to me some people may be too young to remember hotplates so here's a pic of one:
So Long!
10-22-2006, 08:40 AM
I agree that you should probably upgrade to 50a service if you want to avoid propane. You can run a 240V cooktop and oven on a 50a campground service, or your temporary service at the construction site.
You should figure out a way to get warm air to the black and greywater tanks if you don't use the propane furnace. May be as simple as installing a booster fan in the existing ductwork, or running just the furnace fan to draw warm air from the electric spaceheater.
10-22-2006, 09:43 AM
West of Fort Worth
Originally Posted by Auretrvr
Canoe Stream,
Actually, it depends. Here's a link.
Dave
http://www.newton.dep.anl.gov/askasc.../chem03364.htm
10-22-2006, 09:50 AM
Jupiter
The premium private campgrounds will put a premium price on heavied-up 120V service whether you use it or not, and will only have a limited number of spaces available for 50A... Also if they see a 50A to 30A conversion patch on your power cables they may have a fit. For the extra $10 or more a night and hassles I would go with propane, no one says you have to have tank valves open except when needed...
10-22-2006, 10:17 AM
2002 25' Safari
Dewey
Good link! The fact is, CO is almost the same weight as air. The most important thing about a CO detectors location is that it will wake you up. I have a combo smoke and CO detector mounted on the wall in the sleeping area of my TT. My wife always complains when I test it (when we setup at a campsite) saying it is way to loud. I always tell her thank you, it's working....
Richard
10-22-2006, 11:04 AM
Hag of Horror
1968 30' Sovereign
Edge
, Near the Edge of the World
I was seriously considering going all electric myself....not from a fear of fire, but more because it is easier to get electric green.
We came upon the same difficulties. There are not appliances out there (at least not at anything approaching a reaonable price) that won't draw tons of amps. Even semi-permanently docked as we shall be, it becomes problematical to hook up to the pole.
Electrical fires scare me alot more than propane fires. Electric fires don't give you any warning. With propane, you get the warning of the god-aweful stench.
The tankless waterheaters are pretty good. They are set up to self-light when they are used, so you don't have to worry about matches and lighters to get hot water.
*shrugs* We're replacing our propane lines with modern stuff. Maybe I'll turn all of that old copper into a sink or something. Still, going almost all propane makes it a bit easier. The propane A/Cs, refridgerators, stoves, heaters, etc., simply work better than electric.
Of course, we found the old gas-lights...and are seriously considering putting them back in. *chuckles*
Doing some internet research, or simply asking about it here, will give a whole bunch of information that is probably more than you need. *grinz* In truth, if you cannot find a new trailer on the dealer's lots with the things you want in it, there is probably a good reason why that is so. 70% of the time, it is because it is just too darn expensive to build them that way. The other 30% of the time, however, it is that to build them that way is bad, bad idea.
Peace,
Caliann
10-24-2006, 09:19 PM
Osceola
K- we've decided to keep the propane for stove, furnace and hot water. However, we are saving it for the future complete rehab.
At this time, because I am parked permanently and need shelter almost immediately, we are doing a quick and dirty repair job instead.
My husband Richard caulked the entire trailer from AC down. He repaired the subflooring where the leaks occurred, then we covered it with 1/4 plywood for added strength. We used screws rather than nails or glue so it can be easily removed later. This will then be covered with tongue and groove floating fake wood floorboards.
Pa has wired the permament hookup with both 30 amp and two 20 amp circuits so I can have other things plugged in without blowing a fuse. We will use the extra circuits for an electric oil heater and something else - not sure what (microwave?). He will run conduit and insulate it properly for cold weather.
Phone and TV lines will run through conduit via the original fridge propane outlet so we don't cut new holes in the outer or inner skin.
I will have a small electric dorm fridge and microwave for snacks.
We are still in the beginning stages of how to handle hot water at this time. For the moment I have cold water (well-insulated). If I DON'T use propane while parked, we're looking for alternatives. However, it may be that I WILL use propane, and then its simply a question of connecting it to the existing hot water tank, if it is viable.
In about a year when home construction is completed,we will take the Airstream down to the chassis and reconstuct her properly.
As I had mentioned before, we bought this vehicle for various uses, but the most demanding one at this time is a home for me to spread out and do my work.
So as it stands, the advice from all of you has helped a great deal in determining what we will be doing for the future.
That said, we LOVE the Airstream and are having fun working on it.
THANKS! ~ Merry
10-24-2006, 09:34 PM
More than one rivet loose
Los Alamos
CO is lighter than air. 12+16=28
O2 16+16=32
N2 14+14=28
Michelle TAC MT-0
Sarah, Snowball
10-24-2006, 10:00 PM
Missouri gets pretty cold in the winter
Are you planning on living in a trailer for a year in Missouri ?????
There is a link somewhere about winter camping. The weak links are where water goes in and where " fluids " come out. They will freeze unless you do some real fancy engineering.
If I was going to winter camp, I would probably
use electric heat. The furnace will deplete your propane in about ten days
