04-18-2017, 03:48 PM
2019 27' International
1964 17' Bambi II
Ogden
, Utah
Removal of labels & stickers
Is it generally recommended to remove the interior & exterior labels & stickers on the stone, refrigerator, exc. If the labels are to be removed what is the best product to use so there is not scratching or residue left? Thank you.
04-18-2017, 03:57 PM
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
Heat it up and peel it off. Get it warm but not so hot you can't touch it and they should come off with the glue. Any residual glue can be removed with Goo Gone adhesive remover. Rub with the grain on aluminum and stainless.
04-18-2017, 04:00 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Or soak with WD-40 and remove.
2019 Ford Expedition Platinum
04-18-2017, 04:08 PM
2016 19' Flying Cloud
Austin
I would leave the GVWR, etc., on the outside. Yes?
The rest of them are the worst stickers ever! I've had my AS a year now and still haven't removed all the stickers.
04-18-2017, 04:14 PM
blackdog06
2017 25' Flying Cloud
2015 23' Flying Cloud
Tuttle
, Oklahoma
I just got rid of of all our stickers using Goo Gone and a microfiber cloth. I did leave the GVWR sticker. On our last trailer I used paper towels instead of the microfiber and it left faint scratches.
Forgot to say that I first peeled off as much as possible by hand before using the GG.
04-18-2017, 04:18 PM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
The easiest and safest way is without chemicals. Vigorous rubbing on the clearcoat with anything even mildly abrasive can cause fine scratches that you don't see until later (on a sunny day). Use a 3M Adhesive Eraser Wheel instead.
04-19-2017, 11:21 AM
2016 30' International
Quartz Hill
Another vote for Goo Gone.
Works well on leftover adhesive after peeling off labels
04-19-2017, 12:41 PM
Burlington
, Vermont
In Vermont they sell a product called "Goof Off". Probably the same idea.
04-19-2017, 07:27 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Must be "price tag" glue
04-20-2017, 06:52 AM
, Ontario Canada
Goof Off is way stronger than Goo Gone and can create other problems I don't recommend it unless you are careful and don't let it sit too long and avoid getting it into the seams as it could ruin the seal. If you can get Goo gone WD40 is good.
04-20-2017, 02:06 PM
2017 23' Flying Cloud
Parker
I used a plastic razor blade and then isopropyl alcohol. When used gently, it worked great, no scratches anywhere, even on sunny day.
Soak rag/microfiber towel with isopropyl, soak sticker with rag, then use plastic razor to take it off. Then go over gently with rag again to get residual off.
Troutboy
04-20-2017, 02:17 PM
Granbury
I've tried everything under the sun and nothing works as good as good old WD-40.
WD-40 also works to remove tar and bugs from exterior.
I found it better at driveway oil removal than stuff they sell for it.
Really does work. Give it a try!
04-20-2017, 02:30 PM
2016 25' Flying Cloud
Jupiter
I agree. WD-40 sprayed onto a microfiber cloth does the trick.
04-20-2017, 03:24 PM
Austin
I thought I remember hearing that lighter fluid works as well.
05-13-2017, 08:58 PM
redondo beach
Today was sticker abatement day using WD40.
Lets hope all the stickers were not needed for structural support.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
05-14-2017, 07:00 PM
2018 19' Flying Cloud
Newport
Our 2018 FC19 is supposed to ship in a about 2 weeks. Would it be in bad form if I were to ask the dealer to remove the stickers as part of his prep work?
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
05-14-2017, 07:18 PM
Jupiter
I don't know about bad form, but I suspect they wouldn't be able to do that for you. It's not hard, and it only takes a few minutes per sticker when they are pretty new. At least that's all it took for mine.
05-14-2017, 07:40 PM
Fayetteville
, Arkansas
What, if any, should remain? Are there any that are less likely to cause corrosion?
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
05-14-2017, 08:41 PM
2014 30' FB FC Bunk
Hoover
, Alabama
Remove them all!!! They come off easy early
Later they are a pain.
One has like maybe vin # or other info as I recall? That one leave of course.
