Old 09-25-2020, 08:21 PM   #1
1992 34' Limited
Sherwood , Arkansas
Images: 12
shower door
my plastics folding shower door is breaking all the running wheels etc was wander if people are replacing it with solid door or just wire rings and shower Curtin etc thanks for any help
Highball is offline   Reply With Quote
Old 09-26-2020, 02:23 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Your profile says your trailer is a 1992 34 ft Ltd. Plastuc that is almost 30 years old is going to degrade so it is definitely due for replacement. If you can't decide which you will like most, replace it with a curtain. It is easier and less expensive than a door. Then if you don't like it, upgrade either to a food or another folding plastic door or a Nautilus retractable door from Stoett.
I am personally not a fan of the glass doors as they can shatter (rare but it does happen), the ones Airstream uses tend to sag with use and vibration and the swing can interfere with other doors. YMMD
Old 10-26-2020, 07:21 PM   #3
2016 23' International
2005 19' Safari
Fredericksburg , Texas
Hi Foiled Again,
I am replacing My glass showedoor with a Stoet curtain door.
Question do you know how to get the side rails off of the shower after taking the three screws off each side. The side rails won’t budge off the walls.
Seems like several people have had this same issue. But I can’t find an answer.
Can you advise anyone that might know. thank you
Jeffery
jp77texags is offline   Reply With Quote
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 27 10-02-2022 06:12 PM
replaced shower accordion door with solid door waninae39 2005 and newer - Bambi all models 7 07-01-2019 01:37 PM
Has anyone had a custom lucite or clear plastic folding shower door made fro shower? Driftin Di Sinks, Showers & Toilets 2 08-09-2017 07:34 AM
To shower or not to shower? urbanfood Sinks, Showers & Toilets 55 07-19-2012 11:39 PM
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 09:18 AM
