Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-23-2016, 06:54 PM   #1
2.7
_ , Texas
Removing paint from walls of Airstream
Is it possible to remove white paint that was painted on the interior walls of an Airstream and return it to what it looked like from the factory? This is on a 1971 Airstream. Someone please correct me if I'm wrong, but I believe the material on the walls inside the trailer is called Zolatone. It was originally a light tan color as the person did not paint it inside the closets and it is still visible in there. If possible, I'd like a way to return the living area and bedroom to that same look.
2.7 is offline   Reply With Quote
Old 10-23-2016, 07:27 PM   #2
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
I think Zolatone was on 50's and early 60's trailers. Mine has vinyl covered aluminum, so should yours. I doubt you'll be able to get the paint off if it was applied on a clean, primed surface.
CaCraig is offline   Reply With Quote
Old 10-23-2016, 08:24 PM   #3
2.7
_ , Texas
Oh okay, thanks. It probably is vinyl then. I wasn't sure what it was.
Is yours painted? If so, what color? The person that painted this painted it white, and it shows everything.
Old 10-24-2016, 07:42 AM   #4
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Mine is not painted except for just a few inches around the air conditioner. It's white and it shows every mark.
Old 10-24-2016, 01:59 PM   #5
Life long Airstreamer
korgen's Avatar
1966 24' Tradewind
Lewiston , Idaho
I have a 66 TW and the inside was painted over with a dark green by the previous owner. I am stripping all the paint down to the vinyl with orange stripper which is working well. You have to let it work long enough and not to scrape too hard or you can damage the vinyl. Then I'll sand it and paint.
korgen is offline   Reply With Quote
Old 10-24-2016, 05:02 PM   #6
2.7
_ , Texas
Are you using Citristrip?
How does the vinyl look underneath the paint?
To Rip Off Walls Or Not To Rip Off Walls... belikethefox Upholstery, Blinds, Walls & Interior Finishes 5 07-23-2021 07:11 AM
Interior Walls - Paint and Primers LI Pets Upholstery, Blinds, Walls & Interior Finishes 45 07-12-2009 02:44 PM
stripping paint from original vinyl interior walls Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-10-2008 05:37 PM
Removal of Zolatone Paint from Interior Walls of '54 Wanderer rek Upholstery, Blinds, Walls & Interior Finishes 16 10-30-2007 04:38 PM
Paint for Shower walls? myboyburt Sinks, Showers & Toilets 4 04-28-2005 07:54 PM
