Old 01-10-2023, 02:58 PM   #1
ondaroadagin's Avatar
2016 27' International
San Anselmo , California
Shower Door Debacle
We're full timers, on the road now in our seventh year. Our shower door has been a constant source of leaking irritation. We noticed someone on the Forums who posted about their Nautilus shower door system using a flexible poly roll up screen that self squeegees, and decided to deconstruct our troublesome shower door and install this promising replacement.
Tearing out the old door which had broken during our travels, and had to be lifted up to open, was a chore to remove but doable. Carrying the old door to the trash instructed us how its weight had added to our load. The new door is feather light. The instructions are easy and the frame parts can be cut to fit easily into the Airstream frame pocket, however, potential buyer be aware, the instruction sheet does not take into account Airstream's wooden framework in contrast to a porcelain surround. We installed our door with the door closing to the right hand and although we caulked well on the outside and inside, saw significant leaking along the framework's lower section onto the floor. Soon water began seeping into the wood below the door and we called the company engineer to get a solution. They recommended we caulk around all the seams but to no effect. I removed the roll up screen from its cassette and noticed two notches in the lower frame that allowed water to pass through onto and through the Airstream wooden frame support to each side and penetrate the wood. However, I did see that the upper cassette had no such cut outs and mentioned this to the Nautilus design engineer. He agreed to my supposition that this was the cause of the leak! Not a good time to find out!
Asking why this wasn't mentioned in the installation instructions, I was told that they couldn't foresee every installation situation, and I was able to have them send me a new door to install.
Once again I had to deconstruct all the caulk removal and detach the framework from the wall held in place by hard core 3M double sided tape.
I flipped the new framework 180 degrees so it now closed to the left hand and the notches were up on the other side no longer subject to water intrusion, and again carefully caulked the heck on both sides extremely carefully. Water has a nasty way of finding an escape route. This fix has solved the problem and I'm passing this information on to everyone in case they wish to lighten their load, eliminate glass squeegeeing, and eliminate door opening competition between the shower and bathroom.
Name:	Nautilus shower door.jpg
ID:	427041   Click image for larger version
Name:	shower door leak spots.jpg
Ars Gratia Artis
https://www.anamericanstream.com
Get our travel writing ebook on Amazon: "Wanderlust: A Scrapbook of life on the Road"
ondaroadagin is offline   Reply With Quote
Old 01-10-2023, 07:12 PM   #2
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
So, that's a sliding/roll-up shower door? Interesting idea. You like it?
10Smiles is offline   Reply With Quote
Old 01-10-2023, 08:26 PM   #3
2022 27' Globetrotter
DALLAS , TX
I am reading this via the app and can't see what trailer you have and the model year. Would you mind sharing that information? Thanks.
foobar is offline   Reply With Quote
Old 01-10-2023, 08:36 PM   #4
2002 19' Bambi
Lafayette , California
Yes, it is. A very similar roll-up door came with our 2002 19' when we bought it new and it is still performing superbly. Such doors have been discussed several times on the forum over the years. Another brand was Shub/Newline, but they appear to be no longer in business.
Tim
Tim A. is offline   Reply With Quote
Old 01-11-2023, 04:37 AM   #5
Yes. Now that we're past the construction complexties.
Ars Gratia Artis
Old 01-11-2023, 04:39 AM   #6
2016 International Serenity, 27'
Ars Gratia Artis
Old 01-11-2023, 04:44 AM   #7
P. S., We keep our mini washing machine in our shower and love not having to mess with a glass door interfering with access.
Ars Gratia Artis
Gmc Denali debacle kapt59 Tow Vehicles 15 09-17-2016 06:43 AM
Step Outrigger Debacle Widget Steps 2 06-01-2016 11:05 AM
The PayPal debacle?! das997 Dollars & Cents 29 01-11-2013 05:54 PM
Honda 7000is Conversion Debacle chaimemet Generators & Solar Power 0 06-20-2007 07:50 PM
