Spring nuts for c channel?
Hello,
I am in the process of replacing a small portion of my subfloor in my 73 tradewind.
I know the recommended approach is to remove the belly pan to gain access to the bottom of the c channel, however I have thought of a way to potentially bypass this step and wanted to gather people's thoughts who are smarter/more experienced than me.
I see spring nuts such as the ones in the link below used in automotive construction. My thinking is to attache these to the bottom portion of the c channel and then just be able to screw bolts directly into it.
If I get some made out of strong enough steel it should work right?
https://m.lowes.com/pd/Hillman-2-Count-10-Black-Phosphate-Standard-SAE-U-Spring-Nuts/3013180
Regards,
Dane H.
